Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Closed Thread
Old 12-03-2005, 12:41 AM   #26
STIGSXR
Member#: 95700
any other thoughts??
STIGSXR is offline
Old 12-03-2005, 07:05 PM   #27
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Whether or not you go to another VF39 or a VF22 or VF34 or something equivalent or larger, something you could do is to either get the tubo ported & polished or do the P&P work yourself.
Deadbolt can certainly do the P&P work ($195 for an IHI turbo) http://www.boostplanet.com/services.htm and there are others on the board who do P&P work but I don't know what they charge.
You won't have any issues with work from Deadbolt and some on the board have gotten good reviews for their work also.
The P&P will smooth out the air flow through the turbo (going in and going out) and this will give you a slight increase in spool (300 - 500 RPM) w/associated torque increase.
If you want to maximaze the results of the P&P work and your upgrades, EM will be necessary. Everyone has their favorited for EM, and you have a number of options to choose from (Hydra, Ecutek, COBB, possibly others)
Samurai Jack is offline
Old 12-04-2005, 01:39 AM   #28
bgod
Member#: 100274
why not just stick with your current blown turbo and have it rebuilt?
your choices seem limited within your budget so this might be your best bet.
bgod is offline
Old 12-04-2005, 02:13 AM   #29
Davenow
Member#: 23676
IHIs arent worth the trouble. You can get another VF39 off ebay for a couple hundred bucks.
The 16/18/20G turbos are MUCH better units. As said earlier, IHIs pretty much suck. But if you are going to buy an IHI, lok for a VF22 first, although good luck finding one under 1400 bucks now, if at all, then a 34 then a 39. I wouldnt put a 30 on it unless I HAD to.
Davenow is offline
Old 12-04-2005, 12:41 PM   #30
STIGSXR
Member#: 95700
What do you guys think about a VF23 on an sti? Is it worth spending alittle more money on that instead of the 39?
STIGSXR is offline
Old 12-08-2005, 12:29 AM   #31
STIGSXR
Member#: 95700
bump to top
STIGSXR is offline
Old 12-08-2005, 01:45 PM   #32
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
It's been said before....IHI turbos are junk and should be overlooked completely. If your looking to replace the stock turbo but you don't want a oversized turbo then look into a TD06h-18G. I'll never stop suggesting these turbos for the sti- 18g, 20g, sz49, sz55 depending on your goals any of those turbos would be great.
fastwrx006 is offline
Old 12-08-2005, 01:48 PM   #33
STIGSXR
Member#: 95700
Whats the price range on a slightly used one? Can I also run the car with stock injectors and pump and be able to wait alittle to get EM?
STIGSXR is offline
Old 12-08-2005, 01:51 PM   #34
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
Please don't do that. Wait until you have at least injectors, pump, EM(I love ecutek). You don't want to risk anything on a 30k+ car, I say do everything all at once and don't peice things together bit by bit.
Old 12-08-2005, 01:53 PM   #35
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
Not sure on the price of a used 18g but I'm sure you can find one a lot less then you would for a new one if you look around.
Old 12-08-2005, 02:08 PM   #36
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
Can you use any of those turbos with the stock STi TMIC???
conker69 is offline
Old 12-08-2005, 02:09 PM   #37
WrxWonderWagon
Member#: 67265
04 35r Sti meth
What Spelluring?
save
get a green
WrxWonderWagon is offline
Old 12-08-2005, 02:19 PM   #38
ESEMES
Member#: 67128
2001 996TT
seal
I have a VF39 (from my 06) up for sale.
2300 miles, no cracks, and ready to go!
-ese
ESEMES is offline
Old 12-08-2005, 02:29 PM   #39
calib17a
Member#: 64150
If you only have $300-400 just get another vf39, like this guy's ^^^, to get you back on the road, then save up these items as they will be needed all at once for an upgrade: em, larger injectors, 255 lph fuel pump, and larger turbo (fp green, 20g, etc).
calib17a is offline
Old 12-08-2005, 03:03 PM   #40
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
Of course it fits just fine with any of those turbos.
