Old 11-28-2005, 02:19 PM   #1
LathanM
Member#: 90486
2004 WRX
WR Blue
Question Reading wiring diagrams before installing?
I know alot of the knowledge in this area comes from trial and error for example finding the correct fuse size for a particular wire, amp mounting or sub box building but what about the rest, remote turn on leads, enable/disable switches and relay connections. Does anyone actually look at and understand the wiring diagrams before installing new electronics in their car?
LathanM is offline   Reply With Quote
Old 11-29-2005, 04:18 PM   #2
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Correct fuse size for a particular wire should NOT come from trial and error!
As for the answer to your question, although it should be "yes", all too often it's "no".
Old 11-29-2005, 04:28 PM   #3
ekw
Member#: 92141
2004 STi-WRB on gold
Street prepped by TiC !
cannot recommend this site strongly enough:
http://www.bcae1.com/
ekw is offline   Reply With Quote
Old 11-30-2005, 12:00 AM   #4
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
The only time I look at diagrams is when I'm dealing with funky relays.
IE any subaru ground switched anything.
This goes for my headlight relays, foglight switch and my hella supertones relay.
It's just a PITA to keep that all straight in your head. I draw it all out.
As for standard stereo wiring...that's just simple + and - stuff.
-- Dave
AcquaCow is offline   Reply With Quote
Old 11-30-2005, 07:31 PM   #5
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
-- Dave
I bet you use the HU connector wiring pinout diagram...
Make sure to double-check wiring diagrams before soldering... El Camino Off-Topic 5 11-19-2009 11:07 AM
Wiring Diagram Question - What am I reading?! XanRules Electrical & Lighting 0 03-18-2009 08:25 PM
Looking for JDM V7 wiring diagram and '01 RS wiring diagram moss Subaru Conversions 1 07-06-2006 10:52 PM
Wiring diagram 98 RS or TC2 install for a '98 fabulous12 Normally Aspirated Powertrain 12 12-26-2001 10:35 PM
Installing FogLights (continued from Elec. Wiring Diagram Request of 7 June) Bob OM,Md Technical Forum Archive 4 06-12-2000 05:13 AM
