Old 11-28-2005, 03:28 PM   #1
njskatchmo
Member#: 94618
2002 Bugeye
Default Time for an oil change.
I'm running synthetic.
What do you guys suggest,
Having subaru do it?
Small mechanic?
Do it myself?
The only reason I'd want a mechanic to do it is so I'd have the receipt in case I want to sell the car. Should I just keep the receipt for the Oil and write the mileage on it?
njskatchmo is offline   Reply With Quote
Old 11-28-2005, 03:46 PM   #2
ludecrous
Member#: 19376
2003 03 WRX Wagon
do it yourself. cheaper & good experience
ludecrous is offline   Reply With Quote
Old 11-28-2005, 04:12 PM   #3
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
Do it yourself. It is extremely easy and you'll know everything that happens during the change. I wouldn't trust my car to someone else anyway.
bl_easy is offline   Reply With Quote
Old 11-28-2005, 04:14 PM   #4
Synacr0n
Member#: 90681
98RS w/07 WRX swap!
02 WRX to 04 STi to swap!
do it yourself....that way you are SURE that the crush gasket is changed.
Synacr0n is offline   Reply With Quote
Old 11-28-2005, 04:20 PM   #5
005sti
Member#: 78293
DP stockcatbckpro-
tune301wtq 289.7whp 93oct
keep records on my.subaru.com and do it yourself. I use "Q" quaker state 10w-30 fullsynthetic. Since the switch, my oil consumption is negligible. Although, that may also be partially explained by the additional (break-in) mileage... plus, it's cheaper than ams oil lucas, etc.
005sti is offline   Reply With Quote
Old 11-28-2005, 04:25 PM   #6
ludecrous
Member#: 19376
2003 03 WRX Wagon
crush gasket, yeah I know your supposed to changed em, I put a fiber one on there and used it for the last 4 changes and not a drop of oil.
Old 11-28-2005, 05:30 PM   #7
Scoobie Noobie
Member#: 65498
Another vote for DIY - it's cheaper, it's easy and it's fun.
Spend some quality time with your Subie!
BTW - I use a new crush washer at every change. It may not be necessary but why take a chance on a leak and having to drain all your brand new oil?
87 cents and I don't have to worry about it.
Scoobie Noobie is offline   Reply With Quote
Old 11-28-2005, 05:45 PM   #8
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
I get my oil change done free at the dealer... so I go to the dealer...
otherwise I would do it myself (do NOT go to jiffy lube or any other quick oil change crap.... they ruin cars)
sizzflair is offline   Reply With Quote
Old 11-28-2005, 05:55 PM   #9
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
do it yourself.
volkl23 is offline   Reply With Quote
Old 11-28-2005, 06:43 PM   #10
2fas4u
Member#: 90691
2005 STI / 2009 STI
I wouldnt trust anyone else to do mine. Its not that big of deal to do....
2fas4u is offline   Reply With Quote
Old 11-28-2005, 07:01 PM   #11
makanai
Member#: 65277
2004 WRX Wagon
Platinum Silver
I would, and have, trusted someone else to change my oil (including Jiffy Lube type places). I've never had a problem. That being said, I would still suggest doing it yourself. It's not hard, it's good to know how to do it, and it's dirt cheap, especially if you like to run synth.
MAK
makanai is offline   Reply With Quote
Old 11-28-2005, 10:05 PM   #12
njskatchmo
Member#: 94618
2002 Bugeye
Ok, so lets say im oing to do it. What do i need to buy, ie how many quarts of what weight oil, oil filter, this gasket thing? anything else?
Old 11-28-2005, 11:25 PM   #13
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
DIY
you will become more confident doing work on you own and will end up saving alot of money by doing your own tune ups, as they are not hard.
Check your manual for oil capacity with filter change.
Kawikid20o2 is offline   Reply With Quote
Old 11-28-2005, 11:30 PM   #14
ShortThrow
Member#: 92607
i too havent changed my crush washer in 3 changes, havent noticed any leaks, also my manual says 4.8 quarts but i just put in 5 and it worked fine.
ShortThrow is offline   Reply With Quote
Old 11-28-2005, 11:45 PM   #15
newrxonr
Member#: 100647
2005 WRX Wagon
Black (sadly, no longer)
njskatchmo,
Check out the section on oil in the unabombers manifestor in the FAQ section. There is a ton of info on all things oil, including links which will take you through the WRX oil change process step by step and explain exactly what equipment you'll need. Good luck, you won't need it. As long as you have opposable thumbs you'll be fine.
newrxonr is offline   Reply With Quote
Old 11-29-2005, 02:38 AM   #16
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
I found this secret book in my glove box that tells all kinds a neat info, like 4.8 quarts of 5W30 oil. I bet your car has one, take a peak.
