Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Old 12-12-2005, 09:34 PM   #1
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
Default Mixing 2 brands of oil?
I just recently changed my oil to redline 5w-30 in my 03 wrx and for some reason I can only find this stuff online.
Anyways, my car burns oil and I'm going to the track this weekend and want to make sure I have extra oil just in case.
Would it be ok to bring some Mobil 1 5w-30 and use that in case I needed to add more oil?
QUESTION: Is it ok to mix 2 different brands of oils that are the same weights?
IE: Redline 5w-30 with Mobil 1 5w-30?
Erexxx is offline   Reply With Quote
Old 12-12-2005, 09:50 PM   #2
BillJC
Member#: 31002
You shouldn't have any issues doing that. It's completely safe.
BillJC is offline   Reply With Quote
Old 12-12-2005, 10:32 PM   #3
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Originally Posted by Erexxx
QUESTION: Is it ok to mix 2 different brands of oils that are different weights?
You meant, the same weight, right?
It won't hurt your car at all.
specialev is offline   Reply With Quote
Old 12-12-2005, 10:50 PM   #4
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
+1 for being perfectly fine.
Old 12-13-2005, 02:17 AM   #5
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
woops, yeah, I meant the same weight.
what about doing an oil change with 10w-30 but putting in a quart of 5w-30 after 1500 miles?
Old 12-13-2005, 02:47 AM   #6
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Go for it.
Old 12-13-2005, 05:41 AM   #7
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
You can even add it if they are different weights too.
volkl23 is offline   Reply With Quote
Is it bad to mix different brands of gear oil? Mike Wevrick Transmission (AT/MT) & Driveline 15 12-02-2003 09:38 AM
mixing different brands of fuel w/ the same octane iloveturbos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 05-28-2003 12:30 PM
Cool little study I found about different brands of oil filters LinuxGuy Service & Maintenance 2 12-31-2002 03:21 PM
What brand of oil are you using? Lightning Jack Service & Maintenance 47 10-01-2002 03:17 AM
What brand of oil to use in RS? Vigorous Newbies & FAQs 3 12-08-2001 04:03 AM
