Old 11-28-2005, 01:50 AM   #1
Blown95ImpalaSS
Member#: 87629
Default Weird boost gauge readings or too much boost in the cold?
Ok, so I hit it in 4th gear at about 50 miles per hour. The revs climb and the boost guage (stock) reads over .12 bar at then backs doown quickly to ~.8 bar then rises again to ~.1 bar. I tried it again in 4th and 5th gears, the boost gauge did the exact same thing. When this happens it feels like the car hits brick wall and does not accelerate normally until boost has finally fallen. This only happens in the cold weather and in the upper gears...what the hell is it? How do I get rid of it and hold boost smoothly in the upper gears?
Thanks,
ben
p.s. can anyone give me a whp range for my car as it sits with these mods?
02 wrx wagon
uppipe, tbe/high flow cat, k&N typhoon intake, ecutek tune.
Blown95ImpalaSS is offline   Reply With Quote
Old 11-28-2005, 11:44 AM   #2
BoostinEJ20
Member#: 73710
whp id guess around 230-240 with that setup.
BoostinEJ20 is offline   Reply With Quote
Old 11-28-2005, 12:09 PM   #3
KingOfSiam
Member#: 84636
2005 WRX (automatic)
Crystal Gray
That much boost on stage II isn't too much, I'd just be worried about the that it's not steady.
KingOfSiam is offline   Reply With Quote
Old 11-28-2005, 06:34 PM   #4
Blown95ImpalaSS
Member#: 87629
There is definitely something wrong. Just tried it again (4th gear) on my way back from class and boost rises then falls sharply then peaks again. *** is going on? Help?
ben
Old 11-28-2005, 11:24 PM   #5
Blown95ImpalaSS
Member#: 87629
Anybody out there? Should I take the car back to my tuner or something? Am I hitting fuel cut??
ben
Old 11-29-2005, 11:52 AM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
take it back to the "tuner" and tell them their boost control tuning isn't worth crap.
i just love all these posts that pop up when the winter comes. i feel sorry for you, ben, cuz it isn't your fault. how much did you pay for that tune, i have to ask?
Old 11-29-2005, 12:56 PM   #7
REX8
Member#: 24038
My boost started fluxing too when it got cold out. Stock EM and with both a TXS and Vishnu Unichip. Not really wure what it is, but I'm trying to work it out.
Old 11-29-2005, 01:14 PM   #8
dgp2003wrx
Member#: 60955
2003 wrx
blue
the cold will do that...when it was summer mine would sometime peak at 17-18 psi, with stock turbo(which i know is not good) but now that its winter it peaks at about 20, but i dont get on it enough to see that kinda boost when the snow hits so it doesnt bother me too much, and if the turbo blows oh well...
dgp2003wrx is offline   Reply With Quote
Old 11-29-2005, 04:05 PM   #9
Blown95ImpalaSS
Member#: 87629
So this is an issue that is not an isolated incident. I payed for my Ecutek license and the tune which came to about $700, but I am afraid a new tune will cost about $200. It only happens when temps reach below 40 degrees, I guess I'll just keep out of the throttle until it warms up. Anyway, if I blow the turbo its a valid excuse to do a vf30 swap
Thanks for all the help,
ben
Old 11-29-2005, 04:26 PM   #10
neversatisfied
Member#: 42631
03 Subaru WRX
Silver T67 equipped
Lower temperatures might have something to do with it. I know some car's ECUs allow for more boost with cooler intake temps like my SRT-4 does. It definitely sounds like you are hitting fuel cut though. Its not a good idea to put a load on your car in higher gears just for future reference. When you do that your EGTs have got to be going through the roof.
neversatisfied is offline   Reply With Quote
Old 11-29-2005, 07:12 PM   #11
rugbywrx03
Member#: 57703
08 STi
Denser air = more boost. Cold air is gonna make your ecu have to adjust a lil more than usual. Mine does the same thing but its not a big deal. Be happy the air is cold, your turbo is.
rugbywrx03 is offline   Reply With Quote
Old 11-29-2005, 07:15 PM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
it is not "isolated," but that doesn't make it right, or normal.
How much is too much play in the shaft?? wr-ecks Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 01-11-2016 11:43 AM
do you spend too much time in the OT? gc822 Off-Topic 22 09-14-2005 04:44 PM
Too much O2 in the gas..... plexrex Mid Atlantic Impreza Club -- MAIC 6 03-16-2004 04:22 AM
Too much fun in the snow (donuts) see pictures cky211 North West Impreza Club Forum -- NWIC 9 01-08-2004 03:29 PM
Too much fun in the mud? ImpSP Normally Aspirated Powertrain 4 06-10-2003 09:57 PM
