Tire & Wheel Forum sponsored by The Tire Rack |
12-02-2005, 11:22 PM | #1 |
Member#: 67395
Help me paleez! Sticky tires for my driving style
I've got an 05 sti.
*Hotckiss performance swaybars front and rear(current) *STI pink springs(will install come springtime) *SSR GT2 18x8.5 *factory alignment specifications *I don't care if the tires only last one season(April-October) appx-8,000 miles *I want to feel maximum g-forces when going through corners (I'm not talking xtreme high speed corners, but more like autocross type speeds, although I've only done one autocross this past year and will probably only do one or two this coming year. *this is a daily driver Questions; 1) What tire has made you most pleased? 2) Does a wider tire(more contact patch) always correlate to better cornering? 3) Should I go with different alignment specs? 4) Does a lower UTQG rating always correlate to better cornering? Thank you
12-03-2005, 01:33 AM | #2 | |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
And as far as tires go...a 225/40 is what ya want....and these are some of yer 'R' compound choices..... http://www.tirerack.com/tires/Spec.j...=24YR8SPORTCUP http://www.tirerack.com/tires/tires....1=yes&place=37 http://www.tirerack.com/tires/tires....1=yes&place=33 http://www.tirerack.com/tires/tires....1=yes&place=39 http://www.tirerack.com/tires/tires....1=yes&place=30 |
12-03-2005, 01:57 AM | #3 | |
Member#: 24038
South East
12-03-2005, 02:20 AM | #4 |
Guest
Member#:
go yokohama es 100's, realy great tire with great sticky characteristics. One of the best tires out there.
12-03-2005, 02:28 AM | #5 | |
Member#: 16200
....no...just plain NO..as in NOT |
12-03-2005, 02:31 AM | #6 | |
Member#: 24038
South East
ES100's are NOT one of the best tires out there, in fact, they are one of the worse couple. They are VERY average in terms of grip, noise, and wear. They are good because they are cheap. But as far as performance goes, they are a long way off. Like many people on here with them, I would never buy them again... |
12-03-2005, 02:32 AM | #7 | |
Member#: 24038
South East
12-03-2005, 03:01 AM | #8 |
Guest
Member#:
well I believe they are one of the best tires for a wrx or sti and I prefer them over michelin pilots so that is my .02.
12-03-2005, 03:35 AM | #9 |
Member#: 84006
NWIC
Vehicle:2005 Impreza WRX STi WRB with Goldies |
I'm really impressed with the stiction of the RE070s on dry and wet, but then again, that's all I have any experience with. I've had them out to the track and they're very responsive (stiff side walls), and they understeer very controllably at the limit of traction, but then that's a matter of sway bars. I plan on putting some Cobb sway bars on and get them back out to the track next summer. Then we'll se how well balanced they can be.
12-03-2005, 08:40 AM | #10 |
Member#: 67395
Tire size is what I was thinking of....
2) Does a wider tire(more contact patch: Contact patch size stays the same, shape changes, for a given pressure that is) always correlate to better cornering?
Oops, I was not referring to adjusting tire air pressure to change the shape of the contact patch, but if one goes with a wider tire(of the same model), will cornering traction increase? |
12-03-2005, 08:43 AM | #11 |
Member#: 67395
I used to be pleased with the REO70's.....
[quote=STirocket]I'm really impressed with the stiction of the RE070s on dry and wet, but then again, that's all I have any experience with.......
For the first summer I drove my STI, I really liked the performance of the REO70's. However, as my "cornering gumption" increased, I found myself pushing harder and discovered I was already near the limits of maximum g-force felt with my set-up. |
12-03-2005, 08:52 AM | #12 |
Member#: 67395
Thanks for addressing each question.
[quote=Uncle Scotty]To get MAX 'summer' performance, you should look into some more suspension adjustability..........
I figured I would need to adjust my alignment. As far as rain performance goes, anything that "sticks" as well as the REO70's is acceptible to me. And by that I am being facesious(sp). My experience with REO70's in the rain is okay until you even tap the brakes on a wet painted line around town, instant skid!......REO70's sort of suck in the rain. Until now, I've been under the impression that a lower UTQG rating=more traction and therefore I had my eye on the Michelin Pilot Sport Cup(UTQG rating=80 versus the REO70=140) in a 18" (to fit my new wheels, which is what I want.) Thanks Scotty.... ps I thought you were Subaruless, now I notice you may be the proud owner of a TR?.....Cool |
12-03-2005, 11:28 AM | #13 |
Member#: 12
Vehicle:2018 STI Type RA Crystal Black Silica |
If you are looking for a street tire instead of an R-compound you may want to look into a Falken Azenis RT-615 or if money is not object a Yokohama Advan Neova. These are the top two that I am looking at. I have yet to try them out, but I have heard good things and I figured if Lotus was nice enough to suit up their Elise with these Advans, they may be worth looking into.
12-03-2005, 01:17 PM | #14 | |
Member#: 41762
International
Vehicle:04 STi in ur Floriduh |
12-03-2005, 01:31 PM | #15 | |
Member#: 24038
South East
Fact is, that tire is at the BOTTOM of the summer performance pile. Take a look at tirerack, read the reviews, if you think that is anywhere close to a good tire, let alone one of the best, you have a lot to look forward to when you replace them with something else. |
12-03-2005, 01:36 PM | #16 | |
Member#: 41762
International
And when they're wrapping 'round 18" konig theroies, all the hunnies is checkin em out. |
12-03-2005, 03:03 PM | #17 | |
Member#: 24038
South East
what size sway bar is better for my driving style? | Speedster329 | Newbies & FAQs | 9 | 03-02-2010 02:18 PM |
help me choose a tire for some Sti V7 rims | trojanWRX | Tire & Wheel | 2 | 06-05-2006 07:27 PM |
Help me pick new tires for my Tacoma | beachbum | Off-Topic | 14 | 08-03-2005 02:26 PM |
Help me choose a tire for HDPE/Autocross for 2005 | MattNJ2.8 | Motorsports | 21 | 12-02-2004 01:53 PM |
what coilover setup would be most compatible for my driving style? | eharo99 | Brakes, Steering & Suspension | 4 | 01-21-2004 06:44 PM |
