Old 12-06-2005, 01:51 PM   #1
nosajh9
Member#: 85435
02 Impreza RS 2.5L
Default should i switch for winter?
i was thinking of swithching to 5w30 for winter, been using 10w30, but wanted to know if it will benefit anything, or should i just stick with the 10w30 i been using? this morning here in akron ohio it was 8 degrees, but our winters here are real wacky. it might be 50 degrees tomorrow!
nosajh9 is offline   Reply With Quote
Old 12-06-2005, 02:46 PM   #2
z&cobb
Member#: 12344
2002 2JC
blue
If you check your manual, you will see that both are OK at 8 deg F. If it doesn't get much colder this winter, you should be OK. . If you anticipate a lot of very cold morning starts in the minus F zone, 5w would flow better cold and make it a little easier to crank the engine on a cold battery.
z&cobb is offline   Reply With Quote
Old 12-08-2005, 07:53 AM   #3
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
Are you using synthetic or conventional oil? If synthetic, either should be fine for winter (although I'd probably drop down to the 5w-30 or even 0w-30). If you're talking about conventional oil, I'd definitely drop down to 5w-30 for the winter.
AndyH is offline   Reply With Quote
Old 12-08-2005, 12:29 PM   #4
TurboRoo
Member#: 53299
2015 Don't forget
a towel!
I switch to 5w30 for the winter months and then go back to 10w30 for summer and use mobil 1. I switch during a regular oil change interval when it gets close to winter, or however it works out, and the same thing for spring.
TurboRoo is offline   Reply With Quote
Old 12-08-2005, 12:35 PM   #5
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
^^I've been doing that for a while, although I've recently made the switch to German Castrol Syntec 0w30 all year around. The 0w30 is surprisingly thicker than even the M1 10w30 in the summertime!
volkl23 is offline   Reply With Quote
Old 12-08-2005, 11:19 PM   #6
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Look at his car, guys. 5w30 might be a little thin for a 10-yr-old 1.8
nosajh9: You can try it but keep an eye on the level; it might burn more of that thin an oil.
Mike Wevrick is offline   Reply With Quote
Old 12-09-2005, 11:12 AM   #7
TurboRoo
Member#: 53299
2015 Don't forget
a towel!
I did notice his car but seeing how I donít know much about the 1.8ís I meant in general terms. Most my knowledge right now is with the wrx 2.0. I know for my car 5w30 is a bit thin but ok and will cause increased oil consumption. I would have mentioned that but seeing how Iím not sure about the 1.8ís I meant in general terms. And yes with 5w30 I do notice increased oil consumption. I do know that boxer engines in general will burn oil and as a rule of thumb check the oil level frequently. Iím not a guru yet but Iím learning.
Old 12-12-2005, 02:40 PM   #8
nosajh9
Member#: 85435
02 Impreza RS 2.5L
i just changed the oil and put in the valvoline maxlife 5w30. i cant seem to find anything that says this is bad or good. maybe i should have just stayed with the 10w30. i guess ill just have to be extra careful and check my oil more often with the 5w30 in it. also, arent the "high mileage" oils actually a little thicker than conventionals with the same weight?
Old 12-12-2005, 04:00 PM   #9
poison
Member#: 37678
It depends on the specific oil and maker. High milage oils are very robust and have lots of detergents and other additives, generally a good thing.
poison is offline   Reply With Quote
Old 12-12-2005, 07:57 PM   #10
bluesubie
Member#: 767
04 FXT
MaxLife 5W30 (synthetic) is a tad thicker than M1 5W30 (even after M1 recently thickened it up). Castrol GTX High Mileage 5W30 (dino) is thicker than both. All high mileage oils aren't necessarily synthetic, fyi. Check the manufacture spec data sheets to compare thickness.
-Dennis
bluesubie is online now   Reply With Quote
Switching over to 0w-30 Semi-Synthetic for Winter? Zac86 Normally Aspirated Powertrain 3 12-18-2009 06:59 PM
hmmm What color should I powdercoat my factory 05 16" wheels for winter use? tacomaprime Interior & Exterior Modification 3 07-23-2009 11:36 AM
What oil should i use for California winter? Hyelude Newbies & FAQs 4 12-20-2008 02:54 AM
How high should i raise my car on coilovers for winter fastlanerex Brakes, Steering & Suspension 14 12-09-2007 06:41 PM
Switching oil from M1 15W50 to X for winter wrxrex Newbies & FAQs 5 09-30-2007 08:22 AM
