Welcome to the North American Subaru Impreza Owners Club Thursday September 18, 2014
Old 12-14-2005, 05:13 PM   #1
Mr. SUAVE
Member#: 96893
Default what oil filter do u use
do you necessary have to change the drain plug gasket everytime u change oil?
is it necessary to use oem oil filter or what other after market oil filter do u use for this?
Mr. SUAVE is online now   Reply With Quote
Old 12-14-2005, 05:17 PM   #2
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
look into this: www.fumotovalve.com
imho the oem filter is the best.
Bishop is offline   Reply With Quote
Old 12-14-2005, 05:18 PM   #3
edo2000
Member#: 68709
2012 WRX
red
There is a lot of info on this if you search. Subaru recommends you NOT reuse the crush gasket on the drain plug. I have successfully reused once, when I didn't have one. I have not researched this, but the oem filter is generally regarded as much better quality than the standard auto parts store ones.
edo2000 is offline   Reply With Quote
Old 12-14-2005, 05:23 PM   #4
Corkfish
Member#: 39503
If you been following this site, you'll notice all the problems with oem Subaru filters. My next filter will probably be a K&N or Mobil 1. Both have received very good reviews.
Corkfish is offline   Reply With Quote
Old 12-14-2005, 05:27 PM   #5
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Yes you should change the crush washer everytime you change the oil, and I use the Puralator filter.
eltrouble is offline   Reply With Quote
Old 12-14-2005, 05:31 PM   #6
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
<- Amsoil filter + fumoto
Trunk_Monkey is offline   Reply With Quote
Old 12-14-2005, 06:04 PM   #7
Bishop
Member#: 59993
Ass, grass or cash
i'm sorry. but if you've been following subaru has re-issued the A100 filters. unfortunately though. SOA has sold out. check w/your local dealerships to see if they got any in.
see here: http://forums.nasioc.com/forums/show...3#post11993543
Old 12-14-2005, 11:35 PM   #8
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
K&N filter is the way to go.
cjfike is offline   Reply With Quote
Old 12-14-2005, 11:38 PM   #9
2006STI
Member#: 96540
2006 STI
Crystal Metallic
i ordered the black oil filter thats made in japan from 1stsubaruparts.com. quick shipping and dont forget to order the crush washer as well.
2006STI is offline   Reply With Quote
Old 12-15-2005, 08:40 AM   #10
Corkfish
Member#: 39503
Yeah, I'm aware. But who needs the hassle of trying to find and figure out if you've got the right one when you can just buy a purolater, mobil 1, K&N or Amsoil. All of which are superior anyway. They messed up so screw em. I beleive my dealer would try to pawn off one of the bad ones on me.
Old 12-15-2005, 09:33 AM   #11
haven
Member#: 95
2006 Wrx
Crystal Gray
I am going to start using the Amsoil EA oil filter.
haven is offline   Reply With Quote
Old 12-15-2005, 09:50 AM   #12
ptirmal
Member#: 82243
07' Acura TL-S
11' Ducati Monster 796
does mobil even make one for our car? I remember the autozone only had bosch in stock for my wrx.
Do you have a part number for the puralator, pure one or mobil1 filter?
ptirmal is online now   Reply With Quote
Old 12-15-2005, 10:45 AM   #13
InfamousDX
Member#: 25413
I've used the 0100 white ones, the ones ppl have had trouble with.. I guess I got a miracle case of 12 because out of using 5, none have given me issues. What exactly is the issue with them... they leak? I couldn't page thruogh the thread it was too long.
Old 12-15-2005, 11:46 AM   #14
2fas4u
Member#: 90691
2005 STI / 2009 STI
Yeah I agree??? What problems? The only problem is the new replacement white filter, which has already been corrected by Subaru. The OEM black filters have been proven to rank the best out of any of the filters....
2fas4u is offline   Reply With Quote
Old 12-15-2005, 01:47 PM   #15
Hayes
Member#: 11808
I use a PureOne filter or OEM always and also a new crush washer. I like the safety of the bolt/washer combo and the speed at which the oil is removed. It has also been mentioned on how to modify the fumoto valve so ALL the oil is drained from the sump. It is a farly easy modification and you only need a rat-tailed file and some time. JMHO Ed
Hayes is offline   Reply With Quote
Old 12-15-2005, 09:47 PM   #16
Hunt3r
Member#: 95484
1985 911/993 Cab
I always use a PureOne filter and I didn't change my drain plug's crush washer the past few times and now it started leaking so be sure you change that too.
Speaking of which, where can I get a crush washer? If I go to the dealership will they give me some?
Hunt3r is offline   Reply With Quote
Old 12-15-2005, 09:50 PM   #17
Bishop
Member#: 59993
Ass, grass or cash
yes. some will give it to you for free some won't.
Old 12-15-2005, 09:51 PM   #18
InfamousDX
Member#: 25413
I have a bunch of crush washers I don't use cuz I have a fumoto... i could send u some.
Old 12-15-2005, 10:02 PM   #19
Hunt3r
Member#: 95484
1985 911/993 Cab
=) need some postage money?
Old 12-15-2005, 10:13 PM   #20
hondaeater69
Member#: 60324
the washer on the drain plug? funny, i've never replaced mine, EVER. I"m at 60K on my wrx. And i'm sure subaru says to replace the washer every time on all their models. . I had a legacy that i racked up 150K or something like that, never replaced that one either. Guess i'm lucky my car didn't blow up. hahahah I use bosch oil filters.
Old 12-16-2005, 01:04 AM   #21
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Yeah, the previous owner never replaced the washer on the drain plug until it came into my possession. So the car went through 30k on the same washer and didn't leak oil out through the oil pan.
But you're supposed so, and I guess for a few bucks for the crush washers, it's worth it just for piece of mind.
Old 12-16-2005, 02:24 AM   #22
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
I replace the washer on the oil drain plug. And yes, you can get away with not replacing it. I replace it because I always get a new ring with my filter.
I've done it with our OBK's ATF. Never changed the crush ring and it doesn't leak.
-paK +3
Pakin is offline   Reply With Quote
Old 12-16-2005, 07:59 AM   #23
darthtater
Member#: 85902
05 STi
deffinately go with the fumoto if you do your own oil changes. I went with the K&N oil Filter, mostly cuase I didn't want to have to go out and get a special filter wrench. and the K&N has a nut on the bottom that makes removal a breeze.
darthtater is offline   Reply With Quote
Old 12-16-2005, 04:33 PM   #24
RUrunning
Member#: 68758
04 STi
R.I.P. AEROSIM
oem filter
RUrunning is offline   Reply With Quote
Old 12-16-2005, 04:44 PM   #25
lDeez lNutz
Member#: 94339
2005 STi
mobil1 - because it's easily available everywhere. my autostores don't stock k&n for my sti and subaru dealers parts stores are always closed when i get off work.
lDeez lNutz is offline   Reply With Quote
what oil filter do you use? kooklie Newbies & FAQs 131 09-25-2013 07:46 PM
What Kind of Oil Filter Do You Use? LaureltheQueen Off-Topic 37 06-08-2004 12:24 PM
what damage does a fram oil filter do? skyredrex Service & Maintenance 28 01-02-2004 09:52 PM
what kind of engline oil and oil filter do u use? lik Vancouver Impreza Club Forum -- VIC 38 11-04-2003 06:16 AM
