Old 12-12-2005, 03:26 PM   #1
Zora
Member#: 74712
2006 Saab 92x Aero
Obsidian Black Pearl
Default 2004 USDM STi pedals in '95 Impreza L?
Will the pedal box fit? I assume it's a hydraulic set up. Any problems with mating it to a '97 JDM WRX 5-speed? TIA.
Zora is offline   Reply With Quote
Old 12-12-2005, 06:09 PM   #2
kheff46
Member#: 66739
2002 WRX wagon
hydro clutch- should fit with correct tranny bits to attach.
your L isn't hydraulic, so you must have the sti parts, but you can do it!
dbw? not sure if 2004 is e-throttle or not(you can go either way with minor mods).
-keith
kheff46 is offline   Reply With Quote
Old 12-12-2005, 06:25 PM   #3
Zora
Member#: 74712
2006 Saab 92x Aero
I'm going to be dropping in a '97 jdm engine and transmission, so I need to make sure that the STi box is compatible with that setup. My L is an auto right now
Old 12-13-2005, 09:34 AM   #4
kheff46
Member#: 66739
2002 WRX wagon
you'll need to make holes in the firewall, but with the jdm stuff it'll work fine!
Old 12-13-2005, 09:39 PM   #5
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
im about to put in 2002 WRX pedal box into a MY94. doing a swap also, and from what i read, it should fit fine.
just make sure you bench blead it before you put it in.
snowman4us is offline   Reply With Quote
Old 12-13-2005, 11:31 PM   #6
orangescooby
Member#: 15144
93 impreza
orange
i put a o4 sti pedal assembly into a 93 impreza L, the holes are alread there, there is a big rubber gromit where the clutch goes through the fire wall, the gas pedal mount is different though,
orangescooby is offline   Reply With Quote
Old 12-14-2005, 11:19 PM   #7
Zora
Member#: 74712
2006 Saab 92x Aero
Perhaps I can keep my old gas pedal? Was it difficult to modify the gas pedal to fit?
will a DBW/USDM sti pedal assembly work in Legacy GT? Leggy_09 Transmission (AT/MT) & Driveline 0 09-01-2009 08:50 AM
2004 usdm sti cams in a 2L rstinut Built Motor Discussion 2 09-22-2007 03:51 PM
WTB in MD: 2004 usdm Sti or JDM/EDM sti or wrx wheels . ALaDDiN Private 'Wanted' Classifieds 0 03-12-2006 07:31 PM
FS: 2004 USDM STI Shortblock In Maine, $500 Dizastical New England Impreza Club Forum -- NESIC 7 02-13-2005 01:32 PM
2004 USDM STi Gauge Cluster in a 2004 WRX! phenemwrx Electrical & Lighting 16 12-01-2004 08:49 PM
