Old 12-07-2005, 12:15 PM   #1
SlimSE
Member#: 102000
Default Does anyone use a oil extractor (Tempo Oil boy) when doing a oil change
Did a search and came up did not come up with anything on this board. Do any of you use Tempo Oil Boy. On the acurazine borad, a lot of guys use it. Now I have a Subaru also and wondering if it is possible to use oil extractor on it. Any help will be great.
SlimSE is offline   Reply With Quote
Old 12-08-2005, 12:37 PM   #2
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
What's the benefit of using an oil extractor over the traditional method?
volkl23 is offline   Reply With Quote
Old 12-08-2005, 01:57 PM   #3
blitzoid
Member#: 31276
1998 Forester L
Green
Mostly, it's just a lot cleaner, and easier to take care of disposal.
On some cars (my former VW TDI being one of them) the oil filter is topside, so with an extractor, you don't have to get the car up on ramps, get down on the ground, etc. On a VW in paticular, with that annoying plastic lower shield, held in by a dozen torx screws, it was really helpful. You also don't run the risk of stripping the drain bolt in the pan, if you're concerned about that sort of thing (again - vw had an aluminum pan with a steel bolt - it was a fairly common problem if you overtorqued the bolt)
Since the filters are down on the bottom for subarus, there's little value, IMO.
Only other advantage is that you can usually get a little more oil out with the extractor than you would using the normal method.
Oh, and if you overfill, by chance, it's easy to remove a little bit of oil.
I had used a Pela back in the day. Cost around $45.
blitzoid is offline   Reply With Quote
Old 12-10-2005, 07:57 PM   #4
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
Ah, I see. Wow, what a pain in the ass to have the oil filter topside!
Old 12-11-2005, 11:44 AM   #5
blitzoid
Member#: 31276
1998 Forester L
Green
Not really - VW actually got it right with that one. Instead of a cartridge filter, like on a subaru, the VW filter is a replacable paper/fabric element and the housing stays attached to the engine. You simply screw off the lid of the housing, pull out the paper filter into a plastic bag (it's like taking a pickle out of a pickle jar) and that's it.
Blindingly simple, and if you're careful, and use an extractor, you never get dirty.
Old 12-11-2005, 07:20 PM   #6
DChan
Gone... But not forgotten
Member#: 60342
2004 STi
I have one that I bought from Griots Garage and it does not work. You can't get to the bottom of the oil pan through the dipstick with our subies. It works fine on all other cars though.
DChan is offline   Reply With Quote
Old 12-12-2005, 12:51 AM   #7
mn1028
Member#: 33590
2005 Impreza WRX STi
I am glad you said that, because I was going to order the one from Griots Garage this week.
mn1028 is offline   Reply With Quote
Old 12-12-2005, 01:20 AM   #8
SlimSE
Member#: 102000
Thanks DChan!! I was wondering it would work for the Subaru or not. It works great for Acura. I guess it is the old fashion way for the Subaru.
Old 12-12-2005, 07:10 AM   #9
DChan
Member#: 60342
2004 STi
Yeah they work great on every V or inline motor I've tried it on. Even though it doesn't work for Subies, it is still one of my favorite tools in the garage.
Does anyone use or recommend using ZDDPlus? Forcedinduction Service & Maintenance 10 07-28-2009 10:05 AM
Does anyone know how to shut off a/c when the front defogger is on? awdlifestyles Electrical & Lighting 18 10-09-2005 07:32 AM
Exhaust- Does Anyone Use This Sesame Street Racing Bay Area Impreza Club Forum -- BAIC 1 07-18-2002 08:01 PM
Does anyone feel a thump in the rear end when you shift Boom New England Impreza Club Forum -- NESIC 6 06-19-2000 07:01 PM
