Old 12-14-2005, 02:33 PM   #1
xS2k
Member#: 85112
Default What do you guys think?
I found a turbo kit for my RS for a whooping $1400 used. The cheapest WRX swap cost $4500 or so if I do it myself and have someone else do the wiring. Is it really worth the trouble of turboing my car for 1400 and have a short fun, or just keep saving? I'm not looking for big power, just a little extra (50-80hp extra MAX) to climb those mountains
Don't tell me to search because I did every other tread compares with more expensive new turbos. I'm getting this turbo for a good deal (CHeAP!), so is it really worth my time to buy and install it?
Also, this guy says I do not need EM because I'm only boosting 4-5lb and running a vortec fmu with SVX fuel regulator.
xS2k is offline   Reply With Quote
Old 12-14-2005, 05:46 PM   #2
kheff46
Member#: 66739
2002 WRX wagon
you should be fine with thatsetup. i ran a wrx turbo setup on my 1998 OBS for almost 30k with zero prob. initially i stayed at 5spi for reliability. a month before i took it off i turned it up to 7psi a couple of times. it was cool, but i heard sounds i didn't like after a little while. not sure what it was, but after removal, i didn't hear any weird noises. but the engine still runs exactly like it did 70k ago. GO FOR IT! -keith
kheff46 is offline   Reply With Quote
Old 12-14-2005, 09:17 PM   #3
xS2k
Member#: 85112
^^^Why did you take it out? Did you ever figure out the noises?
The seller said he used the turbo for over 70k miles and recently put his car back to stock. Turbo is rebult and ready to go, so I heard.
I did some further search and found a little people with problems often boost over 7-8 psi, so staying under 5 psi shouldn't be a problem.
Old 12-15-2005, 08:01 PM   #4
kheff46
Member#: 66739
2002 WRX wagon
i went to school, and didn't want to risk going broke while there. i like to drive, and i play hard. i had no job to pay for what i was about to break. and no i never figured it out. except after i removed the entire setup, no noise! weird for sure!
it better be rebuilt, 70k anything can happen to a turbo(wear thru hose clamp, overboost, and blow motor) mine had less than 10k when i bought it. 5 psi is the limit with no EM of any type. HEED THE WARNING NOW! or you will feel the wrath.
What do you guys think of a SPT intake? What do you have? chomponthis231 Newbies & FAQs 28 07-07-2009 09:01 AM
Thinking of going wingless, what do you guys think?? Calitri-Boost Member's Car Gallery 66 09-30-2006 02:42 PM
What do you guys think I should do?? evokiller04 Proven Power Bragging 13 06-13-2006 07:28 PM
Thinking about bidding on this eBay car, what do you guys think? Cjchaps Mid West Subaru Owners Club Forum -- MWSOC 18 01-04-2002 01:42 AM
