Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 11-28-2005, 06:25 PM   #1
Member#: 5778
09 135i
Jet Black
Default Hydra Question.
Does anyone know if the Hydra has an input for an External map sensor?
I know it comes with the 3 bar sensor built in, but I think I'm going to need to run a 5 bar sensor.
STiTuner is offline   Reply With Quote
Old 11-28-2005, 06:56 PM   #2
Member#: 84772
2005 GDB STI
Unfortunately there is no external output. The on board is a 3 bar sensor. I also looked into this as I didn't want to run the vacuum line into the cabin, but nevertheless ran it as recommended by Phil and Hydra EMS.
Hope this helps.
syoung0298 is offline   Reply With Quote
Old 11-28-2005, 07:19 PM   #3
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
I wouldn't bother up to about 35 psi but if you want to run 36+ psi then yes you can wire in an external 5 bar map sensor and configure the Hydra to recognize it.
Keep in mind this will require significant remapping of the fuel and spark tables.
Element Tuning is offline   Reply With Quote
sti swap and hydra question rooobaru Other Engine Management 4 08-12-2008 08:12 AM
some gen hydra questions gthurin Other Engine Management 10 06-08-2007 09:53 AM
hydra question Paintballguy Other Engine Management 3 12-29-2006 04:52 PM
Hydra questions swordmaster Other Engine Management 15 08-08-2006 09:52 AM
Hydra question (1st of many) rjrutzky Other Engine Management 6 08-29-2005 07:03 PM
