Vancouver Impreza Club
Old 11-07-2009, 06:30 PM   #651
normega
Member#: 180831
normega is offline   Reply With Quote
Old 11-08-2009, 09:33 PM   #652
k20a
Member#: 132712
1992 Civic CX
EJ257 Swapped!
Originally Posted by Linkseal View Post
What's with the 650hp STi build on your FB?
I am sure 511awhp is somewhere around 650 to the crank right?
k20a is offline   Reply With Quote
Old 03-02-2010, 06:43 AM   #653
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
574WHP & 502WTQ SAE corrected
596WHP & 522WTQ Uncorrected
29psi - 94 octane and 70/30 meth injection
alcoolaid is offline   Reply With Quote
Old 03-24-2010, 06:11 AM   #654
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
^don't round off the numbers arthur=.= your car is fast enough that u dun need to do that......i will need to hahahaha
alvinli217 is offline   Reply With Quote
Old 03-24-2010, 01:05 PM   #655
RX Renesis
Member#: 108624
'06 SlowBaLow
MEISTER
its not rounding off, it's called SAE correction.
RX Renesis is offline   Reply With Quote
Old 03-24-2010, 01:12 PM   #656
Linkseal
Member#: 102329
05 AW Piggy Gone
11 SP TOM'S IS-F
NICE!! Can't wait to test sit in it!!
Linkseal is offline   Reply With Quote
Old 03-24-2010, 01:56 PM   #657
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
Look a bit more closely, he rounded up.
420WRX is offline   Reply With Quote
Old 03-24-2010, 02:00 PM   #658
RX Renesis
Member#: 108624
'06 SlowBaLow
MEISTER
huh? where?
Old 03-24-2010, 02:46 PM   #659
420WRX
Member#: 27752
573.5 is 570 to most people, not 574 and 501.8 is 500 to most people, not 502.
You are talking about numbers that can shift a bit based on temperature or other conditions.
I'm just sayin'
Old 03-24-2010, 07:11 PM   #660
geebutbut
Member#: 118451
I'm just sayin'
where did you learn to round?
geebutbut is offline   Reply With Quote
Old 07-18-2010, 11:02 PM   #661
Petrie
Member#: 1260
09 STi, DGM
04 WRX Stage 2, red
I used my onboard computer to datalog a 3rd gear pull today.
Elevation: 50 feet
Temp: 75F
Humidity: 44% (taken off the weather network)
2009 STI, oem wheels and tires.
AVO panel filter + Grimspeed AOS (everything else is stock)
Max whp: 258 @ 6400 rpm
Max wtq: 262 @ 4090 rpm (18.57 psi boost)
Torque curve sits just on top of 250 from 3500 - 4700
Torque @3K rpm, 205 and betters that all the way to redline
I'm quite pleased with those figures considering its only an OTS stage 1 tune.
Dyno plot was done using the Airboy spreadsheet.
Soon I'll have the plots embedded in the onboard computer.
Petrie is offline   Reply With Quote
Old 07-19-2010, 04:04 PM   #662
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Elevation: 50 feet
Temp: 75F
Have you put your car on RR's dyno with the current setup? I am curious to see how Airboy's spreadsheet compares.
Those are really good numbers though for a state 1 tune
minifreak is offline   Reply With Quote
Old 07-19-2010, 04:11 PM   #663
Linkseal
Member#: 102329
05 AW Piggy Gone
11 SP TOM'S IS-F
Elevation: 50 feet
Temp: 75F
For your STi should try to do the 4th gear pull for the more accurate dyno data
since 4th gear will give you the max engine load under full boost.
We normally do 3rd gear pulls on WRX and LGT, and always 4th gear for STi.
Old 07-19-2010, 04:24 PM   #664
Petrie
Member#: 1260
09 STi, DGM
04 WRX Stage 2, red
I hit max load at 2500 rpm.
The car has not been on the RR dyno (at least it has not been logged on the dyno). As this was the first 09 tune, Pat put it on the dyno to double check there was nothing new in the ECU and make sure everything was smooth. He certainly managed to do that. Delivery is smooth and, in S#, the car is eager to stretch its legs.
The expectation was that the car was making 260whp and that's proved to be accurate. At some point I would like to verify that the plots I get are consistent with the spreadsheet macros but that's not a priority.
