Old 09-06-2001, 12:40 AM   #1
Andrew
Member#: 1170
2005 STi
Arrow Auto tranny temps discussed with Subaru. No serious need for a tranny cooler?
I talked with Bruce at Subaru of Santa Cruz today about the Auto tranny temps. I asked him what the operating temps are of the tranny and he said around 180F and that the car can safely go to 210F (which is what mine did on a very long very hard run up a mountain). so i dont see any need for a tranny cooler. he said NOT to do the power launches that we all do at a stopligth or dragstrip. he said that that can EASILY heat up the Torque Converter to 1000F within 10seconds. so maybe for that type of application a tranny cooler would benefit us but i dont see the point in it being any form of a necessity.
but of course, for 50 bucks its not a bad safegaurd.
Andrew is offline   Reply With Quote
Old 09-06-2001, 01:01 AM   #2
ivbdn
Member#: 2736
2001 Impreza 2.5RS
I think the money spent on a tranny cooler is well worth that extra peace of mind. I'd hate to one day find out that I just roasted it.
ivbdn is offline   Reply With Quote
Old 09-06-2001, 01:18 PM   #3
ralyrcr
Member#: 1769
2006 Pontiac GTO
2009 Forester
Subaru also says that there is no need for aditional cooling on the svx, however talk to any svx owner and ask about how long thier 1st tranny lasted. svx s trannies last significantly longer with a cooler. i have several friends with svx s, and if i ever end up with an auto subaru i will be getting a tranny cooler.
jon
ralyrcr is offline   Reply With Quote
Old 09-07-2001, 05:35 PM   #4
WRX1
Member#: 3533
2002 Impreza WRX
WR Blue
Also, a 30 degree drop in fluid temps with DOUBLE the life of the fluid, and that alone is going to make it worth the money.
Russ
WRX1 is offline   Reply With Quote
Old 09-08-2001, 05:05 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
well as long as you change your fluid regularlly, every 15k or so you'll be fine, but it never hurts to have added protection, just make sure all your clamps and stuff are tight, blowing a transcooler line and running out of ATF is a BAD BAD BAD thing
Jeremy
Old 09-08-2001, 03:50 PM   #6
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
How much does an AT fluid change cost at the dealership?
garface is offline   Reply With Quote
Old 09-09-2001, 01:37 AM   #7
thng
Member#: 8062
In my book, any time you beat on an AT you need to put a cooler on it. If you granny the car for the rest of its natural life then you probably don't need one. But if you are going to do what anyone else that has one foot in an insane asylum; you are going to need a cooler. Warranty on my car, which should be similar to yours, is only 3 years/36000mi and I am about half way done with that already.
I had to do some long term testing on a Nissan Pathfinder with an AT. It didn't take long to burn the clutches in that thing. And the fluid came out smelling like it went through hell.
When I put the cooler on my last car I went and sized the proper cooler and then bought the next one up.
Get the cooler....that's one issue that won't come up again afterwards. And if you do get one make sure you put it after the one in the radiator.
thng is offline   Reply With Quote
Old 09-09-2001, 04:57 AM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
powertrain warranties on scoobies is 5yr/60K...get a cooler, change the fluid every 15k and ur set.
Jeremy
Old 09-10-2001, 11:54 PM   #9
Joncas
Member#: 5349
Garface ~$45 for a flush (does not pump out torque converter).
Joncas is offline   Reply With Quote
Old 09-11-2001, 03:14 AM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
$45=Drain and fill $99.95=flush
Or actually 109.95 @ my dealer
Jeremy
Old 09-11-2001, 01:41 PM   #11
Daios
Member#: 1111
2000 2.5RS Sedan
BRP 4EAT
every 15k miles?!?
Flushing out the TC is better right? What ATF do you people use? synthetic or reg?
Daios is offline   Reply With Quote
Old 09-11-2001, 02:54 PM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
you DO not need to flush it every 15k, just drain and fill....i normally rec a flush every 45k to 60k.
Jeremy
Old 09-27-2001, 12:27 PM   #13
enphorcerWRX
Member#: 8030
Platinum Silver Wagon
how do they flush the AT tranny?
enphorcerWRX is offline   Reply With Quote
Old 09-27-2001, 01:22 PM   #14
enphorcerWRX
Member#: 8030
forget it, i found the answer in a later thread
Old 09-30-2001, 11:05 PM   #15
KoMpreSsor
Member#: 10009
2002 Impreza WRX
WR Blue Pearl / Dirt
i would recommend the B+M stacked plate cooler that they sell in catalogs.
i had the 24,000 or 28,000 lb motor home unit on my '98 grand prix gtp. i had close to 280 hp at the crank, and they were known to have weak A/T's. never had a hint of a problem.
at 37,000 miles, the fluid was clean and so was the filter. absolutely no odor.
more amazing is how much heat the cooler would transfer to the surroundings. the B+M unit is licensed from a canadian company. if you buy a cooler, give it a look.
KoMpreSsor is offline   Reply With Quote
Old 09-30-2001, 11:17 PM   #16
KoMpreSsor
Member#: 10009
2002 Impreza WRX
here is a photo.......
why the need for additional oil cooler? hwtan Newbies & FAQs 10 10-08-2007 01:19 PM
What do I need for WRX tranny install into 99RS?? Urgent! sonic03rex Transmission (AT/MT) & Driveline 0 05-14-2007 09:40 AM
Why Subaru no manual hub for dorifto action? X-Factor Off-Topic 5 01-26-2007 08:35 AM
wat is needed for a tranny swap GotTurbo Legacy Forum 14 07-12-2004 04:20 PM
Extra hands needed for engine/tranny pulling Aspen_2.5RS South East Region Forum 26 09-08-2003 08:00 PM
