#1 |
Guest
Member#:
ok i got my first oil change at like 3k miles from a oil stop drive thru place on my 05 wrx. they put in 5w-30 oil. Now i have 7k miles on it and am ready for my next oil change. Where should i have it done and what oil do u all suggest. I just wanna do whats best for the car. btw i have a tbe catless. thanks.
#2 |
Member#: 57231
Do it yourself...it depends if you want to make the switch to synthetic or not...tons of threads....look around meng
#3 |
Member#: 79493
SCIC
Vehicle:2003 WRB WRX Wagon 5 doors > 4 doors |
Do it yourself, it's extremely easy to do, and gets you familiar with the car.
Personaly I would stick with dino 10w-30 oil until the switch to synthetic at 15k, but that's just me. As far as dino oils go, I'm a big fan of Castrol GTX stuff. |
#4 |
Member#: 103196
Vehicle:06 TRIBECA SILVER |
Wait till you have at least!12 to 15000mi. on it.Takes time to break in motor. Ive had two,One had 8000mi other had about 14000mi THe one with lessor milage seemed to breakin longer ,based on how car ran.It was ok but one with more milage ran quiter and smother.BE patient.It's a great motor it should last you a log time ,used Mobil 1 5-30w.Good luck.
#5 |
Member#: 3808
Vehicle:2005 Forester XT!!! Crystal Gray Metallic |
Like has been said already, it's a bit too early to switch to synthetic. I'd go at least one more change with dino oil. Then use whatever you're fond of. For me it's Mobil 1, 5W30.
#6 |
Member#: 79493
SCIC
5w-30 is nice, but I think for californian weather it's a bit too thin.
#7 |
Guest
Member#:
they put in chevron oil 5w-30, whats that. should i use that again?
#8 |
Member#: 94299
Vehicle:2007 2.5i wagon mutt CGM |
Def do it yourself, easy as pie and it's a great piece of mind knowing some knumbskull did not screw up your car.
#9 |
Guest
Member#:
what oil should i use
#10 |
Big Ron
Moderator Member#: 18062
Vehicle:on car parts so PM me b4 j00 buy |
Read the stickys at the top of the forum, that's what they are there for!
http://forums.nasioc.com/forums/show...hreadid=499177 |
| Thread Tools | |
| Display Modes | |
| Second oil change..after stage 2 | mjjantz | General Community | 10 | 06-09-2006 06:23 PM |
| Metal shavings on second oil change?!!!! | progresr | Factory 2.0L Turbo Powertrain | 5 | 10-05-2003 07:41 AM |
| oil light came on for a second after oil change... is this normal? | Poe | Factory 2.0L Turbo Powertrain | 3 | 01-28-2003 10:07 PM |
