Old 11-30-2005, 01:32 PM   #1
The_Urban_Knight
Member#: 78955
2005 STi
Default About to get the SMC Injection Kit- Run with Meth or Alcohol?
My SMC kit arrives tomorrow. I have read the few threads, but my question now is what do I get setup and tuned for?
I am not really worried about the cost, I want the best performance.
SO, with that in mind, do I get Methanol (where do I buy it), Denatured Alcohol, or 50/50 Denatured and water, or???
This is going on my05 Sti with the following:
Last dyno(11/26) with Cobb Stg 2 (untuned) I ran 280 whp/300 Tq on a mustang AWD dyno with the following mods:
> Cobb Ap Stg 2 93 Octane Base and Realtime Map
> Maddad V2 Catted Downpipe
> 3" Ultimate racing exhuast
> Stock airbox with hacked snorkus, drop in K&N
> Perrin Crank Pulley
> Static X Grounding kit (just in case it added 10
> hp!)
I am hoping that with the SMC kit and a AP Protune from Topspeed to hit >300whp and >325 tq on the mustang dyno. Seems reasonable right?
Thanks Guys!
UK
The_Urban_Knight is offline   Reply With Quote
Old 11-30-2005, 02:47 PM   #2
powerleak
Member#: 72571
04 STI
i have close to 15k miles running straight denatured alky between an fp green and an sz60. methanol was too corrosive for my liking. i know there are many here that run 50/50 because of the fear for an engine fire... which reminds me, i need to get a fire extinguisher.
what made up my mind was asking steve from smc what he runs... 100% denatured alcohol.
you can buy it at any paint store (also called shellac remover) or hardware store. out here in cali, i get it for about $10/gal from ace hardware.
powerleak is offline   Reply With Quote
Old 11-30-2005, 11:04 PM   #3
mindchatter
Member#: 36447
Heav en for the weat
her & Hell for company
I run a 50/50 blend of denatured/distilled water. I had a difficult time sourcing methanol, whereas alcohol is widely available, making road trips less of a hassle. I run a a 50/50 blend because it provides stellar detonation resistance at roughly 1/2 the cost of straight alcohol or methanol, isn't readily ignitable (see below), and I believe the H20 content cools/steams/cleans the internals while the alc/meth acts as race gas on demand - the logic/science behind it seems sound to me over running an add'l straight fuel spray. Water's octane rating is infinite, after all.......
I used the washer bottle resevoir, and wouldn't want straight alcohol/meth under the hood. The kit's well put together, but all the same.....50/50 won't catch fire if you hold a flame to it. For the performance difference between running straight alc/meth (if there is one) over water I chose the peace of mind of knowing there wasn't a potential fireball sitting next to my engine.
Good luck with the kit - I think you'll be very pleased with the results. I've got over 5k on my ride with it so far and have nothing but good things to say......I put down the #'s you see at left at 21psi on a DynaPack dyno on a 60 degree humid day with the 50/50 blend FWIW.....I think your # guesstimate sounds about right, although Mustangs are known to be disappointers......either way you'll be far better off than without it. My .02.
Edited to answer mod query: XX Tuning headers, Typhoon short ram, Hyperflow V2 tmic, SMC kit, APS SR40, PDE catted d/p, Borla Hush, UTEC
mindchatter is offline   Reply With Quote
Old 12-01-2005, 02:52 PM   #4
Garageless
Member#: 57263
2004 STi
^^what other mods do you have?
Garageless is offline   Reply With Quote
Old 12-01-2005, 04:11 PM   #5
Jasper
Member#: 80136
2006 Ford F-150
my buddy uses alcohol, but thats just because we can get it free @ work
either or will work, just dont forget to add a lubricant if you use methanol
Jasper is offline   Reply With Quote
Old 12-01-2005, 07:14 PM   #6
aprazma
Member#: 77619
2009 Cayman S
What is the performance difference between running straight alc and 50/50? What is the best psi to start spraying?
aprazma is offline   Reply With Quote
Old 12-01-2005, 07:27 PM   #7
powerleak
Member#: 72571
04 STI
mine is set to start spraying at 12psi and with maximum around 20psi.
my car is tuned for straight alky but i have used a 50/50 mix twice. i honestly could not tell the difference in the butt dyno. the engine just seemed to rev a little rough kind of like when you're overdue for an oil change if you've ever experienced that... didn't feel as smooth. hopefully someone here will post that has actually logged the differences.
Old 12-01-2005, 08:34 PM   #8
Davenow
Member#: 23676
The reason it didnt pull as smooth is because you would need to modify the tune a touch for the different spray.
Old 09-30-2006, 08:47 PM   #9
east milford wrx
Member#: 102301
If you were tuned for 50/50 meth and water could you switch to 50/50 water and denatured alcohol without problems?
east milford wrx is offline   Reply With Quote
Old 09-30-2006, 09:40 PM   #10
dibblejr
Member#: 94070
05 LGT
50/50 Alky Water I run 26 lbs boost (safe) when on the juice.
dibblejr is offline   Reply With Quote
Old 09-30-2006, 09:42 PM   #11
dibblejr
Member#: 94070
05 LGT
You should get at least 4 maps if you want to swith.
1) Whatever Oct Gasoline you use only
2) Alky/water
3) Water/ Meth
4) Straight Water
Then you can switch with whatever you have running at the time.
Jay-R
Old 09-30-2006, 09:45 PM   #12
living4surf
Member#: 85216
there is a place in west palm beach that sells meth and it is what i have used to a while but when i get tuned next i will be going with 50/50 meth water
living4surf is offline   Reply With Quote
Old 09-30-2006, 09:49 PM   #13
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
alchy has much more energy content than Methanol. The name isn't as cool, though. Meth just sounds so much more edgy than Eth.
But Eth will produce more power. And less damaging to plastic parts. And less poisonous.
Zornorph is offline   Reply With Quote
Old 10-01-2006, 09:07 AM   #14
hippy
Member#: 36528
2002 Impreza Wrx
Yes I could, and I have. I would know at the same time that I might run into knock problems(or something), and to be on the lookout. It would obviously be optimal to get tuned for the setup, but there's such a little difference between meth and eth that I don't think there would be any problems. I haven't had any problems switching the mixes on my 100% water tune, but that might just be from it not being tuned very agressively. If there are problems(like knock) after switching, it might be a good idea to try add a bit more water to the mix(or get tuned obviously). I say this cause I think meth cools better then eth, and that extra water might make up the difference.
peace
Old 10-01-2006, 12:32 PM   #15
InfamousDX
Member#: 25413
What size nozzle are you guys running?
Old 10-01-2006, 02:12 PM   #16
hippy
Member#: 36528
2002 Impreza Wrx
The max flow of my nozzles should be about 7gph. I'm pretty sure that I max out at about 5gph. Setup is, 02wrx, 18g, 23ish psi at 12.5 to 1 a/f ratio and my injection mix is 100% water.
peace
How to Get an Accurate Baseline Dyno Run with an Aftermarket Boost Control Solenoid? grenade Engine Management & Tuning 5 03-14-2007 07:49 PM
Where to get the OEM underspoiler kit unpainted? SpecK Bay Area Impreza Club Forum -- BAIC 3 12-18-2003 11:02 PM
Does anyone know a place to get the OEM body kit pre-painted MPB? krazedant Interior & Exterior Modification 5 08-05-2003 09:41 AM
Where to get the morrette body kit? 42202sub Interior & Exterior Modification 6 09-19-2002 11:57 AM
