Old 12-12-2005, 01:47 AM   #1
Magnum626
Member#: 62856
MBP SQC#197
Stockpiling parts...
Exclamation power steering leak
Ok...it seems like the oil temp sensor is leaking. The one that comes with the stock performance gauge pack.
I've searched and can't seem to find a part # for the sensor that goes into the oil plug. I know it's not a removable sensor and I hope it's not a whole piece that goes in the gauge.
The closest thread I found was this
Now is it the $28 piece or the $145 piece I need?
It's leaking by the sensor before the giant 27mm bolt.
TIA
EDIT:The leak was from the power steering line. It was the loose banjo bolt that caused the leak. PITA to get to as well...all is fixed...
Magnum626 is offline   Reply With Quote
Old 12-12-2005, 12:12 PM   #2
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
Oil temp Sensor = h5010fc025
Oil temp sensor cord = h5010fc026
jac04 is offline   Reply With Quote
Old 12-12-2005, 12:19 PM   #3
jac04
Member#: 49895
09 Forester
Also check this out:
https://www.subarugenuineparts.com/p...roducts_id=681
For about the cost of just the sensor, you can buy this entire gauge kit, then sell off the parts you don't need.
Old 12-12-2005, 12:28 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The sensor is not available as a separate part from the drain plug, you have to buy the sensor/drain plug assembly. I don't think that it's possible for the sensor itself to leak since it is external to the oil and doesn't contact it. The sensor is captive within the outer part of the drain plug but free to spin so the plug can be easily removed for oil changes. If you have a leak at the drain plug it may be the sealing washer, or an oil leak from above getting on the plug and sensor.
Old 12-13-2005, 01:49 AM   #5
Magnum626
Member#: 62856
MBP SQC#197
Hmm...maybe I need to take another look....
Damn and I just changed my oil 300 miles ago....
Thanks everyone...
Old 12-15-2005, 02:53 AM   #6
Magnum626
Member#: 62856
MBP SQC#197
Unhappy
Took another look today and saw nothing around the sealing washer at all...I can't figure it out.
Maybe I'll snap some pics tomorrow...
Well here's some pics....kinda blurry but what is leaking here?
Old 12-15-2005, 06:18 PM   #7
Magnum626
Member#: 62856
MBP SQC#197
bump for some help?
Old 12-15-2005, 07:30 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You're right, that sure is blurry. Move the camera back a bit so it's in focus and take more pics?
From what I can see, the drain plug/sensor appears dry. Looks like your steering rack may be leaking.
Old 12-15-2005, 08:12 PM   #9
Magnum626
Member#: 62856
MBP SQC#197
Anyone know how/why this would happen? Maybe because my garage space is tight and I'm constantly making sharp turns to park?
So how do I go about fixing this?
Maybe this weekend I'll have a chance to get under there...
Feeller: Lamco Oil temp sensor!! dplacen Engine/Power/Exhaust 11 10-25-2008 03:16 PM
L@@KING [email protected]: Lamco Oil Temp Sensor / Probe / Replacement Drain Plug BeBop86 Private 'Wanted' Classifieds 0 05-02-2008 05:43 AM
LA WTB: Oil Temp Sensor for lamco oil temp gauge Yulri Private 'Wanted' Classifieds 0 03-09-2008 09:14 PM
WTB: Oem oil temp sensor for stock lamco gauges theo79 Private 'Wanted' Classifieds 0 10-23-2007 12:57 AM
wtb nyc stock lamco gauge oil temp sensor lilrex Private 'Wanted' Classifieds 1 09-13-2006 10:10 AM
