Old 12-13-2005, 01:07 PM   #1
AutoXRex
Member#: 21650
2015 STI
Default Setup Questions
In the last snow storm I had the great luck of meeting the local granite curbing with my right front wheel. I have not verified but based on what others have experienced I am assuming that I need to rebuild that corner a bit. With that in mind I want to do a few upgrades in the process which leads me to a couple of questions.
I autocross in STX once in a while. The car currently only hase Perrin Front and Real Sway bars and I run a set of 17" SSR Comps and decent tires. I am looking for somewhat of a set it and forget it type setup, so limited adjustments. I like to run my car as I do on the street or at least close to it and see how competitive I can be.
- Are STI aluminum lower control arms legel in STX. I though I read that the 06 WRX is now equipt with them from the factory so would that put this in the update backdate umbrella? Or was that just a rumer?
- I was thinking of running a set of Koni inserts with Prodrive springs. With the Koni's do the Prodrives have a high enough spring rate? Is there a spring with a slightly higher rate with similar drop without going overboard?
Keep in mind this is not a full time AutoX car as I had hoped when I first bought it. So I am looking for a better handling package without going overboard.
Any suggestions on where to get these parts at a good price would be appreciated as well.
Thanks
Marc
AutoXRex is offline   Reply With Quote
Old 12-13-2005, 01:29 PM   #2
KC
Member#: 442
16 SS
00 S2000
Nope. Never have been.
UD/BD does not exist in ST. You have to run same equipment as it came from the factory unless otherwise allowed through the rules.
Konis and prodrives would be fine... I would go with just a little more spring personally than the prodrives allow (like around 300# or so) for a still fine daily drive and auto-x car.
--kC
KC is offline   Reply With Quote
Old 12-13-2005, 02:46 PM   #3
AutoXRex
Member#: 21650
2015 STI
KC,
Thanks, You can tell I am not that familiar with the rules but at least I am smart enough to ask before I jump.
So it sounds like I go with a stock control arm. Koni inserts and springs with around a 300# rating. I guess I have to find a spring with around that rating and then I have my setup.
Thanks
Marc
Old 12-13-2005, 02:56 PM   #4
wm07
Member#: 26529
04 STi
hmm.. I guess Ground Control is the only way you could find that spring rates. I hope I am wrong though.
wm07 is offline   Reply With Quote
Old 12-13-2005, 05:31 PM   #5
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
--kC
I thought they were perfectly legal as long as you dont have camber plates? You just have to call them a method of camber adjustment.
afpdl is offline   Reply With Quote
Old 12-13-2005, 07:25 PM   #6
PKer
Member#: 27647
06 MX-5-STR 03WRX
(ret), 08 Titan-Tow
You're right STi control arms are OK as long as you don't use another method of camber adjustment.
I second the Konis, I think they are comfy on the street with up to 400lb springs.
PKer is offline   Reply With Quote
Old 12-14-2005, 07:48 AM   #7
AutoXRex
Member#: 21650
2015 STI
I am having trouble finding springs with anything near the 300# rate. The highest I can find are 225. Does anybody know of any besides Ground Controls?
Thanks
Marc
Old 12-14-2005, 09:39 AM   #8
Aaron B
Member#: 67924
2003 #25/125 STX WRX
Here you go...
http://forums.nasioc.com/forums/show...t=spring+rates
280ish is about the highest rate you're going to find for a standard spring, and to do that you're going to have to switch to an '04+ style rear top hat.
Aaron B is offline   Reply With Quote
Suspension setup questions... Bigger Front Sway for more understeer? d00f Brakes, Steering & Suspension 4 12-23-2001 12:54 AM
22B Brakes on 99RS Setup Questions? Nick Brakes, Steering & Suspension 6 10-04-2001 01:51 PM
WRX Multi CD player setup question.. mpj_becks Car Audio, Video & Security 4 05-07-2001 03:11 PM
Autocross setup questions AutoXr Motorsports 26 04-27-2001 07:50 AM
Custom turbo kit setup questions morphine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-29-2001 08:08 PM
