Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 12-07-2005, 09:45 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Shifter Bushings, Tranny Mounts, Tranny Rebuild Kits, JDM 5th / 6th Gear Conversions!
1) JDM 5th and 6th Gear Close Ratio Conversion Kit - 04+ STi
The USDM 6-speed transmission was compromised by stringent US regulations for cruising fuel efficiency. Sacrificed was the close ratio gearing of the JDM 5th and 6th gears. This kit includes shorter 5th and 6th gears to convert your taller USDM 6-Speed Transmission to a true close ratio JDM STi spec gear box; the way it was designed to be. This conversion will be particularly useful for those of you who regularly track or drag race your car. As I'm sure you've noticed, their is a large space in gear ratios between 4th and 5th gears on the USDM 6spd. This oftentimes causes a grinding when shifting from 4 to 5 quickly because the synchros cannot catch up quickly enough to compensate for the large difference between gear ratios. Professional installation is recommended.
- Excellent upgrade for motorsports guys
- Better accelleration in 5th and 6th gear.
- Eliminates grinding when shifting up from 4th to 5th gear
- Restores 6 spd. to intended gearing
Ratios:
-5th Gear - 1.062 (0.971 stock)
-6th Gear - 0.842 (0.756 stock)
$319 Shipped for 5/6th Gear Conversion
$769 for rebuild w/ 5/6th Gear Conversion
2) Genuine Subaru Synchro & Bearing Kit for 6 Speed Manual Transmission (13 pcs) - 04+ STi
We have packaged together the most commonly damaged synchros and bearings for the Subaru STI 6-speed transmission. In all likelihood, if a transmission rebuild is necessary, these synchros and bearings also need to be replaced. Replacing these synchros and bearings can also cure many "mystery" gear box issues such as, "why does my tranny always grind going into 3rd gear," or "how come I sometimes can't shift down into 2nd gear." These are in stock and ready to ship. You can also send us your 6spd. to be rebuilt with these.
- Should be replaced when rebuilding your tranny
- Cures many transmission gremlins
$419 Shipped for Synchro and Bearing Kit
$869 for rebuild w/ new Bearing and Synchro Kit
Save money if you do both at the same time!
$719 Shipped for Synchro and Bearing kit, and 5/6th Spd. Conversion
$1149 for rebuild w/ new Bearing and Synchro Kit, and 5/6th Spd. Conversion
STi Transmission Mount - GDA 02+
$69 shipped !
The STI "Group-N" Transmission Mount is designed to reduce excessive motion of your transmission during shifting and launching. This is done by increasing material stiffness over your stock transmission mount. By decreasing this type of motion, more energy is focused to the drivetrain and chassis rather than spent twisting your transmission. These should be replaced with your engine mounts.
Cusco Shifter Bushings - 02+ WRX / 04+ STi
-The Cusco Shifter Bushing is designed to replace the soft rubber bushing found at the anchor point of your shifter assembly. This upgraded bushing greatly improves the feel of the shifter by eliminating that spongy feel you get when changing gears.
$37 shipped!!!
Thanks,
Preston
Phone: (510) 783-5300
We Accept Paypal!
Paypal: [email protected]
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Preston/Geoff
Price including shipping: $XXXX
Shipping address.
Gruppe-S is offline
Old 12-07-2005, 09:46 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
1) Exedy Organic Clutch Kit and Steetlite Flywheel - 02+ WRX
-Clamp Load: 2300 lbs/ft.
-Pressure Increase: 44% over stock clutch.
-Weight: clutch - 14.3lbs, flywheel - 13.9 lbs.
$750 Shipped!!!
$1175 Installed!!!
2) Exedy Hyper Single Clutch/Flywheel Kit - 02+ WRX
-Clamp Load: 2655 lbs/ft.
$PM FOR BEST PRICE!!!
3) Exedy Hyper Single Clutch/Flywheel Kit - 04+ STi
4) Exedy Twin-Plate Clutch/Flywheel Kit - 04+ STi
-Clamp Load: 2205 lbs/ft.
Thanks,
Preston
[email protected]
510-783-5300
Gruppe-S is offline
Old 12-07-2005, 09:47 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
1) ACT HD Street Disc Kit and Steetlite Flywheel - 02+ WRX
-Torque Capacity: 411 lbs/ft.
-Pressure Increase: 32% over stock clutch.
-Weight: clutch - 17lbs, flywheel - 13.9 lbs.
