Old 11-30-2005, 07:08 AM   #1
garie
Member#: 26607
2002 wrx wagon
Default question about pcv valve-Instead of replacing just soak in cleaner?
I was wondering if it would be possible to just clean the pcv valve in brake cleaner or something instead of replacing it?
The whole point of replacing it is because it may get clogged.......?
garie is offline   Reply With Quote
Old 11-30-2005, 09:50 AM   #2
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Never heard of that but why bother? A new one is only a few bucks.
Mike Wevrick is offline   Reply With Quote
Old 11-30-2005, 12:09 PM   #3
orndog
Member#: 34670
2013 No gears!
Saltine American
It can be done I suppose, we used to all the time on older cars.
Some issues I have:
Corrosion of metals and deterioration of plastics, why not just replace?
Knocking bits loose but not out, so they enter your engine later.
Once you go through the trouble of removal, why just clean such a cheap part?
orndog is offline   Reply With Quote
Old 11-30-2005, 12:34 PM   #4
2fas4u
Member#: 90691
2005 STI / 2009 STI
They are only $9, why not just replace it?
2fas4u is offline   Reply With Quote
Old 11-30-2005, 10:23 PM   #5
garie
Member#: 26607
2002 wrx wagon
^^haha I am cheap? I have replaced it before but I remember last time as I was checking out the old one I thought about this(what I posted) because it seems the only moving part in it is a ball to allow the air to move only in one direction.
my 60k is coming up and I don't really want to order a pcv valve just by itself+shipping.
Old 11-30-2005, 11:58 PM   #6
Charge
Member#: 3313
Order a PCV Valve? You don't have an auto-parts store nearby? I just picked one up at an Autozone. I think it was $2.95. There's no reason to spend extra money to get one direct from Subaru.
Charge is offline   Reply With Quote
Old 12-01-2005, 09:32 PM   #7
garie
Member#: 26607
2002 wrx wagon
^^you are right. I have thought about that before but never looked up to see which part fits. I'll check them out next time I got to autozone/pepboys...
Question about race pipe instead of cat begbudii Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-22-2009 03:38 PM
Question about PCV change for 2004 WRX QwikRex Service & Maintenance 11 10-12-2008 10:56 AM
Question about PCV valve... SPECTRE2099 Newbies & FAQs 2 01-05-2007 02:38 AM
Question about the valving of KYB AGX's... GooseMan Brakes, Steering & Suspension 4 03-22-2002 12:35 PM
Needle valve instead of restrictor hose observations PunksWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 37 11-24-2001 12:31 PM
