Old 12-13-2005, 01:26 PM   #1
bboy
Member#: 56468
04 Improved STI
Dirty White
Default Mahle Power Pak Piston Update
Well after much deliberation I went with these forged pistons because I believe that they will wear better than the 2618 alloy.
I installed them with 0.0025 inch of bore clearance as per Mahle's recommendation. Upon the initial start up they slapped for about 15-20 seconds and then quieted down. They continued to slap under cold start conditions (~30 F) for about 5-10 seconds for the first 50-100 miles of engine operation.
Now they don't slap even under cold start conditions.
Time will tell if the 4032 alloy holds up better, but there's got to be some reason Porsche goes with these forged babys.
Old 12-13-2005, 01:33 PM   #2
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
What kind of ring gaps did you go with?
The Mahle's come coated i believe right?
Louis
Soon2Bgreat is offline   Reply With Quote
Old 12-13-2005, 01:34 PM   #3
sjl1614
Member#: 56791
06 OBS
Keep us updated, i will soon be replcing my CP's with the Mahle's. Hope they are quieter than the CP's
sjl1614 is offline   Reply With Quote
Old 12-13-2005, 01:53 PM   #4
bboy
Member#: 56468
04 Improved STI
Dirty White
I used Mahle rings, they are a ductile steel--might be nitrided or coated. The pistons come with rings (that has not made it to internet sites yet). They were gapped according to Mahle's specs, which I posted some where here.
There are two coatings on the pistons. One is a phosphate coating over the entire pistion. Like nitrided, phosphate hardens the surface. In contrast to the blinding CP aluminum, Mahle pistion are a dark greyish brown. The second coating is a "Grafel" coating on the skirts which as far as I can tell is Mahle's proprietary name for PTFE (telfon).
Additional thermal coatings can be added to the crowns by sand-blasting the phosphate coating off, and applying the thermal barrier. This is not standard.
Old 12-13-2005, 02:51 PM   #5
ewright
Member#: 68803
2004 WRX STi
bboy,
sweet, my Mahles should be coming via FedEx today and they will go in tonight. I am hoping that mine will be as quiet as yours are. Are you running the pistons in an otherwise stock block or do you have some other aftermarket stuff in the block as well?
Ernie
ewright is offline   Reply With Quote
Old 12-13-2005, 02:59 PM   #6
bboy
Member#: 56468
04 Improved STI
Dirty White
It's got all the goodies. I bored and honed for the proper fit (100 mm pistons), which means I had the pistons in hand prior to boring. If you don't do that, I don't think you can be as sure about noise. At the very least, I'd have the bores and pistons measured by a competent machinist. You'll find that the pistons are very close in diameter, but your bores may not be. At that point you can make a judgement about the clearance that you will have if you put the pistons in to the block.
Old 12-13-2005, 03:00 PM   #7
sjl1614
Member#: 56791
06 OBS
plus the mahle's are much cheaper considering they come coated and with rings!!
Old 12-13-2005, 03:08 PM   #8
bboy
Member#: 56468
04 Improved STI
Dirty White
They are less than $500. I got mine from Spokane Speed in Spokane, WA. Suby chrome rings are about $100.
Old 12-13-2005, 03:44 PM   #9
ewright
Member#: 68803
2004 WRX STi
bboy,
hmmm, I didnt realize you had the 100mm pistons. I got the stock bore pistons but they are going into a new shortblock. Well, Ill report back on the noise as soon as the engine is in and running
Ernie
Old 12-13-2005, 11:29 PM   #10
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
The piston skirt coating is more than likely not PTFE.
Sneak preview from my new Piston FAQ:
1. Dry film lubricants, also known as solid film lubricants, provide a lubricating film that reduces friction, inhibits galling and seizing, reduces piston scuffing, extends cylinder bore life, and in some instances can aid in dispersing heat. One of the obvious reasons for using a lubricating coating is to reduce friction, which improves wear, extends part life, and frees up power normally lost due to friction. A second major benefit is a reduction in part temperature.
Most dry film lubricants are Molybdenum Disulfide based. Why not Teflon? PTFE, also known as Teflon, is listed as having the lowest coefficient of friction (COE). However, under high speed and load, the COE of PTFE degrades while that of MOS2 (Molybdenum Disulfide) improves, until it is significantly better than PTFE. Moly also attracts oil, keeping an adequate film on the part unlike PTFE, which sheds oil.
Dry film lubricants are primarily applied to piston skirts.
Old 12-14-2005, 01:06 AM   #11
bboy
Member#: 56468
04 Improved STI
Dirty White
Grafel (sp?) is a dry film lubricant and it's applied as a patch on the skirts.
I bored out the block to fit the oversized piston. I think the stock sized pistons could work in a new block, but I'd certainly measure them and the bore, at the very least, just to know and/or report what you find.
Old 12-14-2005, 11:03 AM   #12
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
In comparison I have CP pistons in my built 2.5L. I had the pistons coated, oil shedder on the underside, non stick on the sides and a ceramic coat on top. I had these fitted with 0.0035 clearance to the original piston size... They do not slap and they are not noisy but of course they were more expensive than the Mahle's. The coating I had done was $35 per piston on top of the piston cost itself. Just wanted to mention that not all CP's are noisy. They are also installed into Darton sleeves.
bboy you need to make it down to PDX and say hello. Jeff S's car is back together with a 50 shot of nitrous, that's going to be fun tuning.... My car needs another 200 miles and then I'm tuning up the boost, I also need to rebuild my JDM 6 speed
mick_the_ginge is offline   Reply With Quote
Old 12-14-2005, 11:18 AM   #13
bboy
Member#: 56468
04 Improved STI
Dirty White
Yes, I never meant to imply CPs slap and Mahles don't. I know of CPs with the proper clearance and no coatings that don't slap.
