Old 12-13-2005, 04:01 PM   #1
ewright
Member#: 68803
2004 WRX STi
Default Anyone have experience with Accusump?
Hi everyone,
I was wondering if anybody has any experience with an oil accumulator such as Accusump. If so, would you mind sharing your experience? Any advice would be appreciated, thanks!
Ernie
ewright is offline   Reply With Quote
Old 12-13-2005, 04:19 PM   #2
zzyzx
Member#: 815
2013 Boss 302 White
2008 S2000 CR ABP
Originally Posted by ewright
Hi everyone,
Ernie
What do you want to know? I haven't spun another rod bearing since I've been using it.
The only thing I'd recommend is using the manual valve, not the electronic one. The electronic one, IMO, generally doesn't act how I want it to - lets pressure build too slowly. I thought I'd like it because I wouldn't have to remember, but I don't...
Qs?
zzyzx is offline   Reply With Quote
Old 12-13-2005, 05:30 PM   #3
ewright
Member#: 68803
2004 WRX STi
zzyzx,
thanks for the reply. I was just curious as to whether you had experienced any oil pressure or other problems since installing the Accusump. In another words, does it work as advertised? I also was dead set on running the electronic valve but after reading your post I am definitely having second thoughts. With the manual valve, are there any adverse effects to forgetting to open or close it? Thanks again for the advice.
Ernie
Old 12-13-2005, 07:40 PM   #4
solo2wrx
Member#: 87982
05 Intrepid
125cc of 2 stroke fury
I second getting a manual valve. For the same reasons and stated above and because a manual valve has much less of a chance of failing.
solo2wrx is offline   Reply With Quote
Old 12-13-2005, 11:21 PM   #5
ewright
Member#: 68803
2004 WRX STi
solo2wrx,
thanks for your reply. Do you foresee any potentially adverse effects from forgetting to open or close the valve?
Ernie
Old 12-14-2005, 10:42 AM   #6
solo2wrx
Member#: 87982
05 Intrepid
solo2wrx,
Ernie
Well if you forget to open the valve before starting there is a chance you could get oil starvation. If you forget to close the valve before shutting it off you just won't have any way to pressurize the engine with oil when you go to start it back up.
Old 12-14-2005, 12:37 PM   #7
ewright
Member#: 68803
2004 WRX STi
solo2,
So if I forget to open or close the valve I simply lose the benefits of the accusump, but do not stand to do any more damage than if it were not to be installed?
ernie
Old 12-14-2005, 01:52 PM   #8
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Just don't forget. Make it part of your pre-race/post-race routine.
omahasubaru is offline   Reply With Quote
Old 12-14-2005, 03:15 PM   #9
ewright
Member#: 68803
2004 WRX STi
omahasubaru,
that sounds like good advice. my only concern is that I will forget to open or close the valve when I take the car out for the occassional weekend drive, but it sounds like it should be okay even if I forget to open or close it for the occassional grocery run.
ernie
Old 12-14-2005, 04:24 PM   #10
solo2wrx
Member#: 87982
05 Intrepid
I would think your better off forgetting to close it then forgetting to open it back up. If you forget to close it no harm done just no way to pressurize the oil system before start up. If you forget to open it then you could be dealing with oil starvation is not enough oil is in the pan. This is basically what I stated above. Hope this helps you out.
Old 12-14-2005, 04:42 PM   #11
ewright
Member#: 68803
2004 WRX STi
Hey guys,
I just want to offer my sincere thanks for all of your very helpful replies. I have decided to go with the accusump with a manual valve, hopefully this will keep my motor in one piece!
ernie
Old 12-14-2005, 09:05 PM   #12
kursplat
Member#: 89528
2005 sti
crystal grey
if you check your oil level with the accusump full, and the valve closed, you will have the correct amount in the pan. so you will not be running the motor with the oil low. the accusump holds EXTRA oil
kursplat is offline   Reply With Quote
Old 12-14-2005, 09:08 PM   #13
solo2wrx
Member#: 87982
05 Intrepid
I was simply stating if there isn't enough in the pan not that the Accusump carries any bit of the normal capacity.
Old 04-17-2006, 12:57 PM   #14
Ryokosman
Member#: 69997
12 Impreza Premium
Hate to bump a old thread but how many quart accusump units are you guys running? Also when you state you don't like the electric valves, are you talking about the E.P.C. Valve?
I was thinking 2 quart unit with the 20-25 psi E.P.C. Valve... Can't do anything but help motor life. With the added insurance of the oil cooler and accusump I might just entertain the idea of spinning the stock long block upto 7500 -7750 rpm's...
Ryokosman is offline   Reply With Quote
Old 04-18-2006, 08:34 AM   #15
randy zimmer
Member#: 4560
93 buy my rally
build manual
"With the added insurance of the oil cooler and accusump I might just entertain the idea of spinning the stock long block upto 7500 -7750 rpm's..."
The accumulator doesn't fix oiling problems other than starvation - like in a long turn.
