Old 12-10-2005, 11:52 PM   #1
cringeR
Member#: 80100
2008 STi
SSM
Question Do HID bulbs change color just before burning out?
Maybe this is a stupid question but i noticed tonight that one of the lights on my jdm hid's has changed color from the normal bluish tint to an orangish/pink. It seems that the light output has faded quite a bit as well. I'm just wondering if this is typical of hid bulbs when they die or if i should be checking to see if something else is awry?
cringeR is offline   Reply With Quote
Old 12-10-2005, 11:54 PM   #2
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
HID bulbs will typically go through a "color shift" phase after certain amount of hours.
Check this thread for some great info:
http://forums.nasioc.com/forums/show...ht=color+shift
Hank3 is offline   Reply With Quote
Old 12-11-2005, 12:17 AM   #3
cringeR
Member#: 80100
2008 STi
SSM
thanks. This color shift is different from what was discussed in the link you gave me though. The color shift is EXTREME, one is 4300k bluish/white and the other is pinkish/orange now. Anyone have this happen to them?
I should add the hid's have been in my car for a year now and were obviously used when i got them. As i'm in Canada the light are on whenever the car is turned on as we must have daytime running light here in Canada.
Old 12-11-2005, 12:35 AM   #4
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
that me be the p[roblem...most owners will as a rule disable the drl's.... any pics?
ATX25RS is offline   Reply With Quote
Old 12-11-2005, 12:40 AM   #5
cringeR
Member#: 80100
2008 STi
SSM
no pics at the moment, i may be able to take some. Disabling the drl's is not an option for us. If anything i would think having the lights on all the time would just wear the bulbs out faster. Don't canadian hid systems just leave the lights on when the car is running as well? I seem to recall hearing that somewhere.
Old 12-11-2005, 02:18 AM   #6
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
also DRL leave the lights on. This does horrible things to the igniter. may also have an affect on the ballast. disconnect the DRL and just run with you rlight on. The DRL also lowers the voltage to the headlights.
Joe
scoobdude is offline   Reply With Quote
Old 12-11-2005, 03:39 AM   #7
CRXguy
Member#: 25370
2003 WRX wagon
Played Out Blue
i disabled my drl's, but i just leave the headlight switch to the parking light position. maybe you can wire the fog lights to come on with the parking lights as a substitute for the low beams. that's what i wanted to do, but im too lazy. its cheaper to replace fog light bulbs than hid bulbs.
CRXguy is offline   Reply With Quote
Old 12-11-2005, 09:31 AM   #8
Impreza2003
Member#: 67247
2003 2.5RS BRP
SQC 189
sometimes they turn pink, other times they just die.
if your worried just look at your bulb and in that buldge in the middle, if its clear ot hazy your fine, if its dark then its dead or going to be dead
Impreza2003 is offline   Reply With Quote
Old 12-11-2005, 11:10 AM   #9
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
its best if you turn the lights on AFTER you start the car. I forgot why but it puts alot of stress on teh bulbs if you leave them on while starting. causes them to blow out quicker. its even worse on the DRLs cause they already have a lower voltage.
Joe
Old 12-11-2005, 06:49 PM   #10
cringeR
Member#: 80100
2008 STi
SSM
OK well, the light is out now on the one side, so i guess i know it was burning out. Did some research and ordered some 4100K oem Philips D2S replacements from HIDPlanet. Now we just have to drive with one light until they get here.
Old 12-12-2005, 10:59 PM   #11
shinsain
Member#: 51745
LIKE A
BOSS
Yeah, DRL's I believe place stock hallogens at 60% voltage - which = not good for HID's. Without the proper operating voltage there is stress on the bulbs/ballasts, etc. and I would imagine that will ruin parts of your kit quicker (obviously).
It is better to disconnect the DRL's and just remember to turn your lights on everytime you get in the car IMO (even though in Canadia that can get you a ticket if you forget).
Aaron
shinsain is offline   Reply With Quote
Old 12-13-2005, 10:50 PM   #12
cringeR
Member#: 80100
2008 STi
SSM
I'm pretty sure mine are connected so that when the ignition is turned on the lights come on at full Voltage. If i forget to turn my lights on at night the beam is just as bright as when i turn the headlights on, there's just no parking/running lights if the headlights aren't turned on. I bought the car from a good friend who had bought the HID's and installed them around a month before he sold me the car. I guess i'll just have to replace the bulbs more often as they get used alot more.
Old 12-14-2005, 12:35 PM   #13
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
important thing to remember is turn the lights on AFTER the motor has started. starting drops teh voltage WAY down to 7-10 volts. this has the same affect as teh DRLs. but its even worse because it flutuates during this time.
Good luck
Old 12-14-2005, 04:12 PM   #14
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
connecting and disconnecting a highly inductive load (like a starter motor) will cause pretty large voltage spikes in the electrical system of the car.
the ballasts of HID systems are small step up switch mode power supplies which do not like voltage spikes.
hth
ken
Non HID Bulb change EvoSpeed Electrical & Lighting 31 11-28-2007 11:38 AM
Why do hid bulbs cost same as entire kit? 2slofouru Electrical & Lighting 27 03-17-2007 09:10 AM
Q: how do u know if your cat is burned out when u have a BOV?? Azn-Jap STI Vancouver Impreza Club Forum -- VIC 2 03-23-2005 08:06 PM
why do my Morettes keep burning out bulbs? bleuquila Electrical & Lighting 9 04-07-2004 01:54 AM
STi Philips 6000K D2R HID bulb change, pics 909 Electrical & Lighting 6 10-24-2003 10:54 AM
