View Poll Results: Do you know to check your battery's water level
Yes 41 56.94%
No 21 29.17%
Grap on my Engrish! 10 13.89%
Voters: 72. You may not vote on this poll
Old 12-12-2005, 04:52 PM   #1
HamFist
Member#: 2112
Default Do you know about checking your battery's water level?
I'm curious how many of you know about this trick. It's pretty basic, and won't be shocking to those of you that already know (IBt3hshockingdiskuveree!). If you've got a battery starting to die, check it's water level by popping off the little plastic toppers. If you don't see water within an inch of the top of the battery, pour some in. Some batteries don't have them. But most that I've seen, come with them.
How many of you know / don't know about the battery's water level?
HamFist is offline   Reply With Quote
Old 12-12-2005, 04:57 PM   #2
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
I voted "grap my english", as my battery does not contain that precious H2O that needs checking.
coyote73176 is offline   Reply With Quote
Old 12-12-2005, 04:59 PM   #3
Stanley
Member#: 7374
2007 MazdaCopMagnet
dusty
I check the level in my motorcycle battery. The car's battery is sealed.
Stanley is offline   Reply With Quote
Old 12-12-2005, 05:02 PM   #4
GOT_WRX
Member#: 7241
The OEM battery on my WRX had little caps on the top that you can twist open. Water level marks should be on front of the battery (low and high mark).
Manual recommands putting "Distilled" water into it, not tap water. About 90c/gal in my area.
I never bothered putting water into it. I replaced it with Optima Redtop after 4 years of ownership.
GOT_WRX is offline   Reply With Quote
Old 12-12-2005, 05:08 PM   #5
left footed whooten
Member#: 44652
06 Eastern Sierra
Assault Wagon
Yeah, you cant check the water level on all batteries, just the ones with removable caps. +1 for distilled water also. There is not much point in doing any battery maintenance if you put the wrong water in. Distilled has no other ions in it, unlike tap.
left footed whooten is offline   Reply With Quote
Old 12-12-2005, 05:24 PM   #6
Scoobie Noobie
Member#: 65498
I checked mine once.
Scoobie Noobie is offline   Reply With Quote
Old 12-12-2005, 05:31 PM   #7
Lachlan
Member#: 19470
1981 Brat GL
My battery is dry
Lachlan is offline   Reply With Quote
Old 12-12-2005, 10:47 PM   #8
joey1313
Member#: 53839
2005 STi, 94 Miata R
06 S2K
Goes to prove that I am now officially old since this is considered a new "trick".
joey1313 is offline   Reply With Quote
Old 12-12-2005, 10:52 PM   #9
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Optima, no need check, ok?
specialev is offline   Reply With Quote
Old 12-12-2005, 11:47 PM   #10
rubberbiscuitt
Member#: 96566
2002 wrx sedan
black
what's wrong with city tap water? [insert sarcasm here]
if it tastes bad try it with lemon. could be good for your battery too.
rubberbiscuitt is offline   Reply With Quote
Old 12-13-2005, 01:07 AM   #11
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Just to make things really clear: the liquid in the battery that people are talking about is not water -- it is caustic & toxic battery acid. Wear rubber gloves, eye protection, the works, and don't let it drip anywhere. If you do spill or drip it, pour on baking soda, which will neutralize the acid (it's neutral when the fizzing is done).
To top off the battery acid a bit, it's usually OK to use distilled water, because the battery usually loses water vapor. However, the "proper" way to do it is to check the density of the battery acid (using a "hydrometer", that funny turkey-baster-looking thing that battery shops have) and to add some concentrated battery acid and some distilled water to adjust the final concentration in the battery to the correct number.
Old 12-13-2005, 01:16 AM   #12
wrxsubaru
Member#: 65133
If enough baking soda was used.
wrxsubaru is offline   Reply With Quote
Old 12-13-2005, 01:17 AM   #13
P03w
Member#: 29059
1992 Balvenie
Portwood
Or get an Optima.
P03w
*My new quad battery came dry with a container of hydrochloric acid which had to be poured in through a hole in the top of the battery, so yeah, I know what a 'wet' battery is, however, pouring H2O in instead of HCl may 'wet' more of the lead plates, but it will do so with a more dilute acid solution.
"Acid...Base...Blow up in your face!" -Steve Sample, my 7th grade Science teacher.
P03w
P03w is offline   Reply With Quote
Old 12-13-2005, 01:17 AM   #14
nate49509
Member#: 22452
'04 WRX
witty comment goes here
+40million
nate49509 is offline   Reply With Quote
Old 12-13-2005, 10:24 AM   #15
HamFist
Member#: 2112
I was just curious what proportion of you might know a little obscure trivia vs. not. I never claimed to be a pro .