You can also hit up the dealership and get all the stuff you need there, like filter and copper washer, barring the oil which you get at a parts store. I haven't changed my copper crush washer in about five oil changes with no ill effects. If all this scares you, and you want it to stop scaring you, change your own oil.
Goodluck
specialev is offline   Reply With Quote
Old 11-29-2005, 02:50 AM   #17
nick04263
Member#: 68799
2004 WRX COBB STG 2+
another vote for doing it yourself.
nick04263 is offline   Reply With Quote
Old 11-29-2005, 03:22 AM   #18
ALaDDiN
Member#: 98294
2004 Honda Civic
2006 Acura TL
Do it yourself ! ! Why have some people gone from 5w30 to 10w30 ? ?
Also, I cant seem to find Mobil1 5w30 synthetic ANYWHERE. I checked out the local pepboys AND walmart lol any other brand reccomendations ? ? What about the filter ?
ALaDDiN is offline   Reply With Quote
Old 11-29-2005, 03:29 AM   #19
spongejosh
Member#: 62783
Midnight Black Pearl
a lot of people that were noticing oil consumption switched from 5w to 10w and it all but stopped the dissapearing oil, mobil 1 5w is just too thin for some engines.
josh
spongejosh is offline   Reply With Quote
Old 11-29-2005, 03:30 AM   #20
akinasdevil
Member#: 61050
2004 STi
72 Corona
Do it yourself, if you want to keep record get a small 3x5 notepad and you can write everything down. That's what I do that way you know when the next one is due and if you want to sell the car there are your records right there.
akinasdevil is offline   Reply With Quote
Old 11-29-2005, 04:23 AM   #21
porter_mann
Member#: 87148
you should change your own oil. For the cost of service, you could buy some pretty high end oil and change it yourself. There's nothing hard about it. You just have to dedicate a little bit of time.
I change my oil with 5w-30 Redline. Its a good quality synthetic oil, that sort of spendy. But when I calculated it out. If I changed it myself, its the same price as if I went to Jiffy-lube or other and had them change the oil with whatever generic stuff they use.
And, I know its done right - something that even money can't pay for sometimes.
porter_mann is offline   Reply With Quote
Old 11-29-2005, 04:48 AM   #22
fusionlude
Member#: 98168
2007 Impreza WRX
Satin White Pearl
do it yourself..more fun!
fusionlude is offline   Reply With Quote
Old 11-29-2005, 04:51 AM   #23
shemoves
Member#: 80663
2005 STi
Def do it yourself and keep reciepts. I used mobil 5w30 full synth...it sheared out noticably after 2k miles. My suggestion is GC (german full synth castrol 0w30) or Redline.
shemoves is offline   Reply With Quote
Old 11-29-2005, 07:17 AM   #24
Tragedy
Member#: 19011
Y34 Gloria
Is Synthetic really necessary? I spoke with several Subaru mechanics in Japan when I was living there, and they all said synthetic is a waste of money.
Tragedy is offline   Reply With Quote
Old 11-29-2005, 09:04 AM   #25
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
josh
ding ding ding! winnar!
I run subaru's castrol synth blend in the RS, 105k miles & going strong
i run a completely different setup in the race car, but it's a bloody race car
synth is NOT necessary
a synth blend will cause less friction, cost 1/3rd as much
and keep your running/performing just fine
fyi... i do my oil changes m'self as well
i like to use that time to inspect the rest of the car
Jamie
went for an oil change and left with an exhaust leak? SpeedShift Normally Aspirated Powertrain 14 11-18-2009 12:21 AM
car starting to eat mobil 1 and its time for an oil change prometheum Alaskan Impreza Club Forum -- AKIC 42 05-16-2007 05:41 AM
How many quarts of oil for an oil change? codemunky Service & Maintenance 9 07-30-2002 06:35 PM
Time for first oil change... REZA Bay Area Impreza Club Forum -- BAIC 7 09-04-2001 10:03 PM
Time for an oil change Skirvdawg New England Impreza Club Forum -- NESIC 3 03-07-2001 12:36 AM
