Old 12-05-2005, 06:52 PM   #1
riverarob
Member#: 44973
2003 WRX
Default Oil light occasionally flashes........why?
The oil light on my 03 wrx occasionally flashes very briefly.........for a second if that. Seems to only happen when i'm slowing down. Just before I come to a complete stop.......not always......just sometimes
Got an oil change about 1450 miles ago at the local dealer......I checked the dip & oil seems fine........what could be the cause?
This just recently started happening.......probably within the last 500 miles.
It has 61,500 miles on the odo. Car is lightly modded with the basic stuff; up-pipe, shorty downpipe, axleback, y-pipe & ecutek, lowering springs, 17" wheels & tires.
riverarob is offline   Reply With Quote
Old 12-05-2005, 07:01 PM   #2
dru_hill
Member#: 67661
2004 WRX sedan
If you're not actually low on oil (big if), my first thought would be the light is messed up. The only other way oil pressure could be low is if something is wrong inside the engine, and usually that is something not good. I dont know where the sender is for the light, but that would be my starting place, maybe there is some goo in there and its messing it up or something.
dru_hill is offline   Reply With Quote
Old 12-05-2005, 07:12 PM   #3
boxxxer
Member#: 84647
Have this checked out IMMEDIATLY! It's probably just a faulty sender, but it's too much of a risk to not be sure.
If the oil pressure is indeed going low enough to signal the light, then your motor does not have long to live. An independant mechanic should be able to put a hand held guage on it for short money and time to confirm all is o.k. and it's just a sender.
boxxxer is offline   Reply With Quote
Old 12-06-2005, 03:21 AM   #4
realwomble
Member#: 49305
2002 Stg.2 WRX Wagon
IIRC the stock oil warning light comes on at <= 2.5psi oil pressure... scary low. On a warm engine at idle, pressure should be ~30psi, and ~70 under load.
Sender is behind/beneath the alternator.
realwomble is offline   Reply With Quote
Old 12-06-2005, 03:24 PM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
22.5psi it's a pretty standard oil pressure switch
the senders are known for going bad but as was stated...it's not worth finding out the hard way
Old 12-06-2005, 07:20 PM   #6
riverarob
Member#: 44973
2003 WRX
I've got an appointment set for the weekend at Mastro in Tampa........put in half quart of oil in the meantime & i'll monitor it closely until the weekend.........i've never had an oil consumption problem before & i just recently had the oil changed 1500 miles ago so i find it hard to believe that it would burn up so much oil in that time.........anyway i swear the dipstick on this car is very hard to read or perhaps something is wrong with the dipstick trying to read it
thanks for the help.........i'll post their findings & i'm definitely investing in a proper oil pressure gauge
Old 12-07-2005, 04:15 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
yes the dipsticks on these cars suck to read, you really need to have the car hot to get a good solid idea of where the oil is at. start it up, shut it off and check it don't wait 30 minutes like people say to, that's just a bad idea
'00 RS: Headlight switch is fishy, lights occasionally turn off Siper2 Electrical & Lighting 4 09-06-2006 12:09 PM
AT Oil Light flashing.... metalsman Newbies & FAQs 7 03-26-2006 10:38 PM
When Cold Low Oil Light comes on. Anyone know why? nos Service & Maintenance 18 02-07-2005 10:25 AM
The security light on my dash is flashing...why?? mgc9876 General Community 10 11-11-2004 03:57 AM
Flashing Oil Light? sen New England Impreza Club Forum -- NESIC 11 04-01-2004 01:26 PM