It doesn't change the physics of the system. Yes, it holds more oil and there is some heat radiation but that's about it.
rz
randy zimmer is offline   Reply With Quote
Old 04-19-2006, 04:05 AM   #16
patr
Member#: 97
the accusump is of useful benefit to guys tracking their cars - and also of benefit is a true baffled sump. Not a ghetto one that you see being sold in some places - but a truly internally baffled unit.
the boxer and the pan layout with the oil return and the head breather design (especially on the 2.5s) means that when you pull Gs, there is a high probability of either losing the oil in the head (too much oil), or losing pressure (too low of oil, which people end up with such that it doesn't pour out of the head breather). You need to have a baffle and a reservoir. The cooler doesn't have much to do with it, unless you are truly heating it to the point of pressure loss (which i seriously doubt). We reccomend the accusump on all our customer track cars. And a baffled sump, and a surge tank, etc. etc. the 35psi EPC valve works fine. If you want fgaster fill rates (i.e. twisty track or whatever) then bore it out or go manual.
If you are running slicks, and a fast car, and you drive it fast, all of the above and more is needed. NONE of this is going to give you 8000 rpm. Some head work would, though.
-Pat
www.rocketrally.com
patr is offline   Reply With Quote
Old 04-19-2006, 07:15 AM   #17
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Pat - Could you point me in the right direction for info on baffled oil pans? Much appreciate it...
Pat Olsen
'97 Legacy 2.5GT sedan
Old 04-19-2006, 08:07 AM   #18
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Hmmm...I was planning on getting an oil cooler, but hadn't thought of an Accusump. Does anyone have a setup with an oil cooler and an Acuusump installed?
Old 04-19-2006, 10:21 AM   #19
Ryokosman
Member#: 69997
12 Impreza Premium
patr - I hadn't thought about a baffled oil pan. I didn't know anyone made them for subaru's...
However I don't have quite the budget to do everything I want to do so I have to choose. Would you recommend a oil pan or accusump given you had to choose???
Old 04-19-2006, 09:12 PM   #20
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Originally Posted by mav1c
Hmmm...I was planning on getting an oil cooler, but hadn't thought of an Accusump. Does anyone have a setup with an oil cooler and an Accusump installed?
I don't know if there are any Subies running around with that setup, but it's pretty common in the Mustang/Camaro/Corvette open tracking crowd. The plumbing would be the same, of course, you'd just need to work out where to mount the pieces parts.
The only (potential) one I've seen is a pan from ARC advertised on a couple of the websites of guys that import hard-to-find Japanese parts. When I emailed about it the guy really didn't have any info, as nobody had ever bought one from him.
Pat
Old 04-19-2006, 09:22 PM   #21
randy zimmer
Member#: 4560
93 buy my rally
build manual
Amazing, I'm speechless.
rz
Old 04-19-2006, 09:48 PM   #22
javid
Member#: 54304
04 STi
TopSpeed-dAng!
I am going to order a accusump any day now but haven't found a pan yet.
javid is offline   Reply With Quote
Old 04-19-2006, 09:56 PM   #23
spazegun2213
Member#: 91208
the '13 Ktm Duke
is there really a reason for this? I keep hearing how the boxer engines are some of the best at cooling.
although a baffled pan sounds like a worthy investment. Maybe we can get someone to start making some?
spazegun2213 is offline   Reply With Quote
Old 04-20-2006, 03:13 PM   #24
javid
Member#: 54304
04 STi
TopSpeed-dAng!
depends on how hard you want to run your car on track and how much extra engine insurance you can afford. considering the average track day in a wrx/sti will cost about a grand (entry, gas, brakes, tires, misc)... ~$300 for an oil cooler isnt too bad.
i personally have gone with out one for a while at 300whp but have one now that i am moving up to ~450whp...
Old 04-20-2006, 03:40 PM   #25
Ryokosman
Member#: 69997
12 Impreza Premium
I have over 325 whp and track without a cooler now too. I don't have any guages but I know my oils gotta be kookin! It noticeably turns alot darker after a track day.
My car also gets rear hot out on track. The factory temp guage points about the 3/4 hot mark while on track. The oils gotta be feelin the heat.
Probably not real good for the motor but I run a 50/50 mix of 93 and 101 on a 91 oct map so I feel confident that I'm not gonna run into det issues.
I've already got a Process West oil cooler waiting to be installed.
Anyone have experience with Planet Audio? MaximusRex Car Audio, Video & Security 4 08-01-2001 09:43 PM
Anyone have experiance with AudioBahn? Turk Car Audio, Video & Security 5 04-17-2001 07:32 AM
Cusco Rear Lower Arm Bar ...anyone have experience with this? kevinsUBARU Technical Forum Archive 6 09-16-2000 09:15 PM
Anyone have experience with Hercules tires? kevinsUBARU Technical Forum Archive 1 09-15-2000 11:09 PM
Anyone have experience with Yokohama AO32R road race tires JDM5LugHatch Technical Forum Archive 10 06-13-2000 06:41 AM
