Old 12-14-2005, 08:31 PM   #1
EagleRockWrex
Member#: 95780
2008 Infinity G37S
Ivory/Black
Default My Take On My New AccessPort,Feeback Please
Alright, I just put this thing on my car and I am AMAZED !!!!!!! Right off the bat I'm getting 16.8 PSI, boost is up and down betweent 15 and 16.8, but from what I believe it will settle itself down once the computer takes to the new base. This thing went from pretty fast to real fast in about 20 min !!!
My only gripes are, once you load in a base map, mine is the 91 Oct v1.30, then I loaded in a real time 93 Oct v1.30 (I'm running 100 octane right now) When I put in 'View Current Map' it says 91v130.... How are you supposed to make sure you are on 93 or 91 because after this tank, its back to 91 octane (5.99 a gallon is alot to have some extra fun )
And, the vaccuum reader is -10 in/hg (boost gauge shows 20 in/hg, AP reads 10 in/hg) off from my boost gauge.... no idea why that would be.
How can I revert back to a base map and not run a real time map ?
EagleRockWrex is offline   Reply With Quote
Old 12-14-2005, 09:56 PM   #2
WRC-Go
Member#: 29917
2003 WRXWgn-WRB sold
EVO IX-MR, 98 Viper
First, Cobb tech told me that your base map is what displays, regardless of what you've selected as a real time map. If you've put a real time map over your base map, I believe to get back to your base, you need to select the real time map corresponding with your base map. (Note, if you haven't selected a different real time map, your base map automatically runs the corresponding real time map, so no need to select it if you haven't changed RT maps, or so I've been told).
Can't answer your vacuum hose questions...
WRC-Go is offline   Reply With Quote
Old 12-14-2005, 10:17 PM   #3
yobtah
Member#: 48939
You could also simply disconnect your car's battery for a while to switch back to the 91 octane base map. When the ECU loses power, it will default to the real time settings that correspond to the base map you've flashed.
Are you sure your isn't displaying psi rather than inches (or possibly millimeters) mercury? I have an '03, so my AP may be very slightly different... but I know it displays psi for both positive and negative pressure while my Omori boost gauge displays psi for positive pressure and mmHG for negative (because you can't really have negative pressure). If this is the case, you'd be close to -20 on the boost gauge and -10 on the AP while at max. vacuum.
yobtah is offline   Reply With Quote
Old 12-15-2005, 09:31 AM   #4
JRSCCivic98
Member#: 67080
Or you could simply use the Reset ECU feature of the AP. In that case the RAM is cleared of any learning/cel codes/realtime maps. It's simpler then unhooking stuff. Anytime you do an ECU reset the RAM is cleared and thus the realtime map as well.
JRSCCivic98 is offline   Reply With Quote
Old 12-15-2005, 12:10 PM   #5
EagleRockWrex
Member#: 95780
2008 Infinity G37S
Ivory/Black
now what are the limits to how many times I can flash a real time/ECU reset/etc ? Isnt there like a 100 program limit before the computer wont take to any more flashing ?
Old 12-15-2005, 12:23 PM   #6
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
You can flash a realtime map as many times as you like without affecting the "100 reflash limit". It is only when you reset the basemap that it takes away from the imaginary 100 count.
As far as I know nobody has ever had an issue with the ecu crapping out after 100 flashes, I think it is just stated as a precautionary measure.
boundy3 is offline   Reply With Quote
Old 12-15-2005, 02:18 PM   #7
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
You are correct. The AP displays PSI, most boost gauges display PSI for positive values, and mmHG for negative values.
The ratio between PSI and mmHG is about 1-2, so -10psi is about -20mmHG.
drees is offline   Reply With Quote
Old 12-15-2005, 02:40 PM   #8
EagleRockWrex
Member#: 95780
2008 Infinity G37S
Ivory/Black
Cool, mind is at ease and all is well !
Accessport V2: My take on perm-mount blind26 AccessPort 4 08-01-2007 01:55 PM
My take on hauling tires on the hitch. GLwagon Tire & Wheel 11 03-19-2007 09:08 PM
pics of B&N/ my mods on my STI/ C6 vette all on my new web page TUSWM Mid Atlantic Impreza Club -- MAIC 45 10-06-2004 02:52 PM
('93-'01) prodrive taking on a new market =P elemental Impreza Forum 5 07-26-2001 11:05 AM
My take on ClubSi.com 's downfall (dont let this happen to this club!!) ProgSi General Forum Archive 22 05-27-2000 07:36 PM
