Old 12-04-2005, 11:53 AM   #1
testes1010
Member#: 47145
2012 Gas Saver
Default EJ205 + DB TD05H-20G + 50/50 Meth/water Injection....
326whp/292wtq @ 21psi(93 pump + 50/50 meth/water mix).....full torque by ~3700rpm holds solid to ~5700rpm, very flat torque shelf w/ a slight taper toward redline, very linear power all the way to redline, all smiles ...
overall I'm very happy with the results(as always, thanks Jorge), & P&L's service was excellent....highly recommend P&L to anyone in the Chicago area....
Mods that matter:
- TurboXS UTEC (professionally tuned by Jorge @ P&L Motorsports)
- TurboXS Hyperflow TMIC
- TurboXS Magnaflow Catless Turboback Exhaust
- BPM XVR crossover pipe with port-matched & ceramic coated stock exhaust manifold, services supplied though Crucial Racing
- Crucial Racing Uppipe
- Crucial Racing 160deg T-stat
- Ultimate Racing 785cc/min Cylinder Flow Matched Injectors
- Deadbolt Zilla TD05H-20G (ceramic coated)
- CoolingMist 150PSI Alky Injection (UTEC activated, 50/50 Meth/Water)
- GMC Syclone Boost Solenoid
- Perrin Turbo Inlet Hose
- Walbro Fuel Pump 255lph
- XS Engineering CAI
- Mr. Josh's Lightened Crank Pulley
- APS DualVent BPV
- DIY Stainless Steel Hi temp painted & thermal barrier covered Turbo/Downpipe Heatshield
(93 pump + 50/50 Meth/water injection @ 21psi) VS. (93 pump, NO meth @ 23psi)
testes1010 is offline   Reply With Quote
Old 12-04-2005, 04:05 PM   #2
scoogan
Member#: 85673
Nice, no tranny upgrades?
scoogan is offline   Reply With Quote
Old 12-04-2005, 04:17 PM   #3
testes1010
Member#: 47145
2012 Gas Saver
other than a pos SPEC STG2 Clutch & ACT Streetlite flywheel, no...stock gearset, stock tranny...
I've been running w/ this turbo since May(tuned by Jorge)...just recently added the ported/ceramic-coated manifold & meth injection...then got a retune by Jorge
Old 12-04-2005, 08:08 PM   #4
WrxWonderWagon
Member#: 67265
04 35r Sti meth
What Spelluring?
wait so ur peak stayed the same wiht the injection
WrxWonderWagon is offline   Reply With Quote
Old 12-04-2005, 08:12 PM   #5
testes1010
Member#: 47145
2012 Gas Saver
nope, 326whp/292wtq @ 21psi(93 pump + 50/50 meth/water mix) minus 299.9whp/274wtq ~18psi(93 pump, no meth)
+ 26whp/18wtq...w/ only ~3 more PSI of boost...
Old 12-04-2005, 08:13 PM   #6
WrxWonderWagon
Member#: 67265
04 35r Sti meth
What Spelluring?
ahh ok
Old 12-04-2005, 08:28 PM   #7
Ultimate Collision Center
Member#: 69072
congrats
Ultimate Collision Center is offline   Reply With Quote
Old 12-05-2005, 06:26 PM   #8
andy
Member#: 62873
1990 Audi 90 CQ
red
any plans to run it on 21 psi in the quarter mile?
andy is offline   Reply With Quote
Old 12-05-2005, 06:31 PM   #9
nuhga
Member#: 80770
2005 v7 spec-c
cant you run more than 21 w/ meth ?
nuhga is offline   Reply With Quote
Old 12-05-2005, 07:19 PM   #10
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
did the ported manifold help at all?
bren wrx is offline   Reply With Quote
Old 12-05-2005, 10:43 PM   #11
testes1010
Member#: 47145
2012 Gas Saver
no, to andy....
yes, to nuhga...jorge had it cranked up to ~25psi...putting down high 330whp w/ less timing..but the TMIC was getting heatsoaked on the dyno...
yes, to bren wrx....but I have no proof of this...
Old 12-14-2005, 05:03 AM   #12
testes1010
Member#: 47145
2012 Gas Saver
bumping: added digital image of the dyno sheet instead of crappy pics...