This isn't a "which piston is better" thread. CP makes great pistons. The difference with Mahle is the alloy, 4032. It's harder and more likely to handle mileage well IMHO. The 2618 alloy (CP and many others) is more resistant to detonation's effects. Both are more durable than cast pistons.
I posted this info up because I don't know anyone else who has tried these pistons yet.
Old 03-21-2006, 02:57 PM   #14
dream
Member#: 37003
2015 WRX
Update?
dream is offline   Reply With Quote
Old 03-21-2006, 03:01 PM   #15
ewright
Member#: 68803
2004 WRX STi
I can give a little feedback as I had these put into my new block before it went in. The pistons are absolutely great: no slap or sound whatsoever. As far as I am concerned my motor is indistinguishable from a stock motor in sound and reliability.
ernie
Old 03-21-2006, 03:47 PM   #16
bboy
Member#: 56468
04 Improved STI
Dirty White
Well I can distinguish a sound difference, but they are a different metal. There still holding at 3000 miles and about 450 whp. Just get the p-w clearance right and I think most forged piston can be pretty quiet.
Old 03-21-2006, 03:58 PM   #17
_sti_05
Member#: 72313
16 STi
bboy, do u think you can give a full list of what you have in your shortblock?
_sti_05 is offline   Reply With Quote
Old 03-21-2006, 04:19 PM   #18
bboy
Member#: 56468
04 Improved STI
Dirty White
Hmmmm let's see I've never done this.
Motor:
Drilled and balanced crankshaft a la Axis Racing
Coated rod bearings a la Axis Racing
Oliver rods, lightweight (115 gm less than stock per rod)
100 mm Mahle pistons (0.0025 bore clearance) bored by DG Machine in Auburn, WA
DPR Stage 2.5 AVCS cams (.406 lift, 228 [email protected], 110 LSA--required some AVCS optimization from Phil)
DPR conical valvesprings and titanium retainers (really like this design over dual springs)
All clearances and assembly by WorldOne Performance (Wayde Segewa).
Non-motor:
Element Tuning GT65 Turbo Kit with reversed intake manifold (very trick!)
Espelier Exhaust
TSX front mount
Turbosmart EWG + e-Boost2 controller
Element Tuning Hydra
Still working on water injection integration with the Hydra. It's more complicated than it looks and the higher you go in boost the tougher it is to get water in the intake tract. As soon as I get this dialed in, I'm hoping for 500+ whp on pump fuel.
Someday I'd like some of those Cosworth CNC heads. Also someday I'd like to plumb the front mount IC like AlanG did. Phil (Element Tuning) get's more power out of a larger compressor wheel with nearly the same spool up. If someone invents a variable turbine to improve spool up on my turbo (eyes new 911 with gasoline variable turbine), I'd buy it immediately. Mind you I'm not complaining. 15 psi at around 3500-3600 (4th gear) is pretty responsive, but I'm greedy.
Old 03-21-2006, 05:44 PM   #19
_sti_05
Member#: 72313
16 STi
wow man thats an awesome setup you have there.
Old 03-21-2006, 06:22 PM   #20
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
that thing sounds like a beast.
do you have a link to some pics of the motor?
it's good to hear they are still holding strong after 3k miles
WRX8XB is offline   Reply With Quote
Old 03-21-2006, 06:35 PM   #21
bboy
Member#: 56468
04 Improved STI
Dirty White
WorldOne had one posted at one time. Let me look.....but the turbo was not in yet.
Old 03-21-2006, 06:43 PM   #22
bboy
Member#: 56468
04 Improved STI
Dirty White
http://forums.nasioc.com/forums/showthread.php?t=885607
The intake tubing has since been mod'd for two water injection jets. You can see the turbo out of the car there. It's a GT35 compressor wheel and housing. The CHRA is journal bearing, and I don't know what the turbine and housing are.
The car looks remarkably stock. You'd never know it could beat up on 911's and Ferraris.
Old 03-21-2006, 08:35 PM   #23
Shabib67
Member#: 61749
what is the advantage of running reverse intake manifold?
Shabib67 is offline   Reply With Quote
Old 03-21-2006, 08:38 PM   #24
Shabib67
Member#: 61749
Also if you reverse the intake manifold can you keep the AC compressor?
Old 03-21-2006, 10:59 PM   #25
dream
Member#: 37003
2015 WRX
ernie
Did you use the 99.5's or the 100.00's? If you used the 99.5's, did you hone the block?
mahle ej207 forged piston for 2.0L ImprezaRSfan! Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 09-09-2013 02:20 PM
New Mahle 9:1 2618 Pistons Precision Tuning Engine/Power/Exhaust 0 05-13-2010 10:17 PM
Mahle 100mm EJ25 pistons - brand new - also USDM STI new pistons cheap! engineerx Engine/Power/Exhaust 23 11-04-2007 12:20 AM
F/S Mahle power pak 99.5 pistons, agency power fuel rails, STI valvetrain stu Engine/Power/Exhaust 22 02-28-2007 03:15 PM
Mahle EJ257 100mm pistons sjl1614 Engine/Power/Exhaust 14 09-05-2006 04:52 PM