I can now log it any time I want to compare results. 4th gear is a little trickier because you cover quite a bit more ground and need more space. I'll try 4th gear soon though to see the differences.
I did switch between I and S# modes to compare and the max torque is the same but the max whp is down by 10.
60mph-80mph: 3.01 secs
50mph-80mph: 4.20 secs
3rd gear maxes out at 83mph.
Old 07-19-2010, 04:48 PM   #665
Linkseal
Member#: 102329
05 AW Piggy Gone
11 SP TOM'S IS-F
Yes please do the 4th gear pull on S## mode, prepare for about 9~11 secs accel. time,
and you will hit 175km after the pull since GRB has the same gear ratio as 07 STi.
Have fun and good luck.
Old 08-06-2010, 02:19 AM   #666
clarkbw
Member#: 215473
2004 Stg 2 WRX
Got my car back from RR last week. Looking good for a 2004 WRX with 100K miles on it. Running a Dom 1 Turbo and APS FMIC and a bunch of other goodies.
Next I need some go straight and stop fast parts from Dales. In a 3rd gear pull I kind of feel like I'm slalom water skiing.
clarkbw is offline   Reply With Quote
Old 08-06-2010, 06:45 AM   #667
ShadowDancer
Member#: 57441
07 STI
CGM
^ Beautiful~
Might want to take it ez on your 5speed though.
ShadowDancer is offline   Reply With Quote
Old 08-06-2010, 09:58 AM   #668
tora
Member#: 5851
09 Forester XT
+ NA Miata
Nice HP, If you eventually go to a 2.5 block you could get those torque numbers closer..
tora is offline   Reply With Quote
Old 08-06-2010, 10:26 PM   #669
420WRX
Member#: 27752
Didn't someone say that a Dyno plot where the axis aren't crossing at ~5300 RPM is broken?
Why are they crossing at 1000RPM less on the plot above?
Old 08-06-2010, 10:30 PM   #670
tora
Member#: 5851
09 Forester XT
+ NA Miata
Look at the torque/hp numbers on the side....they are not even.
Old 08-06-2010, 11:16 PM   #671
420WRX
Member#: 27752
Ahh.. I knew that .. years ago. Getting old sucks.
Old 09-21-2010, 11:42 AM   #672
sandman21_21
Member#: 152118
1999 RBP 2.5RS Sold
1998 RBP WRX swap XO GC
Hi all,
A few of you are aware that I have been planning to do a little work on my car on the power end of things. I brought my car down to Maxwell Power Services in Arlington because I had heard many good things about Dom and his crew from both the NWIC and the VIC boards. I definitely was not disappointed.
Graph:
Mods:
WRX drivetrain
Blouch 16g-xt turbo with PNP
Modded WRX injectors
Walbro fuel pump
CSS large TMIC
RR Catless Up-pipe
Agency Power Headers
Maddad 2 piece - Catted Downpipe
3"--> 2.5" intermediate pipe with Prodrive oval-tip axleback
Perrin PWI-1 Meth injection (50/50)
Stock box with K/N filter & Zerosports Intake elbow
Dom Tune
sandman21_21 is offline   Reply With Quote
Old 09-21-2010, 11:50 AM   #673
dsmtowrx
Member#: 48879
2010 STi 2.5xtr hsf6
Grey Stocker
Romraider?
dsmtowrx is offline   Reply With Quote
Old 09-21-2010, 11:57 AM   #674
sandman21_21
Member#: 152118
1999 RBP 2.5RS Sold
Not sure what program Dom uses, but it is open source.
Old 09-21-2010, 12:03 PM   #675
dsmtowrx
Member#: 48879
Grey Stocker
Sweet. Hoping to go see him shortly
I-Club/NASIOC: BC Member's Car Pics Happy_Days Vancouver Impreza Club Forum -- VIC 7965 07-19-2016 06:09 PM
Need Members' Help - Salvage Vehicle Keenan Southern California Impreza Club Forum -- SCIC 5 06-09-2008 05:42 PM
New High Score on our Dyno 415.8 whp WHITE GF8 Proven Power Bragging 7 08-12-2005 02:05 AM
2002 Headwaters Club Rally Stage Scores jmullan Motorsports 0 05-13-2002 03:46 PM
Dyno results posted from NW i-club Dyno Day! sponaugle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 06-04-2001 10:30 PM
