Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 12-10-2005, 07:23 PM   #1
trbowrx
Member#: 50770
08 STi
04 536whp STi Sold!
Default Oil Question?
Well here is the deal.... i have a sti that i bought used from a member on this forum (Backedcookies) and he used just regular oil in his car since he got it instead of synthetic. now in my 2002 wrx i only ran Mobil 1 synthetic, and i was wondering if i would cause some damage by switching over to synthetic? the car has 37000 miles on it and does not have a oil burning problem. so just some input would be nice on a good oil to use or a good non synthetic oil? thanks so much.
Paul
trbowrx is offline   Reply With Quote
Old 12-10-2005, 07:58 PM   #2
WR^2X
Member#: 37617
You'll probably be fine switching to synthetic. 87,000 miles would be a different story.
Use Mobil 1.
WR^2X is offline   Reply With Quote
Old 12-10-2005, 08:07 PM   #3
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
you'll be fine. 37k is still young for an engine.
volkl23 is offline   Reply With Quote
Old 12-11-2005, 12:03 AM   #4
mystiwip
Guest
Member#:
i switched to mobil 1 at 5k, after knowing that the sti burn oil (mobil 1) like its drinking water, i went back to use the regular oil
Old 12-11-2005, 12:06 AM   #5
WR^2X
Member#: 37617
Interesting... I switched at 10K and mine doesn't use a drop.
Old 12-11-2005, 12:48 AM   #6
Helium
Member#: 102393
Default Synthetic switch
Why is it bad to switch after such high mileage? I have 20k and I am thinking about switching on my next change, but I am unsure at the moment if I want to do that..
Helium is offline   Reply With Quote
Old 12-11-2005, 01:04 AM   #7
Idahoser
Member#: 78147
93 impreza 4dr
280.000 and runs 100+
If you change your oil when it first turns color whatever the mileage is and dont run it dirty and grunge up your insides you should be able to go synthetic whenever you want to. 5 K isnt enough dino time to seat the rings properly- I usually wait until 10. I have an older dodge pickup here that has 150 K on it and we had to refresh the rear main at about 90- outside of that its perfect inside. Cam, bearing inserts, valve seals all look like new and the previous owner ran synthetic only after the initial break in. Does not use a drop of oil. Granted synthetic does not have the viscosity of regular oil so you tend to lose pressure- but its worth it.
Idahoser is offline   Reply With Quote
Old 12-11-2005, 01:11 AM   #8
silverlegacy
Member#: 90877
My lgt doesn't burn a sip, and i put in amsoil at 1500
silverlegacy is offline   Reply With Quote
Old 12-11-2005, 07:25 AM   #9
005sti
Member#: 78293
DP stockcatbckpro-
tune301wtq 289.7whp 93oct
"Q" quaker state 10w-30 full synthetic
005sti is offline   Reply With Quote
Old 12-11-2005, 12:29 PM   #10
ivwarrior
Member#: 100610
MBP
I hear this alot, but is there really any truth to it anymore? Don't the Chevy Corvette and some others come from the factory with synthetic?
ivwarrior is offline   Reply With Quote
Old 12-11-2005, 12:56 PM   #11
poison
Member#: 37678
So much disinformation in this thread, geez. Ya'll need to head over the www.bobistheoilguy.com to bone up on oil facts.
You can switch to synthetic anytime after, say, 5-10k (depending on who you choose to believe) all the way up to 100k+. How your engine responds is a matter of the individual engine, how its been driven, what oil was used and at what intervals, etc.
Many times a late switch to synthetic will start a leak. People panic and return to dino (regular) oil. The fact is that dinos can sludge; and synths burn much cleaner and have more detergents. So many times the superior cleaning power of the synth cleans sludge out that was plugging leaks from shrunken or aging seals and gaskets. A leak starts, of course, and the oil is dumped in panic.
If the synth had been left in for 2-3 oil change intervals, the conditioners in the synth would have plumped up the old gaskets and stopped the leak, all the while providing a cleaner engine and superior protection.
What do you guys think: that if you put in synth and there's a slow leak, your car will implode? Just give it a couple OCI's to give the synth time to work. If, in the end, it doesn't, go back to dino. But at least try to take advantage of synthetics superior protection.
poison is offline   Reply With Quote
Old 12-11-2005, 08:44 PM   #12
Idahoser
Member#: 78147
93 impreza 4dr
Thumbs up
I agree totally. If its good enough for the friggin space shuttle- its good enough for me.
Old 12-19-2005, 08:21 AM   #13
BakedCookies
Member#: 21543
2016 WRX Limited
Red
Originally Posted by trbowrx
Well here is the deal.... i have a sti that i bought used from a member on this forum (Bakedcookies) and he used just regular oil in his car since he got it instead of synthetic. now in my 2002 wrx i only ran Mobil 1 synthetic, and i was wondering if i would cause some damage by switching over to synthetic? the car has 37000 miles on it and does not have a oil burning problem. so just some input would be nice on a good oil to use or a good non synthetic oil? thanks so much.
Paul
Paul, I dont recommend switching, when i ran it the car was drinking a quart every 2-3 weeks. Switched back to dino and the issue went away. I have read numerous threads that suggest never running synthetic in an STi
BakedCookies is offline   Reply With Quote
Old 12-19-2005, 11:42 AM   #14
poison
Member#: 37678
You're kidding, right?
I bet you ran Mobil 1, huh? If you paid attention, you'd read that Mobil 1 disappears very quick in many Subarus. It's thin and shears down quick. But that's no reason to switch to an inferior dino in a what is essential a race car with a highly stressed turbo-charged engine (though subarus have excellent design and are not as highly stressed as some).
You should've either 1) kept topping off the same oil, or 2) switched to a better synthetic for your application (novel, huh?).
Assuming the car is not ****ed up in some way, I'd put money that GC 0/30 or Mobil T&S 5/40 would NOT lose more than a half-1 quart over 5k of normal driving.
Old 12-28-2005, 07:49 PM   #15
NjRx7T2
Member#: 80866
05 Stock STi
CGM
Subaru Stars
Well, I drive an 05 STi and my dealer does my oil change free for life and I was told they used the regular oil... Here's the thing, I'm gonna be doing my own oil change comes spring time for more aggressive driving (on the track, of course! ) and I'm planning on using perhaps the Quaker Synt. Now, is there gonna be a major problem other than the usual leaking? I now have almost 10k miles so that means my car will have about 13k miles after 3 months.. Is it even recommended to do so at this point? What will be the affect of switching back to regular oil (remember, free!) when winter comes again? Thanks for the input!!
Chad of Nj.
NjRx7T2 is offline   Reply With Quote
Oil filter and Oil question blue89turbo Service & Maintenance 3 06-12-2009 12:04 AM
another burning oil question/disappearing oil..haha blowbyu24 Built Motor Discussion 3 08-07-2007 06:31 PM
Gear oil question dandbest Normally Aspirated Powertrain 16 04-13-2001 11:13 PM
oil questions kastle SVX Forum Archive 3 11-11-2000 03:08 PM
Stupid Oil Question Jon Bogert Newbies & FAQs 8 10-20-2000 01:15 PM
