Old 12-07-2005, 12:47 PM   #1
nosajh9
Member#: 85435
02 Impreza RS 2.5L
Default changing spark plugs on 1.8L
is changing the spark plugs on my 95 1.8L easier than changing them on the 2.2L? also, the wires look fairly new, so im assuming the plugs are ok, but might as well change them, not sure when they were changed, bought the car about a year ago and havent replaced anything but the oil and air filter. planning on changing the oil this weekend, replacing the fuel filter, pcv valve, air filter, spark plugs and draining and refilling my rear diff fluid. i already did the drain and refill on ATF for the 4eat, so that doesnt need done.
nosajh9 is offline   Reply With Quote
Old 12-07-2005, 01:18 PM   #2
Max Umbarger
Member#: 1112
2006 FXT
RBP
I think they both are easy, but the EJ18 is definately easier because the SOHC put the plugs on top at an angle.
Prolly take you 45 mins to an hour the first time. Just deciding what to take off for your likeing and what not.
Max Umbarger is offline   Reply With Quote
Old 12-07-2005, 01:42 PM   #3
nosajh9
Member#: 85435
02 Impreza RS 2.5L
sweet, anything easier is nice! should i even change my plugs and wires? the car runs fine, and like i said, the wires look new, so im assuming whoever changed the wires probably changed the plugs too. the pcv valve im gonna change, doesnt look as if it has ever been changed. rusty. ill change the air filter and the fuel filter also i think. just cant decide on the plugs and wires. if i decide to change these , i was gonna use the v-power NGK's. also, i was gonna drain and refill my rear diff. fluid. where is the front diff. fluid? i have an automatic transmission (4eat), is there a front diff., or is that part of the transmission?
Old 12-07-2005, 03:13 PM   #4
Max Umbarger
Member#: 1112
2006 FXT
RBP
I'd go ahead and do it. It's cheap insurance. It's up to you tho, plus wires can look good and clean for a while, my wrx still has the stock ones and they look great still with 60K on them. I don't keep the engine bay tidy either, granted I don't thrash tho either!
Just go get some $2/pc NGK BKR6E plugs when you go pick up a PCV valve. Car will be running awesome for under $15!!!
thanks
MAX
Changing Spark Plugs on a Tuned STI Ray_STi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 12-16-2008 12:50 AM
Changing spark plugs on 06-07 models Sausage Service & Maintenance 6 11-02-2007 01:05 PM
A shop to change spark plugs on a WRX for less than $200 stees South East Region Forum 14 08-24-2006 11:18 AM
ne1 here know how to change spark plugs on wrx? Benjamin Tang Vancouver Impreza Club Forum -- VIC 12 05-30-2004 12:50 AM
How to Change spark plugs on a Phase I DOHC? yebokmj Normally Aspirated Powertrain 5 01-21-2001 04:44 PM
