Old 12-10-2005, 04:39 AM   #1
BBBsti LTD
Member#: 71682
2007 WRX Sti LTD.
Default Omori EGT installed two days ago and already gone!!!!
I got installed my OMORI Boost ang Egt gauges yesterday and my EGT is going crazy specially when the car is cold and the warning led in also blinking a lot.
I want to know if the problem is caused by the gauge or by the probe.
Once the car warms up the gauge is a little better but still crazy.
Any sug.????????
BBBsti LTD is offline   Reply With Quote
Old 12-10-2005, 09:13 AM   #2
Gethin
Member#: 2998
where did you tap the probe?
Gethin is offline   Reply With Quote
Old 12-10-2005, 10:05 AM   #3
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Had the same problem-
Make sure that you route the wire from the probe to the gauge so that it doesn't get wet. When it does get wet, the gauge flakes out.
Mike
crazymikie is offline   Reply With Quote
Old 12-10-2005, 11:05 AM   #4
BBBsti LTD
Member#: 71682
2007 WRX Sti LTD.
Cilinder #4 was tapped. I did not wash the car and no water or rain on it!!!
Old 12-10-2005, 11:47 AM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
how stable is the power supply to the gauge? check your power and grounds. double check the probe connections to the gauge.
Old 12-10-2005, 12:42 PM   #6
BBBsti LTD
Member#: 71682
2007 WRX Sti LTD.
I'm really up set I just drove my car for 20 min. and from the first min. to 10 min the gauge was ABSOLUTLEY of control. After that the gauge is still crazy bouncing and the warning led blinking.
The gauges was installed by one of the most reputable shops in So Cal Sby Specialties.
Also I notice some loss on the power in the lights in the dash they are weak
maybe there is some kind of prob. with the wiring???
Old 12-10-2005, 12:52 PM   #7
line
Member#: 76189
WRX: Parking Lot
Racer in Training
What are you talking to us for then just take it back. If they are reputable they will see its not right and fix it.
line is offline   Reply With Quote
Old 12-10-2005, 12:56 PM   #8
twentynine
Member#: 96176
'05 WRX
+1
It seems the most common cause of needle bouncing with these gauges is a weak ground, leaking tap or shot probe.
How did you wire your gauges into the electrical system? Did you use an actual 1/8 BSPT tap to thread the hole, or did you use a 1/8 NPT and try to ram it in there?
My first probe went after three days.
Oh, and hi Mike. Thanks again for the help with my EGT probs. I'm going to try to get my gauges and probe replaced at j-spec.
/edit
Ah nevermind. Well, it wouldn't hurt to ask these questions at Suby Specialties I spose.
twentynine is offline   Reply With Quote
Old 12-10-2005, 02:58 PM   #9
WRX-CBR
Member#: 82197
03 WRX
+1...
WRX-CBR is offline   Reply With Quote
Old 12-10-2005, 04:58 PM   #10
subenerd
Member#: 72630
2004 STi
A few mornings ago after rain and really cold weather (frost all over the doors and windows) my omori egt was going nuts! But after 10+ minutes of driving and warming up it was back to normal. I would take it back and see what your shop can do for you
subenerd is offline   Reply With Quote
Old 12-10-2005, 08:31 PM   #11
Bman
Member#: 64351
2005 Legacy GT
Mine had the same problem, what fixed it for me was to push in the connector between the probe wire and the guage wire a little farther.
Bman is offline   Reply With Quote
Old 12-11-2005, 06:11 AM   #12
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
I am not buying this EGT setup....LOL!
sixpack subaru is offline   Reply With Quote
Just bought my bug eye 5 days ago and the motor blew already!!!! sexyWReXy Pre-2002 Factory Turbo Powertrain 12 10-22-2007 09:09 AM
P0519??? Just changed plugs two days ago, IACV bad? Zeker555 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-20-2006 07:07 AM
So, got Lasik two days ago. caseynsb Off-Topic 26 11-04-2005 12:59 PM
ok... two days ago it was almost 70.... now its snowing KevinHeist Texas Impreza Club Forum -- TXIC 19 12-23-2004 12:33 PM
