Old 11-30-2005, 06:15 PM   #1
KitchenerWRX
Member#: 79934
02 WRX
MBP
Default high egt's from running rich?
I know when you are lean you get high egt's but i just heard that you can also get high egts from running way too rich? can some one explain this?
KitchenerWRX is online now   Reply With Quote
Old 11-30-2005, 06:39 PM   #2
KitchenerWRX
Member#: 79934
02 WRX
MBP
bump.
Old 11-30-2005, 06:58 PM   #3
flyboymike
Member#: 83765
2005 WRX wagon
WR Blue
I don't know what a rich condition would do to your EGT, but I do know that high EGT's are often a sympton of running lean. Evaporating fuel helps cool the engine. Therefore, when you don't have enough fuel, your EGT's go up. I would assume that running rich would do the opposite, but I don't know for sure.
flyboymike is offline   Reply With Quote
Old 11-30-2005, 07:06 PM   #4
KitchenerWRX
Member#: 79934
02 WRX
MBP
dude i know that already!
Old 11-30-2005, 07:09 PM   #5
boxerboy
Member#: 80976
what are you saying?
boxerboy is offline   Reply With Quote
Old 11-30-2005, 07:10 PM   #6
KitchenerWRX
Member#: 79934
02 WRX
MBP
read the first post
Old 11-30-2005, 08:22 PM   #7
clamdip
Member#: 18709
i don't think this is possible. it all depends on what load point you're referring to. running rich is a way to suppress detonation due to high cylinder pressure or in other words too much of a bang. as a reference, at 7K my egt's are at/around 800*C and i know i'm dumping a whole lot of fuel (running rich). so i guess yes, you can still run rich and have high egt's, but this is in reference to load point. at a less load, i don't think it's possible to run rich and have high egt's, unless it has something to do with timing, but that would just contribute to the loss of power in most cases.
clamdip is offline   Reply With Quote
Old 11-30-2005, 09:35 PM   #8
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Your exhaust gas temperature will be hottest at some point slightly "richer" than the stoichiometric point because that is where you are burning the most gasoline (for gasoline, that is 14.7).
You have to realize that "rich" and "lean" are relative terms, meaning simply "more" or "less" fuel than desired at a particular point. If you should be running 14.7 (low load highway cruise) and for some reason you are actually running 14.0, chances are your EGTs will be high.
Another thing that drastically affects EGT is the timing. If the spark is too 'retarded' (meaning happens too late), the mixture will be burning much later in the engine cycle and some of this later burning will make your EGT gauge read higher.
Now, if you consider the normal "turbo tuning" use of the words "rich" and "lean", you might consider "rich" to be somewhere in the range of 10:1 and "lean" somewhere in the range of 12.5:1. If this is your frame of reference, running richer will NOT make you run hotter. All that extra fuel is soaking up the heat and making your EGT gauge read lower.
nhluhr is offline   Reply With Quote
Old 12-01-2005, 01:28 AM   #9
KitchenerWRX
Member#: 79934
02 WRX
MBP
thanks for the responses guys but they keep insisting that the more fuel the more combustion and then the more heat???
the only thing i can think of is an antilag system that dump fuel in - but when the throttle is closed....
Old 12-01-2005, 01:43 AM   #10
nimblegimbal
Member#: 91120
06 WRX ImpWag
Batmobile Black
I've also heard of this... iirc, it was being said that if you go way too rich, ie further than 10 afrs, you can also get high egts...
nimblegimbal is offline   Reply With Quote
Old 12-01-2005, 02:40 AM   #11
icantdrive75
Member#: 69663
2004 WRX
Java Black Pearl
The reason hot rodders put in lower temp thermostats is so that the ECU will run in "warm-up" mode and fatten up the motor(richen the mixture). So, following logic, if the computer richens the mixture to warm up the motor, more fuel will give you a warmer motor.
But more commonly, high EGT's mean a lean motor.
icantdrive75 is offline   Reply With Quote
Old 12-01-2005, 03:19 AM   #12
Davenow
Member#: 23676
100% possible, and happens all the time. Although its USUALLY lean that does it, it can still happen when rich.
One common cause is when the timing is too far retarded causes the mix to not be far enough into the burn when the exh valve opens, which = higher EGTs
The reason that happens is people see some knock, and instead of figuring out what is going on, they automatically throw fuel at the knock, when the entire reason they saw knock was a rich misfire condition. So then the extra fuel doesnt fix it, so they start yanking timing. But it still misfires, and they see the flash, which makes them think knock (it CAN be knock as well) so they yank MORE timing.
Or it could just be that the map is a poor match for that car, and has a combination of too much fuel and too little timing...
Old 12-01-2005, 03:35 AM   #13
supermarkus
Member#: 6971
2008 WRX STi
SSM
Sounds like a good recipe for pre-ignition.
supermarkus is offline   Reply With Quote
ej207 v5 swapped from vf28 to vf34 not runs rich @ idle impreziv25 Subaru Conversions 6 05-24-2007 05:46 PM
Damage from running rich? Petrus General Community 16 04-16-2006 01:27 AM
Got back from dealer, now running rich!! Javier Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-17-2005 12:29 PM
Running rich- very rich Hondaslayer Normally Aspirated with bolt-on Forced Induction Powertrain 19 04-12-2003 09:11 PM
can't stop running rich from RRFPR HubbieScooby Normally Aspirated with bolt-on Forced Induction Powertrain 6 06-28-2002 08:55 PM
