Old 12-03-2005, 12:12 PM   #1
hondaeater69
Member#: 60324
Default heat stops working sometimes
Found lots of threads on overheating, but nothing on this. Over the last few weeks, my heat will stop working and turn cold. I'll shut it off for a minute and it'll come back in a few seconds, then go away again. Doesn't happen all the time but it seems to be happening more and more. any suggestions? heater core??
OH and lets' go UCLA!!!
Old 12-03-2005, 01:52 PM   #2
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
I suppose it could also be air bubbles in the heater core. Have you changed the coolant recently? In any case, I'd let the dealer deal with it under warranty.
Old 12-04-2005, 09:58 AM   #3
hondaeater69
Member#: 60324
na, coolany hasn't been messed with for a long time. It's a stage 4 car with almost 60K on it, no warranty here
Old 12-04-2005, 11:04 AM   #4
ivwarrior
Member#: 100610
MBP
What's your coolant level like? I've seen where a car would lose heat at idle, and pick it back up when you hit the gas....coolant level was low.
ivwarrior is offline   Reply With Quote
Old 12-04-2005, 01:46 PM   #5
hondaeater69
Member#: 60324
hmmm, i'll have to check that out later when the car cools. sounds possible.
Old 12-13-2005, 02:23 PM   #6
Sperm
Member#: 25038
I'm looking for a
02-03 WRX or 04 STI!
That's what mine is doing right now. I'll have to check the coolant level when I get home.
Thanks!
Sperm is offline   Reply With Quote
Old 12-13-2005, 02:45 PM   #7
JimBlake
Member#: 82247
2005 Saab 9.2x Aero
satin grey
Thermostat? Your car isn't making much heat at idle, so if your thermostat is sticking just a little bit open, that little flow thru the radiator can overcool it. When you go driving, the engine makes a lot more heat so then it's good.
JimBlake is offline   Reply With Quote
Old 12-14-2005, 12:36 PM   #8
MgMidget72
Member#: 57926
2003 WRX Wagon
Sonic Yellow
Any more information about this problem? Mine just this morning started blowing cold air. It was working fine, engine warm, temperature knob set to full hot, and then all of a sudden, cold air started coming out. Outside temperature was around 12 deg. F.
Any thoughts?
Recently, I too have noticed that it doesn't heat very well at idle.
Thanks,
Scott
MgMidget72 is offline   Reply With Quote
Old 12-14-2005, 12:58 PM   #9
hondaeater69
Member#: 60324
my coolant level was fine, and my car has stopped doing this. I don't think it's a thermostat issue, becuase my heat is HOT one second, and freezing cold the next. Then hot again 10 seconds later. Even if the thermostat was stuck open, the coolant is still going to be hot enough to make hot air, no? Maybe the heater core isn't getting proper flow due to the cold weather?
Old 12-14-2005, 11:39 PM   #10
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
don't forget that the heater coil acts like a radiator. If the thermostat is stuck open the coolant will cool off quickly. The only way the heater core would get improper flow is if the coolant was slushing or freezing.
cjfike is offline   Reply With Quote
Old 12-15-2005, 09:29 AM   #11
JimBlake
Member#: 82247
2005 Saab 9.2x Aero
satin grey
Not sure about Subies; do they have air mixing doors in addition to a water valve for the heater? Maybe those doors aren't holding their proper position; moving around??
Old 12-18-2005, 10:26 PM   #12
myver8
Member#: 100817
2004 subaru
Default i have the same exact problem
i have the same exact problem (04 wrx )
myver8 is offline   Reply With Quote
Both heat seats stopped working blah0r Interior & Exterior Modification 5 02-22-2010 09:56 PM
heat stopped working 3rdgearpinned Service & Maintenance 7 12-25-2008 05:05 PM
Heated seats stopped working CletusTheDwarf Electrical & Lighting 4 10-18-2005 05:40 PM
Sun roof works sometimes/Help viclava Newbies & FAQs 2 04-05-2005 07:22 PM
Parking lights only work sometimes WR^2X Electrical & Lighting 4 06-26-2004 08:27 AM
Message Board Statistics All times are GMT -4. The time now is 01:50 AM.