Anyhoo, educate me on dry batteries. I've never used one. HCl is involved??? Owie! I'm looking at moving my battery to the trunk, and changing over to an Optima dry-cell. (I've heard of the easier cranking, lighter weight, and longer battery life.) Thoughts?
Old 12-13-2005, 10:57 AM   #16
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
The optima battery is a gel filled sealed battery. No leaking unless you mangle it somehow (and it would have to be bad). They do have higher CCA (cold crank amp) rating the the stocker, but they are not lighter weight. In fact, they weigh more than the stocker.
As far as longer life, I can't tell you, I have only had mine in for a year now.
I would say its an excellent choice if your planning on relocating the battery to the trunk.
Old 12-13-2005, 11:09 AM   #17
kcismo
Member#: 21093
2002 WRX WAGON
BLUE
so how long does a typical stock battery last?
kcismo is offline   Reply With Quote
Old 12-13-2005, 02:25 PM   #18
HamFist
Member#: 2112
Mine lasted 3 years, I think...
Old 12-13-2005, 03:29 PM   #19
fireball_jones
Member#: 67536
00 AW GM6
And a bunch of parts
Until it dies. Not to be sarcastic, it's just batteries have widely varying tolerances. Unfortunately, they're almost never good for the life of the car, so you'll always have one of those, "Start!!! Start damn you!!!" moments unless you're trading in a lot.
fireball_jones is offline   Reply With Quote
Old 12-13-2005, 03:35 PM   #20
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Kean is offline   Reply With Quote
Old 12-13-2005, 03:56 PM   #21
kcismo
Member#: 21093
2002 WRX WAGON
BLUE
that's what i'm afraid of... after a long day at the slopes, to come to my car that doesn't want to start..end up stranded having to pay for a tow plus an over-priced bobo battery from some local shop.
my battery is pushing close to 4 years. my luck may be running out soon?>>
Old 12-13-2005, 04:33 PM   #22
z&cobb
Member#: 12344
2002 2JC
blue
I've been using this battery for 3 years. Treat it right and there's nothing to check, except perhaps the weight.
Battery for a light stg 3 2002 wrx
z&cobb is offline   Reply With Quote
Old 12-13-2005, 04:35 PM   #23
z&cobb
Member#: 12344
2002 2JC
blue
I also made a full metal jacket for it, but not the one of military fame.
Old 12-13-2005, 04:53 PM   #24
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
The optima battery is a gel filled sealed battery. No leaking unless you mangle it somehow (and it would have to be bad). ...
Just to clarify: Optimas are not gel batteries and are not dry batteries. They are "AGM" (absorbed glass mat) batteries. Essentially, instead of the loose liquid battery acid in a normal battery, AGMs have the battery acid soaked into a fiberglass mat that is between the electrodes. They pile up a number of layers of electrode/mat, then roll it up into a cylinder (you can see the cylinder shapes in the plastic case of many AGMs). The battery is sealed (except for a few emergency blowout places so it can't explode in extreme conditions), so it doesn't loose water or vent hydrogen gas like normal batteries. Also, because the battery has no loose liquid inside, it is very resistant to vibration, and can't spill (even if you cut it in half).
Because of Optima's design and the use of high-purity metal in the electrodes, Optimas are resistant to damage by charging too fast (because they have less internal resistance and heat up a lot less) and are very resistant to damage from being fully drained.
There are a number of sizes/shapes available, so you can choose whether you want more CCAs, lighter weight but fewer CCAs, whatever.
Old 12-13-2005, 05:21 PM   #25
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
mine's still going after 113,000 miles (april 2001)
*knock on wood*
dm
dwmoss_68 is offline   Reply With Quote
Do you know any names your parents almost gave you? Strider Off-Topic 101 05-11-2010 07:13 PM
Dark knight: What do you know about america and what are you hiding from us? edkwon Political Playground 13 10-01-2008 04:54 PM
Do you know how hot your exhaust is comming out of your Turbo? skoobysnacks Newbies & FAQs 10 08-24-2004 06:38 PM
Do you know how hot your exhaust is comming out of your Turbo? skoobysnacks General Community 5 08-23-2004 03:35 PM
How much do you know about your family tree? chkltcow Off-Topic 19 02-12-2004 02:56 PM
Message Board Statistics All times are GMT -4. The time now is 12:13 PM.
