Old 12-11-2005, 12:57 AM   #1
Evil LTD
Member#: 102691
1993 Legacy
Unhappy no heat or defrost
new guy here. i'm posting this for my father as the scooby is his car. here goes
my dad has a 93 subaru legacy wagon. he has no defrost or heat. the fan isn't blowing at all. he says he checked the relays and he said there was no fuses in the car i'll look at it tomorrow, but i was curious as to what you guys thought it was. secondly, his car has been starting funny. some days it'll start right up. others it won't start at all. when the key is turned, the dash lights come on, but the car does not start. there is no sound of the starter whirring or anything, it just does not start lol. i would think if the started is bad, it would do something other than not do anything. could it be his ignition switch?
thanks!
Evil LTD is offline   Reply With Quote
Old 12-11-2005, 10:35 PM   #2
cwarcup
Member#: 96797
If you really need heat, build a small fire under your seat
cwarcup is offline   Reply With Quote
Old 12-11-2005, 11:31 PM   #3
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
The car must have fuses somewhere, under the dash and/or in the engine compartment. Starter problem could be a loose wire, or the whole starter could be shot.
Mike Wevrick is offline   Reply With Quote
So we have no heat... Any temporary heating solutions better than Kero heaters? AcquaCow Off-Topic 104 02-16-2010 06:19 PM
Intermittent squeal when a/c or defrost on karst Service & Maintenance 10 11-12-2009 01:25 PM
UTEC shows NO TPS signal NO MAP, and no air or coolant temps. jared nelson Engine Management & Tuning 4 12-20-2004 05:47 PM
NO HEAT AT WORK: grounds for leaving early? touch New England Impreza Club Forum -- NESIC 29 12-03-2002 11:26 PM
No heat at idle, only when moving, and long warm up period? Need4Boost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 12-01-2002 12:01 PM
