Old 12-03-2005, 09:09 AM   #1
HAL1
Member#: 58926
2013 WRX 5dr ISM
2011 Infiniti EX35
Default AP response from 2k - 3k rpm ?
I've read all about Stage 1 smoothing out the power band giving and giving power all through the turbo range rather than the sudden pull you start getting. But what about improved response if I'm just cruising at 35 mph in 4th at 2Krpm, then just put the pedal down from, say 2K-3K rpm.
Thanks
HAL1 is offline   Reply With Quote
Old 12-03-2005, 10:27 AM   #2
yobtah
Member#: 48939
Thanks
If you're at 2000 rpm in fourth in a 2.0L WRX, the better choice is probably a downshift to second or third. I've been running Stage I for a while, and I'd say the engine pulls slightly better from low rpm, but it's not a huge change. It's just the nature of a relatively small forced-induction engine... it's off-boost, so there's not too much that can change.
yobtah is offline   Reply With Quote
Old 12-03-2005, 02:49 PM   #3
84SubaruDL
Member#: 42179
SON! F 22's i roll
on 33" 12 fity SON!!!
if you think you have a problem with 40mph in 4th gear at 2krpms
try it with an untuned VF30 map.
if you feel that you won't be upgrading anytime soon, and if you have cash get a custom tune
84SubaruDL is offline   Reply With Quote
Old 12-03-2005, 05:13 PM   #4
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
I found stage 1 to be smoother, yes, but it didn't gain a whole lot below 2500RPM. A bit, yes. The throttle response is better, but it's not really 'faster' until 2800.
Stage 2 with gutted UP/catted DP has a very noticeable increase in response and acceleration down in the 2k-3k RPM range.
It's still about tipping in to the throttle the right way. In 4th at 2100 if you just nudge the throttle until you hear the turbo a bit, and then roll smoothly on to the rest of the throttle, it really has lots of kick. If you just give it 1/2 throttle or more right away, it will not respond nearly as well.
It's one of the joys/challenges of driving a turbo car.
AP - Highly recommended. Stage 1 IS way better than stock.
02WHITEDUB is offline   Reply With Quote
Old 12-04-2005, 05:12 PM   #5
2fas4u
Member#: 90691
2005 STI / 2009 STI
Yeah that is where the AP tuning really wakes the car up. There is tons of pull at those lower RPMs...
2fas4u is offline   Reply With Quote
Old 12-05-2005, 03:56 AM   #6
FWD WRX
Member#: 85592
05 OBP
installed AP stage 1 on a stock car today.. its great!
FWD WRX is offline   Reply With Quote
Old 12-05-2005, 01:23 PM   #7
Badkarma
Member#: 42641
2004 GTO
Red as Hell
UPS man has mine in his truck, definetly not being driven by Dale Jarrett or it'd already be here.
Hopefully I can get it installed tonight.
Badkarma is offline   Reply With Quote
Old 12-06-2005, 10:26 AM   #8
Badkarma
Member#: 42641
2004 GTO
Red as Hell
Holy crap, it's like night and day. It's smooth as silk. Damnit, I wasn't gonna mod this car at all, now I'm thinking stage 2. Son of a b****
Old 12-06-2005, 04:10 PM   #9
Scoobie Noobie
Member#: 65498
^^^ Amazing how fast that happens.
"Stage 1 is awesome! Can't wait for stage 2!"
Let the games begin.
Scoobie Noobie is offline   Reply With Quote
Old 12-06-2005, 04:29 PM   #10
2fas4u
Member#: 90691
2005 STI / 2009 STI
yeah the most I noticed was how the power band was shifted to something more useful. With my STI, even in 5th and 6th the pull was much harder. Now remember I had a pro tune so I get more advantage than just stock maps, but I still say it is the best money we ever spent....
Old 12-07-2005, 04:22 PM   #11
Scubaboy7000
Member#: 47365
2004 WRX
yes, my 04 was a bit choppy through the power band when I bought it...especially at WOT. Then I installed the AP and was very excited to feel the smooth power and no hicups!!!
Scubaboy7000 is offline   Reply With Quote
Weird noise @ 2k and 3k RPMs Sean2.5Black Pre-2002 Factory Turbo Powertrain 2 02-07-2010 04:44 AM
really bad shaking from 2-3k rpm subie502 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-02-2010 03:47 PM
Knocking between 2k-3k RPM? Pursuit Normally Aspirated Powertrain 13 04-21-2009 08:35 AM
Clicking sound between 2k and 3k rpm jmodica Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-29-2007 07:41 PM
hesitation during cruising at 2k-3k rpm cray_ze Newbies & FAQs 2 06-02-2004 11:51 PM
