Old 12-06-2005, 12:25 AM   #1
ScubyMedic
Member#: 98203
2005 Spaceship/03WRX
both WRB
Default CEL is ON, Got Code, dunno what to do now....
Ok all, I need help finding out what the heck is this....
My 2002 2.5RS Sedan is Pulling this:
P0037
I do have a Aftermarket Catback on the car, and a Cold Air Intake...
I bought the car salvaged, and have been fixing it. everything is almost done, and i stuck a 05 STi front end on it. Im not sure what kind of Air intake i have, or Catback, but i do know that the catback is completely welded except where it hooks up to the cat.
Please let me know if you guys can help me,
Thanks
Drew
ScubyMedic is offline   Reply With Quote
Old 12-06-2005, 12:43 AM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
...rear o2 heater circuit malf.....
Old 12-06-2005, 02:02 AM   #3
ScubyMedic
Member#: 98203
both WRB
lol, im kinda slow, so that means i need to buy 02 sensor for the rear?
Please clarify this for me,
Thanks
Andrew
Old 12-06-2005, 07:15 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Check over the wiring to the rear 02, it might have been damaged in an accident or when the car was towed or dragged. Could also be the sensor itself but you should look for other causes before spending the $ for a new sensor.
Old 12-06-2005, 10:22 AM   #5
ScubyMedic
Member#: 98203
both WRB
Default hmm....
Well the thing is, the car was hit in the front. Also im not exactly sure where the sensor or wiring would be. ive just gotten into doing body mechanics so im not really sure where everything is. Do you, or anyone, think you guys can post a pick of where it would be....?
Thanks
Andrew
Old 12-06-2005, 11:19 AM   #6
JimBlake
Member#: 82247
2005 Saab 9.2x Aero
satin grey
What's the proper resistance for the sensor heater (Mulder?) Medic; got a multi-meter?
The 2 same-color (black?) wires on the sensor are the heater. Measure resistance between them. On Hondas it should be 15 to 40 ohms, I don't know about Subies, maybe the same? Neither of those wires should have any continuity to ground (to the metal body of the sensor). If that's not OK, get a new sensor. Otherwise start looking for screwed-up wiring for that circuit.
JimBlake is offline   Reply With Quote
Old 12-06-2005, 10:04 PM   #7
ScubyMedic
Member#: 98203
both WRB
lol, im not too sure, but i think the guy who put the Catback on the car before me, took out the sensor .... Cuz i dont see anything....
Maybe im just blind, or stupified , someone help me out here, post a pick of yours.....
Old 12-07-2005, 12:15 AM   #8
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Here's a pic of my ERZ with the sensor sticking out of it. I don't have it in the car anymore, and it doesn't matter because my AP makes up for it's absence. So, it sounds like you need to either buy an AP or some other form of EM, or look into the appropriate mods to make up for a missing rear O2 sensor. I would suggest the unabombers manifesto as a starting point.
specialev is offline   Reply With Quote
Old 12-10-2005, 10:14 PM   #9
ScubyMedic
Member#: 98203
both WRB
Hey all, i need some more advice. Someone i know has a 2005 2.5rs thats smacked up. He only has 10,000 miles on the car, and hes getting rid of it. He did tell me he had the 02 sensor that i need. But the only thing is mines a 2002, and im unsure if it is the same. Can someone let me know if the 02 and 05 rear 02 sensors are the same? Thanks
Andrew
Old 12-10-2005, 10:43 PM   #10
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....didya get my PM????......and did it help????
...and look at the plugs on the sensors....match =
Old 12-10-2005, 11:30 PM   #11
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
In response to your PM to me.
Check the numbers on the one your friend has vs. the one you have, if they match then they are the same part. If the plugs are different and the numbers match, it is the same sensor but you will have to solder your plug onto the new sensor.
Got a flat... what to do now? thsiao Tire & Wheel 11 07-17-2006 02:25 PM
Got a flat... what to do now? thsiao Tire & Wheel 2 07-16-2006 10:24 PM
dunno what to do now... ScreaminFast Factory 2.0L Turbo Powertrain 5 09-09-2005 09:34 PM
I got the best xmas present ever and I dunno what to do b_tapper Off-Topic 218 12-27-2004 04:35 PM
2.5 overheating, dunno what to do, please help ! NicEJ25 Normally Aspirated Powertrain 9 08-22-2003 03:48 PM
Message Board Statistics All times are GMT -4. The time now is 05:48 PM.
