Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 12-04-2005, 12:31 PM   #1
express_wagon
Member#: 68346
2001 M5
2013 Abarth Cabrio
Default ABS vs No ABS in snow...my experience
after one winter with the wrx, like everyone else...i realize the abs is junk in the snow. so i decided to do a little test today. i rigged up a button over the summer to turn off the abs. here are my results.
done in an open parking lot, unplowed, straight line acceleration and hard braking at 25mph. both runs were basically next to each other so the snow on the ground is identical. tires are green diamond icelanders with ~800 miles. see for yourself.
first run, with ABS
2nd run, w/o
with abs, car basically felt like it was gliding. lots of typical abs noise. stopped okay. unnerving feeling if there would be cars around me.
without abs, though the track marks are not straight, i assure you the car felt alot better and stopped a heck of a lot faster. this is all.
drive safely. wear your seatbelts.
express_wagon is offline   Reply With Quote
Old 12-04-2005, 12:44 PM   #2
Casey
Member#: 82371
2002 IMPREZA
22 psi @ 2600rpm
This is my first full winter with the WRX and I am going to go pull my abs fuse today. I just wish that the abs light could be shut off.
Also ABS isn't supposed to help you stop faster but allow you to steer while you are slowing down/stopping. I'd rather pump my brakes anyway.
Casey is offline   Reply With Quote
Old 12-04-2005, 01:12 PM   #3
TheLegacy
Member#: 47615
2007 BMW 335XI
Saphire Black
now if u pump ABS brakes... doesn't that counteract it? Something that i heard awhile back not to do with ABS as thats waht u do with NON-ABS cars...
TheLegacy is offline   Reply With Quote
Old 12-04-2005, 01:32 PM   #4
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Good luck. IMO there are way too many variable in the real world to not have ABS the entire winter. I've tried both ways on the lake and fellt much better with snows and ABS.
BTW, my Green Diamonds took a good 2-3k miles to break in and get to the carbide flakes, I felt they gripped quite a bit better after that.
Snowphun is offline   Reply With Quote
Old 12-04-2005, 01:35 PM   #5
express_wagon
Member#: 68346
2001 M5
2013 Abarth Cabrio
they've already started to appear
and abs stays on basically all the time until there is packed snow on the ground. the switch comes in handy.
Old 12-04-2005, 03:02 PM   #6
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Just pull the bulb.
<--- ABS removed year-round.
jamesfacts is offline   Reply With Quote
Old 12-04-2005, 03:43 PM   #7
Sephro
Member#: 22319
05 LGT LDT
Right... ABS in snow.... this will never allow there to be any buildup of snow in front of the tires... the more snow that is building up there.. the more of a plowing type action.
However on ice with no snow you might find the results to be different.
I remember my prelude when the ABS would kick on in the snow it would give you the feeling of no control. Often I would have to yank the ebrake to get the car to stop..
(couldn't be disabled without screwed up the 4WS system..)
So in short I would prefer no ABS in the snow...
Sephro is offline   Reply With Quote
Old 12-04-2005, 03:58 PM   #8
Bradus
Member#: 10036
2008 Infiniti G35x
Volvo XC90-T6
I can't speak for US-spec cars but Audis in the UK used to have ABS switches in the car that allowed you tro switch it off for enhanced braking on gravel and in deep snow.
I'd prefer ABS at all other times.
I took a driving course at Skip Barber this summer and all I can tell you is that applying threshold braking without ABS is not as easy as you'd think. In the tests I performed at Skip Barber I was able to consistently stop quicker and in a shorter distance with ABS switched on than when it was off. After some practice I was definately able to stop very quickly in a car without ABS but I'm not so sure I could repeat that performance consistently well.
With the exception of perhaps straight line attempts to stop in snow or on other loose surfaces I think you could find yourself in a scary situation without ABS, especially if you add the need to corner into the mix.
At least express_wagon installed a switch to turn it on/off with ease.
Question for express_wagon: can your ABS system be switched on/off on the fly or do you need to stop the car, turn off the engine, flick the switch, and then restart the car as was the case with the cars at Skip Barber?
David
Bradus is offline   Reply With Quote
Old 12-04-2005, 05:08 PM   #9
strohausii
Member#: 26770
'02 WRX
midnight black
I know the 02's once off and then back on with the modded switch, you have to turn off the car and back on to reactivate the abs.
strohausii is offline   Reply With Quote
Old 12-04-2005, 05:31 PM   #10
Sean
Member#: 518
762 PGT Impreza L,
Silverado EXT, Yaris
Only if you hook into the wrong fuse. There are two fuses; one ABS Solenoid and one ABS/Cruise. I believe if you hook into ABS/Cruise then you don't need to power cycle the car to get rid of the ABS light.
NESIC Web Site | Trunkmonkey FAQ | Trunkmonkey Racing | Trunkmonkeys in Action
Sean is offline   Reply With Quote
Old 12-04-2005, 06:10 PM   #11
andrew_j
Member#: 102026
2004 WRX Wagon
I would like to suggest trying braking with ABS and turning/braking vs non-ABS and turning/braking. Not 100% postive but I think the ABS allows for better turns/stops on slippery stuff, I only have different cars to compare. I agree in straight line though its seems to extend stopping distance.
