Old 12-02-2005, 09:20 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default Leaking Oil FAST After Oil Change
Hello,
Last night, I changed the oil in my '05 2.5RS myself for the first time. Today, I found the thread about the leaking 09A filters. I went under the car to check what filter I had installed and find that it's leaking oil like crazy. However, checking the batch number, the filter is an F11, supposedly one of the OK batches. Have the problems continued, or did I actually manage to screw up something as simple as screwing on an oil filter?
Ty
Old 12-02-2005, 09:23 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Are you sure that the rubber gasket came off with the old filter? If you accidentally "double-gasketed" the new filter it would explain the leak.
Old 12-02-2005, 09:37 PM   #3
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
When I removed the old filter, I was left with a polished metal surface on the bottom of the engine block for the black ring on the new filter to seat against. I would assume that if the old filter had left it's black ring, I would have seen it on that metal surface.
Ty
Old 12-03-2005, 01:26 AM   #4
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
I have seen the supposed new, updated oil filters, STILL leak. They should've stuck with the Japanese one with the nice plastic covering
It will become a problem if Subaru doesn't act fast, because many people will be comming back with the common complaint of a burning oil smell.
Pakin is offline   Reply With Quote
Old 12-03-2005, 02:33 AM   #5
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
You can still get the black OEM filters here for anyone that's intersted:
http://forums.nasioc.com/forums/showthread.php?t=891606
volkl23 is offline   Reply With Quote
Old 12-03-2005, 09:20 PM   #6
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Originally Posted by williaty
Hello,
Are you sure you tightened the oil filter on correctly? I've seen it happen before where it wasn't tightened down properly.
Samurai Jack is offline   Reply With Quote
Old 12-03-2005, 09:31 PM   #7
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I threaded the filter on until the gasket on the filter made contact with the metal seat. I then tightend the filter until the resistance increased (until it became "firm") and went 1/2 turn farther. Is that enough?
Old 12-04-2005, 04:27 AM   #8
hoodscoob
Member#: 85140
2005 Legacy GT wagon
topazzzzz
I changed my oil last weekend with a F11 batch filter and it is leaking as well. Looks like I am going to have to get one of those black filters. Do they fit a 02 wrx.
hoodscoob is offline   Reply With Quote
Old 12-05-2005, 05:10 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
and that is why i use Honda filters made by FilTech on my car
Old 12-05-2005, 10:07 AM   #10
BryanH
Member#: 993
And this is why I will continue to use Purolator pureone.....
BryanH is offline   Reply With Quote
Old 12-05-2005, 03:57 PM   #11
Krazy Mysterioso
Member#: 84415
My friend tried several different ones with his and when I convinced him to try the one I was using (from Amsoil) he hasn't had any leaks.
I have "fixed" (not really doing much but hey) on a couple dates where people managed to have the filter threaded all the way down but its angled so that there is a portion of it that does not make as good of contact.
Last thing I would say is are you sure it's coming from the filter?
Krazy Mysterioso is offline   Reply With Quote
burning oil smell after oil change happs subi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 12-02-2009 01:37 PM
Oil Leak after Oil Change? salvator_rizzo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 05-28-2009 11:14 PM
Oil leaking near turbo after oil change??? yzer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-16-2008 11:18 AM
rear differential leak after oil change? Kevex Service & Maintenance 4 04-10-2002 08:39 PM
burning oil smell after oil change? wrxinfx Service & Maintenance 4 12-12-2001 10:13 AM
