Old 09-06-2001, 04:02 AM   #1
VOLTIS5
Member#: 2353
98' LegOver GT
dark whiteish pearly red
Unhappy did i make a bad choice?
ok heres the thing that worring me. i just got my rotors and i'm getting them installed this weekend and i like em (btw its x-drilled) but as i went to the "brake, suspention" forum i heard that they sucked. now im not gonna say i believe them but i have to exp. it myself b4 i go and say that they do. but for all you out there that have these kind of rotors, how do they do street wise, any improvments over stock and what about snow would it crack easily? either way i have em now and just wanna find out how i can avoid the prob. that these people say about em.
thanks
VOLTIS5 is offline   Reply With Quote
Old 09-06-2001, 09:24 AM   #2
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Let me explain something to you about this board:
If you can imagine a passel of dogs, all grouped around one tree, you'll have an idea about the mentality. There is some good information that gets out of the personal bias and hooraw, but it's mostly just dogs pissing on the tree, that tree being defined as the opinions and choices of other i-Club members.
Unfortunately, there isn't anyone in this forum who drove my GT wagon and can attest to how well it worked with a KVR CD rotor/carbon fibre pad combination. Even if your CD rotors don't work any BETTER than solid ones (something still to be proven decisively) they won't work any WORSE, either.
This board can be a good place, in that you find out answers to some questions that you might have. It can also be a nest of pit vipers that breeds uncertainty and feelings that you made the wrong choice with your suspension/brake/boost controller/sway bar/whatever.
Don't let it get to you. Just get them cryo'd, as I did, at some place like 300 Below, which is good advice period, and use them in good health.
Kevin
gtguy is offline   Reply With Quote
Old 09-06-2001, 11:07 AM   #3
AGscooby
Member#: 4242
1999 BD SUS GRN/GLD
gimme Legacy TPH wagon!
Lightbulb
Hey VOLTIS5, it's nice to see that at least one of us Napervillians can afford parts. In any case, I take mixed opinions about mods/parts very lightly. I say heed what others say but don't let that be your decision as well. If I had the extra money, I'd probably give cross-drilled rotors a try. In the end if you really don't like them, at least they're parts that need regular replacement. AND instead of saying "I heard cross-drilled rotors aren't very good", you can say "I tried them, and [insert comment here]."
BTW, did you get new pads? What kind?
AG
May be the B4 be with you!
AGscooby is offline   Reply With Quote
Old 09-06-2001, 11:30 AM   #4
VOLTIS5
Member#: 2353
98' LegOver GT
yes, i did get new pads but not the kind gtguy's usin. too much $$$ for me . i got ceramics on front and organic in the back, i dont know if this comb. is any good but i'll give it a try. any of you guys tried these type of pads b4? any comments on them?
thanks again
BTW AG, it took me 2 months to save up enough $$$ JUST for the rotors
Old 09-06-2001, 12:52 PM   #5
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
Don't worry about it you'll be OK.
HIHO is offline   Reply With Quote
Old 09-06-2001, 04:33 PM   #6
Jason
Member#: 105
2000 Legacy GT Ltd
WHT
XD rotor will be fine. IMO, it just wont' give you much advantage over the non drilled rotors.
I do however, wonder if those rotors are designed to be drilled. Althouh in most cases, people will get away with it, but I think few of them will eventually crack.
Jason is offline   Reply With Quote
Old 09-06-2001, 07:37 PM   #7
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
VOLTIS5 - This question you've asked is a timeless debate. Being that it's a part you'll need to replace down the line b/c of normal wear and tear anyways, it's always best to try it out to form your own opinion.
I've used x-drilled and slotted rotors on all my cars. I by far find x-drilled rotors much better for street use.
I wouldn't endorse anything that I can get for the Subaru community that I haven't tried myself.
gtguy got his pads and rotors from the first GB I set-up. Patrick Olsen hasn't used the ones that I've been doing for the GB (or any x-drilled rotors to my knowledge). So you make your own decision.
Ultimately, if proper break-in procedures are followed, they will last longer than stock rotors under the same conditions.
GTBGUY is offline   Reply With Quote
Old 09-06-2001, 09:06 PM   #8
silverSurfer
Member#: 1361
1999 Legacy GT Ltd.
2006 Rav4 Sport Silvarrr
Talking
hey Kevin,
did you get that idea to use 300Below from me?
