Old 11-29-2005, 02:08 PM   #1
luis_ej20t
Member#: 101303
Default Stalling Problem
I had a quick question. I have a Stage 2 flywheel and a Stg2 clutch and since iv'e installed it my car has been stalling alot and I have miss fires on all 4 cylinders. Does anyone have any idea why or can help.
luis_ej20t is offline   Reply With Quote
Old 11-29-2005, 02:38 PM   #2
HighRevimpreza
Member#: 90235
1993 GC ej255 swap
hey guys correct me if im wrong. when you upgrade your clutch and flywheel dont you need to get a new transmission since your car reponse is much quicker with the lighter flywheel installed.
HighRevimpreza is offline   Reply With Quote
Old 11-29-2005, 03:25 PM   #3
2fas4u
Member#: 90691
2005 STI / 2009 STI
Wha??? Um no.... You heard wrong. The extremely lightweight flywheels are known to cause CEL lights because they are too light and it messes up the sensor timing....
2fas4u is offline   Reply With Quote
Old 11-29-2005, 03:58 PM   #4
HighRevimpreza
Member#: 90235
1993 GC ej255 swap
ooo. so having a close ratio transmission is not needed if you replace your flywheel?
Old 11-29-2005, 08:02 PM   #5
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
member numbers rise, board iq lessens
overdose is offline   Reply With Quote
Ideas on stalling problem? BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-04-2003 09:22 AM
Compressor stall problem I think. Also, is there a such thing a wastegate slap? knuckles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-19-2002 07:28 PM
Stalling problem... Daveish Normally Aspirated Powertrain 3 11-29-2001 05:53 PM
stalling problems jbdesros Normally Aspirated Powertrain 7 09-17-2001 01:44 PM
Stalling Problems with MY98 RS Turbo yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 24 08-29-2001 10:37 PM
