Old 12-04-2005, 12:15 PM   #1
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Default HELP - How do I fix broken automatic door locks?
I have a 97 Impreza L wagon with broken auto door locks. The normal working behavior of the system is real simple. The three passenger door locks follow the position of the drivers door.
The broken behavior is as follows: The drives door lock works but it does not seem to have any effect on the other three doors. The other three doors can be manually locked and unlocked and seem to work fine mechanically. If I disconnect door lock fuse with the doors in the unlocked position and reconnect the fuse the three passenger doors instantly lock no-matter what position the drivers door lock is in. Its almost as if the position switch in the drivers door is stuck in the locked position.
Where is this switch and how do I get to it? Anybody ever have this problem with a 97 L wagon?
dexterous is offline   Reply With Quote
Old 12-04-2005, 02:36 PM   #2
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
I am pretty sure the switch is part of the door lock solenoid in the drivers door. The motion of that solenoid is supposed to control that of the other three. You will probably need to replace the drivers door lock solenoid.
specialev is offline   Reply With Quote
Old 12-04-2005, 03:57 PM   #3
dexterous
Member#: 23553
2014 WRX - Daily
Ok, how do I get to it? I cant figure out how to take the door apart. It looks as if its spot welded together.
Old 12-04-2005, 04:47 PM   #4
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
I don't know, but just have at it, you'll figure it out. Start by taking off the door panel.
Old 12-04-2005, 05:06 PM   #5
dexterous
Member#: 23553
2014 WRX - Daily
LOL, I am not that stupid. The door is already as taken as far apart as I can get it.
Old 12-05-2005, 10:44 AM   #6
dexterous
Member#: 23553
2014 WRX - Daily
Anybody else have any ideas?
Old 12-07-2005, 11:11 PM   #7
kdogae86
Member#: 99139
02 wrx
bluey
buy a manual
kdogae86 is offline   Reply With Quote
Old 12-08-2005, 11:44 PM   #8
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
dex, if you could post a photo of your door with the door panel off, we might be able to help more. Do you know what a door lock solenoid looks like?
PS - I agree the problem is the driver's door lock solenoid, so you might just check with one of the online Subaru discount parts dealers to find out how much a replacement will cost. Even given OEM pricing, it should be under $50.
The Welfare system is broken. How do we fix it? MrBlue Political Playground 181 02-08-2010 06:10 PM
Automatic Door Lock meprntr1 General Community 19 03-28-2007 01:27 PM
Automatic door lock crmcodeman Car Audio, Video & Security 5 12-06-2006 11:49 AM
HELP! What is this? How did it happen? How do I fix it? MyFirstDeuce Transmission (AT/MT) & Driveline 5 09-24-2006 10:50 PM
2000 RS install help! How do I take off my door! SR 25 RS Car Audio, Video & Security 3 11-24-2005 06:48 PM
