#1 |
Member#: 101892
Vehicle:2002 WRX wagon blue |
Suby dealer in Columbus, GA says it takes three hours to install new spark plugs. The platinum plugs alone are like $64+ I seriously doubt it takes that long, or that the labor should cost that much. Are these guys just after some easy $$ or what?
#2 |
Member#: 66563
Vehicle:2002 Impreza WRX WR Blue Pearl |
have you looked at how the engine in your car is orientated. It's a PITA to get to the plugs due to the boxer engine design. Its not like any other engine where the plugs are right on top. You have to get down into the sides of the engine bay to change plugs
#3 |
Member#: 101892
Ah, I did notice...they're hard to even see from above. What do you think, can an amatuer do it? Or, should I take it in? The cost isn't that great of a concern, and I would like the car to continue to run well for at least another 80K miles. I thought that the stock platinum plugs were supposed to last a long time though, like up to 100K. I know it's recommended at 60K, but so far I haven't experienced any problems, but I know nothing about the ignition.
#4 |
Member#: 67398
South East
Vehicle:2002 Now with 100% RDA of 2.5l Goodness!!! |
DO NOT pay them to do it. EVER. Buy the plugs yourself, gap them and install yourself. It's tedious and at time a PITA, but not technically difficult. If you can turn a wrench you can do it. Run a search for spark plug install. Scoobymods.com has good instructions too.
The Cliff's notes install requires this: Remove airbox, battery and washer bottle. Remove 12mm bolts holding the coilpacks on the plugs. Slide coilpacks off. Remove spark plug with rachet extension(s). Apply a bit of dielectric grease to the end of the plug the coilpack goes on. CAREFULLY thread the plug back in, taking care not to crossthread. Coilpack will slide on but will not give you a reassuring click. Replace 12mm bolts securing coilpacks. Reassemble airbox, washer bottle, and replace and connect battery. Profit ! $$$$$$ |
#5 |
Member#: 38338
Vehicle:2003 Outback Sdn H6 Black |
it's very easy. in no way is it worth $280 to have someone else do it.
#6 |
Member#: 10309
NWIC
Vehicle:'02 OBS 2-tone! '95 Montego Miata |
On the WRX, 60k is a good time to change the plugs. It's not trivial, but is certainly doable for an amateur. Especially your first time, you need to be patient, and make sure you have all the correct tools in advance (like a plug socket of the correct size). A friend/acquaintance who has done it before is *extremely* helpful.
Don't forget to use a bit of anti-seize on the plug threads. If you don't feel comfortable doing it, you can also have an independent mechanic do it (who will charge less). I'd make sure the shop has experience with turbo Subaru engines, though (or pick a Subaru-only shop). |
#7 | |
Member#: 94339
SCIC
Vehicle:2005 STi |
#8 |
Member#: 90156
NWIC
Vehicle:1986 Syncro Vanaru 07 SV650 |
That job should take an experienced mechanic, ie., someone who has done it before, no more than 40 minutes. It shouldn't take a novice more than an hour and a half.
They are trying to fleece you. Either do it your self or take it to a different set of hands. |
#9 |
Member#: 9861
RMIC
Vehicle:1999 2.35 RS-T w/NOS Hybrid Rally Blue Pearl |
Book time it 2.1 hours according to alldata.
#10 |
Big Ron
Moderator Member#: 18062
If you post in the SE Regional Forum, I'm sure you can get someone to help for beer or do it for like $50. Beer and friendship is the best choice though.
#11 |
Vendor
Member#: 87569
Vehicle:Once Was Gr8wheels |
FYI! Real time labor guide a guide that collects national DATA and compiles real time stat National Average 1.6 hours I find them acurate as an average when you take some really fast guys and some slow! I prefer a average speed guy! I have seen more than an average stripped plug holes in subarus and the problems that creates in a suby is multiplied by location!
| Thread Tools | |
| Display Modes | |
| How to- Install Spark plugs | Dirtyhobo010 | Service & Maintenance | 57 | 10-02-2012 01:54 PM |
| Time to get new plugs! | Schleppy | New England Impreza Club Forum -- NESIC | 7 | 09-22-2003 09:18 PM |
| hesitation after installing new plugs | MAD REX | Factory 2.0L Turbo Powertrain | 0 | 04-08-2003 01:51 PM |
| How hard is it to install new forged pistons? | skywalker | Normally Aspirated with bolt-on Forced Induction Powertrain | 13 | 10-16-2001 06:23 PM |
| Planning to install new stereo; please advise... | scotty305 | Car Audio, Video & Security | 3 | 09-10-2001 04:24 PM |