Great to know either way.
andrew_j is offline   Reply With Quote
Old 12-04-2005, 06:17 PM   #12
express_wagon
Member#: 68346
2001 M5
2013 Abarth Cabrio
David
the abs can be turned OFF on the fly but cannot be turned back on until you flick the switch back, turn the car off and back on.
for the other comment, if you throw turning into the mix, it's a whole other ballgame. that's when you'll find yourself much better off with the abs on.
Old 12-04-2005, 08:01 PM   #13
Davenow
Member#: 23676
Anyone that has been to team oneil can tell you how useless ABS is in REALLY slippery stuff. I pull my fuse every winter (not anymore)
Old 12-04-2005, 08:36 PM   #14
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
I've been to team oneil twice. Three times if you count showing up for a day and riding backseat in empty spots. And I disagree with your statement.
Fitz
Fitz is offline   Reply With Quote
Old 12-04-2005, 11:53 PM   #15
tygab
Member#: 5791
02 wrx wagon
shiny silver
I have done team oneil also and I will keep my ABS on. there are lots of variables as pointed out earlier. One thing I make a point of doing every winter (after sufficient snowfall) is braking hard with ABS so that I am familiar with what is needed to complete the stop and not have the unsettling feeling. Lather, rinse, repeat until it is 2nd nature.
tygab is offline   Reply With Quote
Old 12-05-2005, 12:29 AM   #16
Davenow
Member#: 23676
Fitz
OK almost anyone.
I know my 02 WRX was outright dangerous in snow and ice with ABS. Come up to a stop sign, touch the brakes in any manner at all and the car would blow right through the sign by easily 10-15 feet.
Pull the ABS fuse and stopping was a non issue. I stopped perfectly without it.
Old 12-05-2005, 12:34 AM   #17
supermarkus
Member#: 6971
2008 WRX STi
SSM
So start your braking 10-15 feet earlier
supermarkus is offline   Reply With Quote
Old 12-05-2005, 01:40 AM   #18
redobs
Member#: 1501
2009 WRX wagon
Dark grey
Exactly. If you connect to the ABS switch on the fuse box, you have to turn the car on and off to reset the switch. But, if you hook the switch up to the fuse next to the fuse box you can turn it on AND off on the fly.
redobs is offline   Reply With Quote
Old 12-05-2005, 07:01 AM   #19
express_wagon
Member#: 68346
2001 M5
2013 Abarth Cabrio
this is good to know
Old 12-05-2005, 09:39 AM   #20
m750
Member#: 2278
8Sti | 07 allez
White | Comp
I've always felt I was able to counter act ABS by lifting and re-applying the brakes. Which allows me to have confidence in the system, unlike some of you guys. Yes lifting and reapplying can increase braking distance versus a straight lock up, but, vs not lifting and abs it is more effective. For me, what's important is consistancy. Turning abs on / off just seems like I'd have to do more thinking about weather I had it on, or off at a particular time, than worrying about car control. Since we all agree proper methods to breaking with it on or off is different.
AO
m750 is offline   Reply With Quote
Old 12-05-2005, 09:43 AM   #21
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
yep. mine's been hooked up that way ever since chris (cdvma) showed me his rig. i had it the other way at first (ignition cycle necessary).
Old 12-05-2005, 01:09 PM   #22
fastfreddy
Member#: 66148
05 STI
With the STI it wouldn't really matter.
The brembos are HOPELESS in snow, dangerously so, abs or no abs
fastfreddy is offline   Reply With Quote
Old 12-05-2005, 01:24 PM   #23
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
what makes brembos hopeless in snow?
Old 12-05-2005, 01:27 PM   #24
fastfreddy
Member#: 66148
05 STI
They are very susceptible to snow build up on the rotor.
Press brakes and nothing happens - makes it like Russian roulette sometimes in the snow.
Happens frequently in the rain too.
They are great on a dry day but........
Old 12-05-2005, 01:39 PM   #25
TheLegacy
Member#: 47615
2007 BMW 335XI
Saphire Black
rain yeah i've had problems because im cross drilled but in the snow not to much of a problem... generally though i guess id do what i do in the rain which is pump brakes 2x-3x before needing to really stop.
First one to drive the Blizzak Revo1s in snow! My experience. powerlabs Tire & Wheel 1 11-16-2005 06:38 AM
ABS or no ABS in autocross w/non-stock brakes? RebelINS Motorsports 11 10-21-2004 01:02 AM
AutoX, ABS or No ABS? makofoto Motorsports 26 02-15-2004 10:54 AM
just ordered snows no Zoom in snows bill harvey New England Impreza Club Forum -- NESIC 4 01-02-2004 06:31 PM
Gravel roads - ABS or no ABS? 8Complex General Forum Archive 7 06-20-2000 09:35 PM