That's where i got my X-drilled rotors cryo'd. I've auto-xed a couple of times on my brakes, made numerous emergency stops and plain driven maniacal too, and I've had no problem with my brakes.
Oh I also have the EBC Green pads: NO i don't have major dusting or any squeeling at all. I have the SPO cf pads for the rear. Those squeeled a bit. But nothing the anti-squeel paste/jel put on the pads when you installed them won't handle. Oh yeah yeah...i have S/S lines with Neo Dot4 fluid too...
-chrisC
silverSurfer is offline   Reply With Quote
Old 09-07-2001, 01:19 PM   #9
VOLTIS5
Member#: 2353
98' LegOver GT
Thumbs up
thanks for the info guys. i guess i just really have to find out for myself to see how these rotors do and then have my opinoin on it down the road .
BTW whats "cryo'd"?
Old 09-07-2001, 03:05 PM   #10
gtguy
Member#: 2184
Cryogenic treatment, which is essentially freezing something to a temperature nearing 300 below zero, then gradually bringing it back up to room temperature. It has been proven to make metal stronger and more durable. Go to www.300below.com, which should have plenty of information.
Kevin
Old 09-07-2001, 10:45 PM   #11
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
I have the KVR pads and slotted rotors from GTBGUYs latest group buy.
They rock. Really. Soooo much better than stock rotors and the axxiss/repco pads I had on.
The slots keep the rotors and pads nice and cleaned off, or so I've observed. Downside is lots of black dust, but I can live with that.
remarcable is offline   Reply With Quote
Old 09-08-2001, 03:29 AM   #12
tahrndt
Member#: 1315
Hey for a really good site dealing with freezing you rotors check out www.frozenrotors.com
they are a Minnesota company that supports Rallying and the Soob community here in MN. At the pre race party for the Ojibwe State Forest Rally they donated a door prize of 1 complete set of rotors cryo'd. I did not win that one but I won the Soob rally blue jacket made by LL Bean!
TIm
tahrndt is offline   Reply With Quote
Old 09-08-2001, 09:10 PM   #13
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default wow
this was dramatically more polite than the other discussion. Should I start a fire here? CD rotors SUUUUUCK!!!!!!!!!!!!
j/k guys I think that we beat that horse to death. They will probably do just fine, but hey let us know.
edit: redundant
subysouth is offline   Reply With Quote
Old 09-08-2001, 09:55 PM   #14
HIHO
Member#: 7624
BD5; family sedan
Thats coming from a guy who bought my stock exhast then got upset because it didn't fit. He did not even ask if I had a sedan or wagon when he bought it. I had a sedan so the exhaust was about 6" short. Just messing with you South. Did you get it extended to fit?
PS- Get some than you can bitch about how bad they suck.
Old 09-08-2001, 11:39 PM   #15
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
You took me for a ride and I kissed the dashboard several times... I can definitely attest to how well that wagon stopped. Most impressive thing I've felt in such a large (no offense) vehicle.
Old 09-09-2001, 11:48 PM   #16
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default Yep
Hmmm, when did I get upset? Anyway,I did get it worked out HIHO. I knew you had a sedan(not to many donor GT wagons available, gotta take what you can get.) I kinda had hoped the length difference was in the midpipe(nope-tailpipe.) I posted but I couldnt get it pinned down, but it was no prob to fix.
On the brake agenda, I tell you what I would really like as far as rotors go is a two piece rotor (maybe slotted.) You listening GTBGUY??? I think hes keeping up with the WRX brake developments. I want some weight savings if I can get it.
My latest brake upgrade has been to the WRX setup on my wagon, I can definitely FEEL a difference. I would recommend this to anyone. I went from a 10.2" rotor to an 11.4" and single pot to 2-pot. Definitely stops a lot better I think. Need to wear out the RE92s and get some better rubber next.
Edit: rotor dim.
Did I make the right choice? Python96 Newbies & FAQs 13 11-28-2008 02:29 AM
Good Choice or Bad Choice? nonstop213 Transmission (AT/MT) & Driveline 0 09-19-2006 06:23 PM
where did you work/how did you make money in college BigWrecKs Off-Topic 38 01-12-2006 05:03 PM
Did i make the right choice? Miguel_04_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-28-2003 02:31 PM
Is Valentines day a good or bad choice for a first date? Hagbard Off-Topic 26 02-12-2003 09:24 AM
