Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 12-02-2005, 09:48 AM   #1
greysave
Member#: 62395
2005 STI
Default Street tuner and Utec or Hydra?
I currently have a street tuner which for tuning fuel and timing its great. With my application though launch control would help greatly. I would also like to add nitrous later which the street tuner also does not natively support. My idle also needs to be raised which I apparantly can't do with the street tuner. My question to you is do you think I should keep my street tuner and add a utec for more control or go straight for a hydra? Anyone having any major problems with the hydra?
greysave is offline   Reply With Quote
Old 12-02-2005, 10:02 AM   #2
hondaeater69
Member#: 60324
you can adjust idle with ST.
they will have their pluses and minuses. does keeping OBDII compliant matter to you? If so stay with ST + UTEC. THe biggest draw back to that IMO is having to run two systems and switch between them. Obvisously having just one EMS system would be simplier in the long run.
hondaeater69 is online now   Reply With Quote
Old 12-02-2005, 10:35 AM   #3
TheMadScientist
Member#: 23717
2005 Big red
I love the ST+Utec combo. What one can't do the other can.
I don't think you can adjust idle with ST but I think you can with PT.
TMS
TheMadScientist is offline   Reply With Quote
Old 12-02-2005, 10:57 AM   #4
hondaeater69
Member#: 60324
strange, maybe just on the STi you can't adjust idle, i can with my ST.
Old 12-02-2005, 12:28 PM   #5
greysave
Member#: 62395
2005 STI
There is definetly no Idle adjustment which has been a real annoyance since I have a dr725 and modded injectors. The car stalls when coming to a stop at least a few times a day. How much more did pro tuner cost? The only reason I am shying away from hydra is the intial set up seems pretty complicated.
Old 12-02-2005, 01:46 PM   #6
hondaeater69
Member#: 60324
i think protuner is like 1300-1500 iirc.
I would call cobb and ask them about that feature, WRX ST SW has it. . .
Old 12-02-2005, 02:30 PM   #7
Newbie Subie
Member#: 20214
07 Acura RDX
390WHP no more
Hydra all the way.....initial setup is not that bad. Tell Phil what you have he gives it to you. Idle adjusment is kind of a PIA but with Phil its not that big of a deal just patients in getting it right.
Newbie Subie is offline   Reply With Quote
Old 12-02-2005, 02:30 PM   #8
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
I remember reading a thread on the Cobb forums, someone had problems with the idle adjustment on the ST. They worked around it for now by using ecuExplorer which did the trick.
drees is offline   Reply With Quote
Old 12-02-2005, 02:55 PM   #9
greysave
Member#: 62395
2005 STI
What is ecuExplorer.
Old 12-02-2005, 03:02 PM   #10
drees
Member#: 25905
2003 Silver Wagon
http://www.tari.co.za/cgi-bin/yabb2/...cuexplorermain
Old 12-02-2005, 03:12 PM   #11
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
If you cant adjust the idle with streetuner, make sure you are running the current version.
FYI, the current version is 1.5.0.3
parker/slc/gc8fan is online now   Reply With Quote
Old 12-02-2005, 03:14 PM   #12
hondaeater69
Member#: 60324
It's under the list of tuning parameters for the wrx, but NOT for the STi. wonder why. . . .
Old 12-02-2005, 03:39 PM   #13
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Regardless of idle problems, if you really want to go big power I would suggest a Hydra.
offset
offset is offline   Reply With Quote
Old 12-02-2005, 03:50 PM   #14
TheMadScientist
Member#: 23717
2005 Big red
Didn't Big Valley use a Utec up to ~600whp?
TMS
Old 12-02-2005, 06:06 PM   #15
greysave
Member#: 62395
2005 STI
Did I mention I also want to add nitrous and water injection? I also want launch control.
Old 12-02-2005, 08:51 PM   #16
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
TMS
Lot's of good choices out there just pick one that suits your current and future needs adequately.
Big Valley's been using Hydra from the EVO vs. Subaru Shootout on. I gave them a secret weapon for the weekend and I hope to see them run 9s
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Street Tuner and Pro Tuner Zumble AccessPort 6 06-02-2006 07:22 AM
Cobb street tuner vs. UTEC deluxsti Engine Management & Tuning 7 06-24-2005 11:51 PM
Street tuner and frustration levels 03WRX83 Engine Management & Tuning 8 03-10-2005 01:38 PM
UTEC or HYDRA for GT35 Kingpin Turbo Kit STi_Guy04 Engine Management & Tuning 33 01-31-2005 11:47 AM
street tuner and pro tuner question dippi Engine Management & Tuning 0 09-11-2004 12:13 AM
