Closed Thread
Old 12-14-2005, 10:26 PM   #1
jsavage
Member#: 15699
02 wrx
Default Who is good with Diagnosing Weird Engine Behaviors? I got a stumper.
1996 2.2L Impreza (my second subaru...love er ta bits)
172,000 on the odo.
Here's the problem:
Engine randomly cuts out at idle/Won't start to begin with randomly (but usually only when the engine is warm)
Once the car has stalled it refuses to start, but one of the two ALWAYS works:
- Let the car sit for 10 minutes
- Let the car turn over for a bit, while pumping the throttle.
I've had it to my mechanic for this, but everything he replaces is only a temp. fix. He replaced the fuel filter, distributor, man I can't even remember what else. Car still has a CEL (I believe for the knock sensor), which has been on for years. At some point with subaru's I just end of forgetting about getting each CEL looked at.
I think it's a timing issue...just because of the randomness of its behavior. When the car doesn't start it is pretty obviously a fuel issue...like something is preventing fuel delivery...or fuel delivery is happening at the wrong time.
whoever wins gets a banana
jsavage is offline
Old 12-14-2005, 10:29 PM   #2
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Coolant temp sensor.
Get the CEL scanned.
Hondaslayer is offline
Old 12-14-2005, 10:34 PM   #3
joey1313
Member#: 53839
2005 STi, 06 S2K
I would guess fuel pressure possibly.
joey1313 is offline
Old 12-14-2005, 10:35 PM   #4
ivwarrior
Member#: 100610
MBP
I don't know, I'm still trying to figure out how your mechanic changed the distributer on a 96 Subaru.....
I'd start with getting the codes pulled, fix what's causing the CEL....
ivwarrior is offline
Old 12-14-2005, 11:16 PM   #5
jsavage
Member#: 15699
02 wrx
Code is a bad knock sensor.
Distributor CAP was replaced...
jsavage is offline
Old 12-14-2005, 11:17 PM   #6
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
There is no distributor cap on that engine
and get a better mechanic; might be worth paying a Subie dealer to check it out
Mike Wevrick is offline
Old 12-14-2005, 11:27 PM   #7
rubberbiscuitt
Member#: 96566
2002 wrx sedan
black
fuel pump overheating. i don't think there are any sensors involved, so it won't throw a dtc.
rubberbiscuitt is offline
Old 12-15-2005, 12:32 AM   #8
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
This is a really easy fix... and well, 95% sure that it's the source of your problem.
Calamity Jesus is offline
Old 12-15-2005, 12:36 AM   #9
jsavage
Member#: 15699
02 wrx
then what the hell is that black thing that all the spark plug wires go into?
jsavage is offline
Old 12-15-2005, 12:37 AM   #10
jsavage
Member#: 15699
02 wrx
Really? DIY fix or easy for a mechanic to fix?
jsavage is offline
Old 12-15-2005, 12:41 AM   #11
Calamity Jesus
Member#: 44501
1984 That's *Sir*
The black thing on top is a distributorless coil. It has no cap, it's one piece. They do occasionally fail.
Very DIY. The temp switch is right on top of the engine towards the front where the radiator hose meets the block. I think it costs like $10. As long as you swap it out quickly, you shouldn't lose more than 2oz of coolant.
Old 12-15-2005, 12:43 AM   #12
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
That's your ignition coil assembly I believe.
TyranosaurusWRX is offline
Old 12-15-2005, 12:44 AM   #13
squeech
Member#: 38280
2000 2.5RS w/ EJ205
tuned @ teh Ghetto Garage
That's the ignition coil pack. Cars with Electronic Fuel Injection don't use distributors, the ignition coils are charged/discharged by electronics controlled by the ECU.
squeech is offline
Old 12-15-2005, 12:53 AM   #14
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Heh, this reminds me of this one lady who had her 2004 Forester not able to start where she was at home. So we thought it was towed in. Well it wasn't.
Needless to say, we could start it up fine.
So we asked the lady about how she got it here.
She said: "Well, my husband played around with the carburator."
Me and another tech: , <runs away, and very far>
-paK +1
Pakin is offline
Old 12-15-2005, 01:36 AM   #15
jsavage
Member#: 15699
02 wrx
You mean to tell me that a little motor doesn't spin around controlling spark? A computer can do all that!!!!!!!!!!
jsavage is offline
Old 12-15-2005, 01:37 AM   #16
jsavage
Member#: 15699
02 wrx
BTW...what makes you think it is this part? What about this coolant temp. sensor would make the car behave this way?
jsavage is offline
Old 12-15-2005, 08:45 AM   #17
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
My guess is that it is the cam and crank sensor...
RexyGirl is offline
Old 12-15-2005, 09:00 AM   #18
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
The problem's at idle, so how about the idle control system for the throttle?
rogue is offline
Old 12-15-2005, 09:02 AM   #19
punk'd
Member#: 74342
05 STI
fuel pump my daughters mustang did the same thing I put a new fuel pump in problem fixed
punk'd is offline
Old 12-15-2005, 10:33 AM   #20
Synacr0n
Member#: 90681
98RS w/07 WRX swap!
02 WRX to 04 STi to swap!
I would think "fuel pump" myself
-paK +1
You should have replied, "Whats a carburator?"
Synacr0n is offline
Old 12-15-2005, 11:34 AM   #21
mnavarro
Member#: 51537
2004 WRB WRX STI
62 Corvette/11 Cherokee L
With that mileage, fuel pump.
mnavarro is offline
Old 12-15-2005, 09:34 PM   #22
Hondaslayer
Member#: 4562
1995 Legacy LSi
It's a Subaru, fuel pumps very rarely fail.
Coolant temp sensor, or as Kelly pointed out, cam and crank sensor is possible as well.
But not wanting to restart when it is warmed up screams of coolant temp sensor.
Old 12-16-2005, 09:34 AM   #23
punk'd
Member#: 74342
05 STI
Fuel Pump
punk'd is offline
Old 12-16-2005, 09:50 AM   #24
GeeZee
Member#: 88035
2006 Mazdaspeed6
2006 Tribeca
That was my first thought too. I had one go bad on me and the car exhibited the same problems.
GeeZee is offline
Old 12-16-2005, 10:22 AM   #25
Calamity Jesus
Member#: 44501
1984 That's *Sir*
The coolant temp sensor is how the computer decides how rich the start-up mixture needs to be. Just like a choke on a carburator, the ECU will increase the amount of fuel used at startup when the engine is cold to get it started. When sensor stops responding, the computer defaults to cold-start mode. Unfortunately, a rich mixture will just flood the engine when it's already warm, making it very hard to start. The rich mixture also makes the warm idle rough and usually causes minor hesitation while driving.
Closed Thread
So, who is good with Cisco stuff? cucamelsmd15 Off-Topic 24 12-15-2009 11:11 AM
who is good with their hands???? nwrDRIVER North West Impreza Club Forum -- NWIC 21 11-03-2008 07:25 PM
Weird question for anyone who is familiar with Woodbury CT BrysImpreza New England Impreza Club Forum -- NESIC 5 06-16-2006 10:25 AM
Weird engine behavior after installing EGT probe. tmat3 Normally Aspirated Powertrain 5 02-12-2002 12:12 PM
Just got dropped from my Insurance, who is good on RS's for auto insurance? STiShawn Mid West Subaru Owners Club Forum -- MWSOC 20 04-26-2001 07:07 PM
