Old 12-03-2005, 08:16 PM   #1
MitchGT
Member#: 73684
2012 4Runner
Default Aftermarket roof rack options
With ski season here I need to invest in a roof rack for the Leggy. The pass-through isn't cutting it anymore for 2 pairs of skis and at least 1 board. It used to be easy with my Jeeps that had factory roofracks to bolt a ski carrier on to, but how does it work on our cars that don't have window frames? Do the mounts actually go right next to the window glass? Anyway, just seeing if anyone here runs a Thule or Yakima or any other aftermarket roof rack. Any suggestions? Pics?
Mitch
MitchGT is offline   Reply With Quote
Old 12-03-2005, 09:04 PM   #2
fsuskppy
Member#: 100139
04 Legacy 35 anv.
Seamist Green
I have a Thule on my and on the brackets there is a lip that tucks into the roof and I hate it cause I have to crack my window just a little bit. It makes alot of wind noise but Im a snowboard instructor and I need to have it so......
fsuskppy is offline   Reply With Quote
Old 12-03-2005, 09:06 PM   #3
MitchGT
Member#: 73684
2012 4Runner
^^^^ That's what I thought would happen.
Old 12-03-2005, 10:35 PM   #4
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
My Yakima fits perfect. No issues with the window. I would say that if you have to crack the window either you have the wrong fit kit, it is installed wrong, or there is one more reason why I don't like Thule.
Mitch-
Go to www.yakima.com and check out their products. You will need to get some Q towers and the Qclips specific to your car. Then some cross bars and your choice of ski attachment. Yakima stuff fits very nicely and doesn't break. The wind noise is inherent to ANY rack, although there are some products you can add to limit wind noise.
.02
Jared
PS: you can save quite a bit of money on ebay with some of this stuff, but as always, you "may" be sacrificing quality, or actually aesthetics.
gtwagon941 is offline   Reply With Quote
Old 12-04-2005, 09:24 AM   #5
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
I don't think it's an inherent Thule problem. There's no reason that the 400 aero feet should require the window to be opened at all. I'm guessing incorrect clips or improper install.
I had a Barrecrafters rack on my old '97 sedan, and it fit fine. Pretty much the same concept as the Thule. I now have a Thule rack that attaches to the factory crossbars and some assorted Barrecrafters ski holders.
Anyway, both Yakima and Thule make excellent products.
KD7000 is offline   Reply With Quote
Old 12-04-2005, 09:58 AM   #6
MitchGT
Member#: 73684
2012 4Runner
^^^^ I actually still have my Barrecrafters ski carrier that I used on my other cars. I'm hoping it will still work once I get the towers and crossbars setup.
Old 12-04-2005, 10:08 AM   #7
TRH_legacy2k
Member#: 66222
2000 Legacy
'68 Spitfire
Thule in here...er, over here... If you want / need a closeup or anything, I could probably run out and take one at some point today.
TRH_legacy2k is offline   Reply With Quote
Old 12-04-2005, 10:11 AM   #8
MitchGT
Member#: 73684
2012 4Runner
TRH - No problems with it forcing the window open or any other fitment problems?
Old 12-04-2005, 10:30 AM   #9
TRH_legacy2k
Member#: 66222
2000 Legacy
'68 Spitfire
This was actually the biggest pain of any roof rack I've never put on (Old Toyota, Old Colt Vista, Jeep, Audi). You pretty much will need a buddy and you both have to tighten the feet at the same time (i.e. tightening the left side will pull the right out of position and vice versa).
I don't think it makes the window seal any worse than it already is, but I've had it on for 95% of the time I've had the car, so I'm not sure if I can make that call.
Ok, I went out and snapped some shots...apparently, it snowed! These are both from the front passenger side
Old 12-04-2005, 10:59 AM   #10
MitchGT
Member#: 73684
2012 4Runner
Awesome, thanks for the pics TRH.
roof rack options ??? IllNastyImpreza Legacy Forum 8 09-19-2008 05:24 PM
Factory or Aftermarket Roof Rack? subie4life General Community 3 07-03-2005 02:22 PM
Roof Rack Options for '03 mikebike357 Forester Forum 13 05-19-2003 10:01 AM
MY02 TS roof rack options AllWheelDrift Canada Region Forum 2 03-09-2002 09:31 PM
