Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Closed Thread
Old 11-27-2005, 05:09 PM   #1
STIGSXR
Member#: 95700
Default Best Turbo Upgrade For Sti??
I have recently installed unequal length headers, upipe, invidia v2 downpipe, 3" N1 exhaust. My VF39 recently blew, and im not sure if i should get the same turbo, or go alittle bigger now that i have the chance? Ive been looking at the VF22 and other series, but I know its laggier and people have said theres only a small increase in hp between them. Im mostly looking for a used turbo, around 300-400 range. Any ideas would help.
Thanks.
STIGSXR is offline
Old 11-27-2005, 05:12 PM   #2
the_colombian
Member#: 84912
2003 2.5L bugeye now
with 6 spd 20g!
for that price, prolly a vf39 or vf34. Unless you get lucky and you find someone with a 18g or so.
the_colombian is offline
Old 11-27-2005, 05:50 PM   #3
burnin4
Member#: 59764
10 sec STi
10 sec Z06
if 300-400 is your range, I'd get another vf39. imo, the vf39 is better than a 22 or 34.
burnin4 is offline
Old 11-27-2005, 06:07 PM   #4
Usaf*STi
Member#: 88063
06 STi
Black as night
this subject is killed. im a newbie and even i kno that you should have seached on this one a lil more. with that said a blown turbo is a perfect time to upgrade to a bigger and better model. the only problem is that you will need new injectors and fuel pump if you go much larger. call up deadbolt and see what they have in stock. they have excellent customer service and will be able to steer you in the right direction.
edit: save up more money as im an idiot and didnt look at how much money you said
Usaf*STi is offline
Old 11-27-2005, 06:10 PM   #5
burnin4
Member#: 59764
10 sec STi
10 sec Z06
dude, he said $300-$400.
burnin4 is offline
Old 11-27-2005, 06:46 PM   #6
NaVaWRX
Member#: 48381
use the same turbo or upgrade to something crazy but since u only looking to spend 300-400 .. then vf39 is the only one i would go with .
NaVaWRX is offline
Old 11-27-2005, 07:26 PM   #7
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
.....300-400???
forget it unless ya find a vf22 somewhere
Uncle Scotty is offline
Old 11-27-2005, 07:31 PM   #8
SketchINoc
Member#: 87370
2005 WRX,Soon to be
EVO9-94 toyota4x4 project
vf22 will net you a lil more power with a tune
SketchINoc is offline
Old 11-27-2005, 08:18 PM   #9
Davenow
Member#: 23676
How do you figure?
The 22 has a bigger hot side, which is better suited to the larger engine, and the 34 is essentially the exact same turbo. If he can find a VF22, it would be ideal for his car. I have driven a basically stock STI with a vf22. If they had to put an IHI on that car, it should have been a VF22. The bearing part of it is a non issue. It spools very fast and holds more boost to redline.
The problem is, forget finding a VF22 in that price range anymore. They have become rare and EXPENSIVE enough that they arent worth buying.
Davenow is offline
Old 11-27-2005, 08:31 PM   #10
cooter
Member#: 23258
2005 STi
I would not get another vf-39. They appear to have issues with cracked turbine housings: http://forums.nasioc.com/forums/show...t+cracked+vf39
For your budget, I would suggest a used vf-30, 34, or 22....whichever you can find with the least miles and in the best condition
cooter is offline
Old 11-27-2005, 09:36 PM   #11
sr55stiguy
Member#: 97225
05 white STi
10 sec 515whp 95 hatch
pmed you
sr55stiguy is offline
Old 11-27-2005, 10:30 PM   #12
STIGSXR
Member#: 95700
If i buy a vf22, 34, or 30 turbo wouldn't i have to then get tunning??
STIGSXR is offline
Old 11-27-2005, 11:00 PM   #13
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
the 30 and 34 won't require any special tuning, although you would definitely benefit from it...
However, just about any turbo you buy except the VF39 will require a different right-angle silicone hose to connect it to the intercooler.
nhluhr is offline
Old 11-27-2005, 11:01 PM   #14
Davenow
Member#: 23676
not for the 30 or 34. They are almost identical to the 39 as far as flow and when they spool.
The 22 will be so close that there is a huge chance that the stock ECU will be able to adjust within its parameters for it. Its not a big upgrade by any means. Its less of a difference going from a 39 to a 22 than going from a stock TBE to a aftermarket TBE.
Davenow is offline
Old 11-28-2005, 12:37 AM   #15
burnin4
Member#: 59764
10 sec STi
10 sec Z06
i should have said easier. more likely to find a 39 for $300-$400. 22 might offer more power but would require tuning to maximize its potential, instead of bolting on the 39 and driving away.
Originally Posted by Davenow
How do you figure?
burnin4 is offline
Old 11-28-2005, 09:12 AM   #16
Davenow
Member#: 23676
true that. But from the 2 untuned, otherwise basically stock STIs I have driven with VF22s on them, there is very VERY little tuning needed. Its that close to the 39.
I think we pretty much all agree that his easiest way out of this (and cheapest) will be a used 39 or 34 (no tuning required and avail cheap used)
Davenow is offline
Old 11-28-2005, 02:39 PM   #17
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
I would say save your money for a bigger but since you have no turbo currently find a vf-22 and stick that thing in your car.
fastwrx006 is offline
Old 11-28-2005, 03:38 PM   #18
STIGSXR
Member#: 95700
What modifications would you recomend I do on a VF39 to help increase hp?? And are they worth the money??
STIGSXR is offline
Old 11-28-2005, 04:59 PM   #19
subalou1
Member#: 57966
2002 wrx Sedona Red
11.59@124, best trap 131
id save for alil longer and get something nice, there isnt much out there in that price range unless its half near destroyed.
subalou1 is offline
Old 11-28-2005, 06:41 PM   #20
kevinh211
Member#: 56297
2004 STi HTA Green
28psi, MSPT Tuned
you have a $30,000 car and with mods but only want to put used turbo on it for $400
kevinh211 is offline
Old 11-28-2005, 11:42 PM   #21
STIGSXR
Member#: 95700
The VF39 only goes for around $800 new. And i found a bunch of them with less than 1k miles on it for that price range.
STIGSXR is offline
Old 11-29-2005, 03:23 AM   #22
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
Get a real turbo for your car. Sorry to say it but IHI turbos are a POS, don't even waste your time with another one. I went with the 20g as did many other people, the 20g is the ideal/perfect turbo for the sti.
Old 11-29-2005, 03:28 AM   #23
STi-MAN
Member#: 70252
05 STI
blue
I think i'd lean towards a green or red, although its way past the projected budget.
STi-MAN is offline
Old 11-29-2005, 03:34 AM   #24
kedrin
Member#: 48380
you need to check this baby out
its one big bad boy perfect for sti's.....
(noob use the search button this topic has been posted a bagillion times)
kedrin is offline
Old 11-30-2005, 05:06 PM   #25
STIGSXR
Member#: 95700
Thanks, but can someone actually help answer this question?
STIGSXR is offline
Closed Thread
best turbo upgrade for 06wrx subaruNV Newbies & FAQs 46 02-26-2008 02:59 AM
Which turbo upgrade for sti JoeBallz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 37 03-21-2006 10:26 PM
Best turbo upgrade for low end? blaznc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 02-12-2004 01:03 PM
to the powers that be: what are the best turbo upgrades for the STI bikerboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-25-2003 08:43 PM
best turbo upgrade for 11's 1quiksoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 12-09-2002 05:46 PM
