Old 12-02-2005, 10:44 AM   #1
b0dh1
Member#: 35269
2011 WRX
Default Cam seal leaking oil. Again!
Does anyone know how involved this would be to replace the cam seal on the passenger side?
It's been to the dealer twice for the same problem but mods are holding me back from taking it a third time and I figured I'd see if anyone has done it.
I'm pretty good with a wrench but I'm not comfortable tearing the actual motor apart.
b0dh1 is offline   Reply With Quote
Old 12-02-2005, 02:43 PM   #2
Tuning Factory Inc.
Vendor
Member#: 3600
Oof be prepared to take off timing belt, cam gear and the valvecover/cams/cam holders to get the new seal in. It will take you a few hours I'd say.
Tuning Factory Inc. is offline   Reply With Quote
Old 12-02-2005, 03:51 PM   #3
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
If it's started leaking twice then I would think you have a bearing issue with that cam. The cam must be wigging up and down causing the seal to leak. Just replacing the seal with a new one is not going to resolve the issue.
mick_the_ginge is offline   Reply With Quote
HELP!! cam seals broken? oil leak. s204life Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 02-16-2010 07:59 AM
2.5 SOHC Cam Seal Leak,. Next Step?? Bullwinkle Service & Maintenance 2 08-28-2009 10:08 PM
Cam Seal Leak DHRDAN Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 07-08-2009 06:19 PM
Cam seal leak bennd87 Built Motor Discussion 7 01-12-2009 11:41 AM
cam seals leaking lawman246 Service & Maintenance 6 01-05-2007 07:31 PM
