Old 12-13-2005, 12:03 PM   #1
Shabib67
Member#: 61749
Default 06 sti o2 sensor
Anyone know the price on an 06 or just in general STI o2 sensor. Mines is gone and i need to replace it.
Shabib67 is offline   Reply With Quote
Old 12-13-2005, 12:25 PM   #2
Shabib67
Member#: 61749
to give more info, i need to know the price for the rear o2 sensor, the one that plugs into the cat.
Old 12-13-2005, 12:32 PM   #3
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
06STI? warranty?
I doubt there's any listing on the aftermarket O2's for any 06's (too new) but unless they're identical to 05's..... who knows.
Robin2 is offline   Reply With Quote
Old 12-13-2005, 12:39 PM   #4
Shabib67
Member#: 61749
oh the o2 should be replaced under warranty?
Old 12-13-2005, 12:40 PM   #5
Shabib67
Member#: 61749
i just put on a turbo xs turbo back exhaust, and when i removed my o2 sensor from the cat, it was stripped, looked like the metal on it got melted. So it wouldnt fit into the test pipe.
Old 12-13-2005, 02:19 PM   #6
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
when mine failed (rear o2) on my 99RS, it was covered under the 3year/36k miles warranty... but if you stripped it when changing exhaust, i doubt they'd cover it.
Maybe check with a local parts store (for a universal o2 sensor) or it's going to be a dealer only part.
Old 12-13-2005, 06:51 PM   #7
Shabib67
Member#: 61749
yea, there not going to cover it since i stripped it when taking it off, however i was wondering if i could use a universal o2 sensor? does anyone know?
Old 12-13-2005, 07:23 PM   #8
dolmen_tor
Member#: 31957
2013 Street Triple R
Explorer XC y DR650
I recently bought one for '02 wrx and it was around $120-150. Can't remember exactly but that should be a ballpark figure. I have since heard that they can be had for quite a bit less. I think there are only a few manufacturers around so a universal could very well work but I would try to get a definitive answer before trying that...there may be some variance to the connectors????
Good luck.
dolmen_tor is offline   Reply With Quote
Old 12-13-2005, 07:58 PM   #9
halo13
Member#: 73245
2004 STI
They can be kinda pricey I think the ones for the 2004 were about $150 for the front sensor and about $115 for the rear. That was at www.subaruparts.com. As for the univeral ones I think your need to find sensors with 4 wires but make sure you ask whoever you go with if the fit your application. i know bosch make a lot of O2 sensors. Good luck!
halo13 is offline   Reply With Quote
Old 12-13-2005, 08:00 PM   #10
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
I had the exact same problem. The o2 was stripped from the factory. The price is about $180. Somewhere I read that Subaru used an off the shelf part and that the same o2 sensor was used in other car manufacturers products. Apparently the part is exactly the same and costs a lot less. I will try to find more info on this and post it soon.
dexterous is offline   Reply With Quote
Old 12-13-2005, 11:40 PM   #11
Shabib67
Member#: 61749
thanks a lot guys, appreciate it.
06 STI o2 sensor Jhovany Private 'Wanted' Classifieds 1 11-19-2009 12:50 PM
Help! 06/07 Sti o2 sensor diagram Jimmy168 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-23-2008 07:20 PM
06 sti o2 sensor the oracle Engine/Power/Exhaust 3 02-15-2008 09:52 PM
WTB: 04-06 wrx / sti o2 sensor takumi Private 'Wanted' Classifieds 1 01-09-2007 07:11 PM
WRX and STI O2 sensor the same? hatchy STi Forum Archive 0 07-21-2003 02:43 AM
