Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 01-05-2006, 10:08 AM   #1
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Default running a hydra, can i eliminate the maf?
I know the hydra uses speed-density (MAP) for its calculations, and the MAF for IAT, but I lost my maf sensor putting my car back together, and I either need to buy another one, or just put on a custom intake or something.
Does it still need to be in there for air temperature?
ScreaminFast is offline   Reply With Quote
Old 01-05-2006, 10:29 AM   #2
pux888
Member#: 8356
02 STi swap
12 WRX limited
The hydra does use the MAF to moniter intake temps so need to keep it.
pux888 is offline   Reply With Quote
Old 01-05-2006, 11:21 AM   #3
TheMadScientist
Member#: 23717
2005 Big red
Talk to Phil. I thought you could use the GM IAT sensor with the hydra.
TMS
TheMadScientist is offline   Reply With Quote
Old 01-05-2006, 03:02 PM   #4
bboy
Member#: 56468
04 Improved STI
Dirty White
Mines stuck into the wheel well. People do use different IAT sensors in other cars.
bboy is offline   Reply With Quote
Old 01-06-2006, 09:19 AM   #5
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
You can replace the IAT with a GM sensor, but apparently there is more than one resistance range of GM IAT sensor out there (see the thread I started in the Impreza subforum on the Hydra forums for more details), so make sure you get the right one.
Link to the aforementioned thread: http://www.hydraems.com/forums/viewtopic.php?t=187
Shane
Warp3 is offline   Reply With Quote
Old 01-09-2006, 04:56 PM   #6
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Ok that sounds good. Someone PM'd me and said I can use a MAF from a scion xA/xB in the subaru, and especially since the hydra only uses it for IAT, I'll use that temporarily until I replace my intake with a custom one and a GM IAT sensor.
Thanks for the help guys
Anyone eliminate the maf on their 99rs by running a map model year ecu? mcu81 Normally Aspirated Powertrain 16 02-14-2008 11:46 AM
could i run the maf before the turbo so it doesnbt blow? White 2.5rs Normally Aspirated Powertrain 2 10-31-2003 09:25 PM
Can we install the MIL eliminator at the ECU? Tronner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-14-2002 12:56 PM
Can you move the MAF after the BOV??? rhdude Mid Atlantic Impreza Club -- MAIC 12 06-04-2002 12:19 PM
Eliminating the handbrake-daytime running lights dependency afeinman Interior & Exterior Modification 11 04-05-2002 07:22 PM