Old 12-14-2005, 10:24 PM   #13
boardertj
Member#: 64014
2004 WRX sedan
JBP fosho
edit nm im blind.
boardertj is offline   Reply With Quote
Old 12-14-2005, 10:48 PM   #14
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
can rifts confirm the help of the manifold prior to tuning the meth
Old 12-15-2005, 12:40 AM   #15
Oaf
Member#: 60687
1981 Team Mongoose
Full Chrome Moly Frame
At what psi does the water/alcohol fire off?
Oaf is offline   Reply With Quote
Old 12-15-2005, 02:05 AM   #16
testes1010
Member#: 47145
2012 Gas Saver
near full boost from the look of the graph, I do know that the dip in hp/tq @ 3800-4000rpm is due to the initial onset of the injection...
if you speaking of UTEC settings I'm not 100% sure, I haven't checked the parameters on how Jorge set it up...my laptop took a poop this past week, awaiting a new hd...
Old 02-23-2006, 01:30 PM   #17
labelskate
Member#: 100512
2005 S2000
Grand Prix White
sick car.. I'm looking to eventually get a 20g once I upgrade everything all at once via dynocomp. Gotta save lol. you gonna look into a FMIC soon?
labelskate is offline   Reply With Quote
Old 02-23-2006, 01:55 PM   #18
testes1010
Member#: 47145
2012 Gas Saver
nope...it's a daily driver, I'd much rather have quick throttle response & little more torque down low than to have more topend hp & a little less throttle response & torque down low....
Old 02-23-2006, 02:11 PM   #19
gpatmac
Member#: 18446
2002 WRX wagon
psm
Congrats, Hoosier!
Have you strengthened the block at all or had any headwork?
Btw, I'll be down in Eville next week. I'll bring the wagon if it's up to it.
gpatmac is offline   Reply With Quote
Old 02-23-2006, 11:21 PM   #20
klattery
Member#: 48503
2004 STi ATP3071
testes1010,
Did P&L help with the install of the parts too? Just curious as I'm thinking of making the drive to Chicago for turbo, injectors, TGV delete, and a protune by Jorge. I trust the tuning, but want to know if I can trust P&L to install (more convenient than installing here and driving).
klattery is offline   Reply With Quote
Old 02-23-2006, 11:49 PM   #21
InfamousDX
Member#: 25413
Wow... very similar to my setup but I love your torque curve.. MUCH broader than mine. Looks great!
Old 02-24-2006, 02:31 AM   #22
ChgoJay
Member#: 71722
Originally Posted by klattery
testes1010,
I install all my own parts but if I was going to have someone install my parts, P&L would be my only choice. They do great work and they are really good guys. Always looking out for you.
Jason
ChgoJay is offline   Reply With Quote
Old 02-24-2006, 02:55 AM   #23
keaniegenie
Member#: 94494
2005 Element 92x
Great 2.0l setup. Very impressed.
keaniegenie is offline   Reply With Quote
Old 02-24-2006, 03:10 AM   #24
SubyDuz
Member#: 80432
69 IchhateinAudi
Blutrot
FMIC and more boost
But very nice numbers
SubyDuz is offline   Reply With Quote
Old 02-24-2006, 09:55 AM   #25
WRX-ERROR
Member#: 83211
2002 WRX - stg4
Originally Posted by SubyDuz
FMIC and more boost
I disagree.. 322awhp daily driver is enough. Like the man said he values low end power over top end.
Nice numbers man.
WRX-ERROR is offline   Reply With Quote
DB-td05-16g TO DB TD05H-20G upgrade WRX4eva Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-15-2007 08:58 PM
Fuel Map for Meth/Water Injection in SD Help plus plus plus UTEC 3 05-15-2007 07:39 AM
04 sti tuned with SMC Meth/water injection AZScoobie Proven Power Bragging 9 09-19-2006 09:21 AM
Coolingmist alcohol/meth/water injection kit Phil Jr. Private 'For Sale' Classifieds 24 06-21-2006 04:51 PM
Timing values and alcohol/meth, water injection reid-o Engine Management & Tuning 0 04-27-2006 03:45 PM