Old 12-08-2005, 03:14 PM   #41
conker69
Member#: 59692
WRB-Gold
Excellent. I plan to upgrade the turbo in the future but I don't want to move to a FMIC for several reasons. Keeping the TMIC is a must for me so I have been looking for aftermarket turbos that will fit that bill. Thanks for the information.
conker69 is offline
Old 12-08-2005, 03:41 PM   #42
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
I ran as big as a sz49 on my spearco tmic so I would hope you could fit much larger turbos on the stock tmic.
Old 12-08-2005, 08:56 PM   #43
conker69
Member#: 59692
WRB-Gold
Well I was more concerned with heat soak than anything. Of course it is depends on the capacity of the stock TMIC but I would guess heat soak is a bigger issue with an aftermarket turbo.
conker69 is offline
Old 12-08-2005, 10:27 PM   #44
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
The tmic will get hot no matter what because of it's location but with my 20g in there wasn't much heat soak to talk about, the big ass scoop really does its job. If your worried about heat soak you can get some turbo wrap the unabomber always talks about
Old 12-16-2005, 11:17 AM   #45
STIGSXR
Member#: 95700
I've found a big 16g turbo for a good price brand new, is it bigger than the stock vf39?
STIGSXR is offline
Old 12-16-2005, 11:28 AM   #46
moorebl
Member#: 59238
selling my sz49 fatboy because i am going 35r. 1500 miles. considered to be the best turbo period for the sti
moorebl is offline
Old 12-16-2005, 11:29 AM   #47
STIGSXR
Member#: 95700
yea if i had the money id deff buy it, but im looking for something smaller right now.. thanks
STIGSXR is offline
Old 12-16-2005, 11:42 AM   #48
BigJ04STi
Member#: 77239
2004 Impreza WRX
None
There are plenty of Used Lower mileage PE1820's on this board and others...
It's a good upgrade in my eyes...will fit easily, ball bearing, not a huge upgrade but will easily make 300+ whp from 14.7psi-24psi...If you want to keep it moderate, run like 17psi on it, with the other supporting mods, and I'd say you'll easily reach 300whp and 320tq range, with similar to stock spool, and metter mid and upper range power...
They are selling around $700-$900 used...about $1500 new... (it's a waste of money new for that price)
All you'd need is a mild injector upgrade (depending on boost, some people are using stock STi injectors), Walbro, turbo back, TMIC (stock or aftermarket)....and a tune...
I think it's a good idea...
BigJ04STi is offline
Old 12-16-2005, 11:44 AM   #49
mikeyg
Member#: 86497
04 STI
Default at least 20g
I wouldn't consider a turbo upgrade for myself unless i went with a 20g at least, green, zilla, red, etc... After that I'd look to SZ49/SZ55. The supporting mods required will be injectors, fuel pump, and some other stuff. So it will cost way more than it looks like you are willing to spend. Anything else just wouldn't be a significant enough improvement imo. Buying another stocker ( there should be plenty of them) and getting a tune isn't a bad option. I've seen guys make close to 300 wheel plus or minus some. Other than that, I would save for 20g.
mikeyg is offline
Old 12-16-2005, 11:44 AM   #50
conker69
Member#: 59692
WRB-Gold
How much??
conker69 is offline
Closed Thread
best turbo upgrade for 06wrx subaruNV Newbies & FAQs 46 02-26-2008 01:59 AM
Which turbo upgrade for sti JoeBallz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 37 03-21-2006 09:26 PM
Best turbo upgrade for low end? blaznc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 02-12-2004 12:03 PM
to the powers that be: what are the best turbo upgrades for the STI bikerboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-25-2003 07:43 PM
best turbo upgrade for 11's 1quiksoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 12-09-2002 04:46 PM
