Old 12-14-2005, 06:59 PM   #1
YinUCSD
Member#: 44945
06 LGT wag
Question My car has trouble starting sometimes. 2003 WRX w/ 80k miles.
Hi all,
I'm not very good at diagnosing car problems, and I think this should be a simple solution, but I dont know where to start. I have a 2003 WRX with 80k miles, stock.
So my car has trouble starting sometimes. It's as simple as that. Sometimes it starts right up (morning), but when I let it sit until lunch (~noon), it takes a few seconds for it to start. It's very noticable. Once it does start, the idle is a little rough.
Is it as simple as putting in a new starter? cleaning out fuel injectors? idle timing?
Any advice will be greatly appreciated.
:tia:
YinUCSD is offline   Reply With Quote
Old 12-14-2005, 09:59 PM   #2
peterex
Member#: 27021
2015 WRX
Not sure if this helps, but I run a Costco battery, Walbro fuel pump, one step colder NGK Iridium plugs, synthetic engine oil, and GTA Fuel Enhancer with every tank. I also make sure to keep the injectors clean and run fresh air/fuel filters. Car starts instantly every time - even in the cold.
Out of everything mentioned in the list above, I think changing the battery and spark plugs made the biggest difference.
peterex is offline   Reply With Quote
Old 12-14-2005, 10:05 PM   #3
cstratton04
Member#: 84489
2005 Toyota Corolla
2005 CBR600rr
It is not your starter. It sounds like you are having trouble kicking over, which could be the things that peterex mentioned (batter, sparkplugs, etc). The stock battery may have trouble putting out the amps you need to start the car, so I would check for a better suited battery for the cold first.
cstratton04 is offline   Reply With Quote
Old 12-14-2005, 10:14 PM   #4
peterex
Member#: 27021
2015 WRX
Yeah, now that I think about it, my car had trouble turning over when it was brand new off the lot with 20 miles on it. Replacing the OEM plugs/battery made the biggest difference.
Old 12-15-2005, 02:43 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
if you live in northern CA i am guessing you live in a region that sees snow? if so run some Valvoline Synpower Fuel System cleaner thru it. It seems that one of the additives they are running in winter blend fuels these days causes severe waxing of injectors. I only know the WRX is affected by this because my Swapped RS started missing/hard starting(acting like it was flooded) after 400 miles...ran the injector cleaner thru and all is well again.
Jeremy
Old 12-15-2005, 05:51 PM   #6
YinUCSD
Member#: 44945
06 LGT wag
wow, some great responses. thanks guys. i didnt think it was the starter. but now i know. come to think of it, i havent changed the plugs in a while, and ive never changed the battery. i'll replace those things and run the fuel cleaner and see how it turns out.
Old 12-16-2005, 08:47 AM   #7
Corkfish
Member#: 39503
It could be a number of things, but I had a similar problem with a Totota Tercel and it turned out to be the valves. They were covered with crud which was soaking up gasoline when it was still warm. A fiel systems cleaner is a good idea. Some of the quick change places even have a pressurized treatment.
Corkfish is offline   Reply With Quote
Old 12-16-2005, 12:23 PM   #8
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Start with the simplest cheapest possible solution then work your way up from there.
As for the spark plugs, they should have been replaced at 60k miles. It didn't make the car start any better for me, but the car did "feel" alot better cruising down the freeway. I use a bottle of Chevron Techron concentrate every oil change to keep the fuel system happy and i repalced my battery for a lightweight one at the end of summer (not because the OEM battery wasn't doing the job, i just wanted something lighter).
I've always noticed the car takes just a wee bit longer to start when the engine is already hot (i.e. after filling up at the gas station or hitting the grocery store). Once in a while it'll start up really weak in the morning (once every month or 2) and it happened with the old and new battery but never twice in a row.
Old 12-17-2005, 10:22 AM   #9
shoooter_j
Member#: 39411
2002 WRX Sedan
I've noticed that cold starts are never a problem as well, but as psydotek said, warm starts are the issue. It take a tiny bit longer to start up and when it does, my rpm drops, then hovers at the normal 750rpm.
shoooter_j is offline   Reply With Quote
Old 12-17-2005, 12:02 PM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
it's normal for WRX's to crank longer on a hot restart versus a cold restart. THe motor doesn't run nearly as rich when it's hot as it does when cold.
Jeremy
Old 12-30-2005, 05:33 PM   #11
hikeeba
Member#: 89165
Poop Stuck Survivor
-=C=- & subari87 FOREVER!
Teh OEM battery is teh suck. One tip to do is to always turn on your ignition, and then wait a few seconds before engaging the starter. This allows time for the fuel pump to dump in the start-up amount of fuel. Otherwise if you turn the key and start cranking right away, you're trying to start the motor and prime it at the same time. Anyhoo, a second or so of cranking isn't horrible.
hikeeba is offline   Reply With Quote
FS: (UT) 2003 WRX Wagon, 80k miles, Cobb Intake/TBE Exhaust... STirish Private Vehicle 'For Sale' Classifieds 13 11-09-2008 04:36 PM
What makes my car hard to start sometimes? nos Service & Maintenance 7 03-15-2005 12:57 PM
car has trouble starting when cold sssp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-22-2005 02:52 PM
Car has trouble starting up Hank3 Electrical & Lighting 16 01-02-2004 08:02 PM
My car hates to start sometimes. Anyone else with this problem? Eric SS General Forum Archive 17 02-09-2001 08:33 AM
