Old 12-08-2005, 12:02 PM   #26
makofoto
Member#: 25243
2006 Legacy Outback
I agree ... we had a class room session the evening before ... during which Andy said that the first thing one should do is tire temps/pressures ... but when we went out onto the ski pad the next morning ... we set-up on the skid pad first ... THEN did tire pressures ... (we all sort of looked at each other and wondered about this) and then were released onto the transitional course ... with no further instructions, although Andy was there to consult with.
I need to find my notes ... but it was my understanding that the insides should always be around 10 degrees warmer? ... although what you say of course makes sense ...
... off to look for my notes and handouts from the Dial-In Course ... (We aren't suppose to share EVO Info ... so I can only make generalizations.)
makofoto is offline   Reply With Quote
Old 12-08-2005, 05:17 PM   #27
grippgoat
Member#: 62182
2005 STI
Probably stupid question: Would it make sense that a tire at the right pressure would have slightly lower temps at the outside edges, since the shoulders could dissipate more heat through the sidewalls?
-Mike
grippgoat is offline   Reply With Quote
Old 12-08-2005, 05:32 PM   #28
makofoto
Member#: 25243
2006 Legacy Outback
heat dissipation through the sidewall is probably pretty slow ... one needs to measure tire temp ASAP when coming off skidpad/track.
If it's at the "right" temperature ... then it would include whatever sidewall dissipation there is ...
Neutral Switch on 04 sti 6MT lagodcm Transmission (AT/MT) & Driveline 9 04-06-2011 11:50 PM
some d00d left neutral feedback on ebay, what to do Protege Menace Off-Topic 53 02-13-2007 10:32 PM
Neutral Wire on ECU for Remote Start color?? Crump Car Audio, Video & Security 2 09-21-2005 05:30 PM
confusion on tire rotation... Sobelizard109 Brakes, Steering & Suspension 4 03-17-2002 12:56 AM
Remote car starters and the neutral switch on manual tranny. SilverSuby Car Audio, Video & Security 9 02-06-2001 11:13 AM