$649 Shipped!!!
$1100 Installed!!!
2) ACT HD Street Disc Kit and Prolite Flywheel - 02+ WRX
-Weight: clutch - 17lbs, flywheel - 9.6 lbs.
$699 Shipped!!!
$1119 Installed!!!
3) ACT HD Street Disc Kit and Steetlite Flywheel - 04+ STi
-Torque Capacity: 475 lbs/ft.
-Weight: clutch - 17lbs, flywheel - 15 lbs.
$855 Shipped!!!
$1275 Installed!!!
4) ACT HD Street Disc Kit and Prolite Flywheel - 04+ STi
-Weight: clutch - 17lbs, flywheel - 11.1 lbs.
$879 Shipped!!!
$1299 Installed!!!
And for the hardcore guys out there:
5) ACT HD 6 Pad Race Kit and Prolite Flywheel - 02+ WRX
-Torque Capacity: 527 lbs/ft.
$699 Shipped!!!
$1119 Installed!!!
6) ACT HD 6 Pad Race Kit and Prolite Flywheel - 04+ STi
-Torque Capacity: 608 lbs/ft.
-Pressure Increase: 35% over stock clutch.
$819 Shipped!!!
$1239 Installed!!!
Thanks,
Preston
[email protected]
510-783-5300
Gruppe-S is offline
Old 12-12-2005, 12:47 PM   #4
mnavarro
Member Sales Rating: (2)
Member#: 51537
2004 WRB WRX STI
62 Corvette/11 Cherokee L
Can you guys get the Spec clutches. How do these compare to the act. My stock clutch is slipping a little in 4/5 gears and I know the pedal feel of the act is extremely firm.
mnavarro is offline
Old 12-13-2005, 03:59 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
mnavarro - Pm sent
thanks,
Preston
Gruppe-S is offline
Old 12-22-2005, 12:00 AM   #6
erice1984
Member Sales Rating: (5)
Member#: 11778
1980 VWRabbit Diesel
w/AAZ Swap
do you guys have stuff for the good 'ol 98-01 2.5rs's??
I have a 2000, and i am looking for a act street/strip clutch and the streetlite flywheel.
Thanks
-Eric
erice1984 is offline
Old 12-22-2005, 06:28 PM   #7
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Eric - PM sent
thanks,
Preston
Gruppe-S is offline
Old 12-24-2005, 01:52 AM   #8
sinNinWRX
Member Sales Rating: (1)
Member#: 69786
04 WRX
any deals on the synchros and bearings for a 5 speed? any ra gears in stock? thanks.
sinNinWRX is offline
Old 12-24-2005, 01:36 PM   #9
mnavarro
Member#: 51537
2004 WRB WRX STI
Preston any news on the spec 3+clutch. I know i have to do this soon.
mnavarro is offline
Old 01-06-2006, 03:44 PM   #10
psyber_0ptix
Member Sales Rating: (25)
Member#: 60671
1992 Turbo Miata
351whp/344tq
+1 ON SYNCHROS AND BEARINGS
i need a set for an 02 tranny
psyber_0ptix is offline
Old 01-23-2006, 06:10 PM   #11
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bearings and synchros for 5spd both in stock; $499 shipped. No RA gears in stock right now. Best to preorder these as there's usually a 2-4 week wait time on them because they're eternally backordered from SOJ.
Thanks,
Geoff
Gruppe-S is offline
Old 12-09-2010, 06:49 PM   #12
gaby
Member Sales Rating: (12)
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
How much for a 6spd jdm synchro set. Or just 5th gear synchro ?
gaby is offline
Closed Thread
perrin shifter bushings,22mm rear sway bar kit and stock intake for '08 2.5i heat7881 Engine/Power/Exhaust 1 05-29-2010 11:34 PM
WTB Kartboy SS, shifter bushings, Group N tranny mount, Walbro sicksubie NESIC Private Classifieds 8 04-21-2009 02:49 PM
Possible AVCR Problem in 5th and 6th Gear on JDM Ver 8 SSFWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 12-11-2006 02:55 AM
JDM 5th Gear and USDM 6th Gear Hybrid pzary3233 Transmission (AT/MT) & Driveline 12 03-07-2006 11:43 AM
1 STi 6 spd Tranny in Stock! JDM 5th/6th Close Ratio Conversion! Clutches! Gruppe-S Drivetrain 6 10-18-2005 05:58 PM
